Sharing my success and lessons learned
2007-05-17 by Curtis Pope
I just wanted to share my recent success and lessons learned. I need to make my first PCB which takes a passive RFID reader IC and integrates it with a PIC, MAX232 and several LEDs and required components. Using Eagle for my design, I layed out my schematic and then went about making the PCB. First lesson learned...Some ICs aren't designed for single sided boards...like the MAX232 for example...Pins 1 and 3 connect together with a capacitor and pin 2 needs to go to another cap and then to VCC. In a future design, I might switch to another MAX chip that has the caps built in...the IC might be a little more expensive, but you will save money in the caps and pain of double sided board. After finding a decent layout, I realized that needed to go 2 sided as I had about 4 traces that I couldn't route on one side and 2 of those I couldn't even jumper easily. So I routed those traces on the front side...not a big worry as the clad board I am using is 2 sided anyways. Sooo...I went out and go the Staples Photo Basic paper as everyone says that is the best (even though I have some hammermill glossy sitting here, but it isn't the stuff that everyone says you should use). Came home and started printing...well my toner cartridge was low/old as this printer had been sitting in the closet for about 6 months...so back to staples for some "FRESH" toner. Printed out my design and looks great. The transfer went pretty smooth...except: Lesson 2...Don't forget to clean the board. Well I did forget so I had to clean it all off and start over. 2nd time, I don't think I even cleaned it enough...next time it is getting the FULL treatment. Etching was pretty simple, I did use Ferric Chloride as I wanted something simple for my first try, but will probably switch to the Muriatic/Peroxid cocktail later. Drilling was pretty smooth, used a drywall screw and hammer to tap an indention where the hole was to be drilled and a 1/32 drill bit to drill it out with my dremel. Assembly...here's where I learned lesson #3...double sided boards without through plating are a pain to solder. I had to apply solder to the lead between the component and the pad, keep it hot and then push the component down to seat nicely. I have now reworked my design and put an extra VIA and small bottom side trace near the component so i can just solder a wire (using cut off leads) through the board to pass the signal. Anyways...hopefully someone will learn something from this post. I have been looking at doing boards like this for years, but this is my first try. I couldn't have done it without the information on this list and a few other places on the Internet. Regards, Curtis
