SMD's with heat slugs
2007-06-08 by Dave Miller
I have a question to the other members in the group.
I use alot of SMD parts, many of which have heat slugs on the bottom of
the parts for thermal dissapation. At work, when I have a PCB made up
by a board house, we lay these out with a large solderable pad under
the part, then connect the top side of the PCB to the bottom side with
numerous feed thru holes. When the part is soldered to the board this
provides a themal path to the copper on the botom of the board. With my
home made TT, or photo boards I can not make plated thru holes to
provide this thermal path, but I still need to get the heat out some
how.
I have thought of drilling many feed thru's under the part and feeding
a thick copper wire from one side to the other, then on the compnent
side cut or grind the surface flat so the component can still be
soldered down.
Has any one else had to use similar parts? How have you managed to get
the heat out of these parts? Any other suggestions?
Re: [Homebrew_PCBs] SMD's with heat slugs
2007-06-08 by Stefan Trethan
> soldered down.
I do the same as you, make a large hole and fill it with copper and solder.
If done well the solid copper slug can be better than a pro PCB, but
it's lotsa work if you compare the two. You can solder a heatsink to
the back.
ST
Re: SMD's with heat slugs
2007-06-09 by derekhawkins
Double sided thermal tape (or thermal epoxy) and heatsink.
http://www.pbase.com/eldata/image/66582088
--- In Homebrew_PCBs@yahoogroups.com, "Dave Miller" <dmiller45@...>
2007-06-11 by Dave Miller
get
> --- In Homebrew_PCBs@yahoogroups.com, "Dave Miller" <dmiller45@>
> wrote:
Thanks Derek, the method you describes works great for parts where you
have access to the heat tabs, unfortunately the parts I am describing
have a heat slug under the part and are designed to be soldered to the
PCB. Once the parts are soldered down, there is no access to the heat
tab, thermal dissapation is only thru the PCB.
2007-06-11 by derekhawkins
>unfortunately the parts I am describing have a heat slug under the
>part and are designed to be soldered to the PCB.
If I followed the datasheet for the heatsinked component in the shot
then there would have to be 24 vias connecting the bottom 8 sq. cm
pad to the top 3 sq. cm pad to which the slug is soldered.
The case is always a viable means of heat dissipation, albeit with
higher junction-to-whatever thermal resistance. Couple the case to a
suitable heatsink and your junction-to-ambient resistance can be more
than suitable.
wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "derekhawkins" <eldata@>
to
> get
you
describing
heat
2007-06-11 by Brian
One thing you can do is drill holes and use small eyelets for via's.
The only problem is the part will not sit flat on the board.
bottom of
up
under
with
this
With my
some
> how.
feeding
compnent
> soldered down.
get
Re: [Homebrew_PCBs] Re: SMD's with heat slugs
2007-06-13 by Stefan Trethan
I doubt this would work at all with the small leadless QFN packages,
or at least soldering the other pins would be damn tricky then.
Possibly for larger parts with leads though...
ST
2007-06-13 by Edward Downer
If the part has a "large" central heat pad you could mill out the era
and press a heatsink on it from the back side of the board.
Edward
