Spray Etching
Spray Etching
2007-04-21 by electrophilip
I have just tried ferric chloride for the first time, it seems to etch
faster & better than ammonium persulphate.
Has anyone have simple plans for a spray etcher (only smallish)I would
like to be able to see the boards as they are etching without lifting
them out of the solution and thought if boards were mounted on an
angle a bit less than 90 degrees i could spray stripper from top edge
and still see board.
Any ideas appreciated.
Philip
p.s. my current setup is pyrex dish submersed in aluminium custom pot
sitting on hot plate.
Re: Spray Etching
2007-04-21 by jcarlosmor
You should try with a pump that has no-metal parts in the impeller. I
am very impressed why in this forum almost nobody seems interested in
building a spray etching system. That is the disadvantage of the "home-
brew" point-of-view. When you want to go like the pros, nobody seems
interested. By the way, with a home-build spray ecthing system I was
able to etch an 30x30 cm double-sided board in 4 minutes with ferric
chloride at room temperature, with excelent resolution.
Re: [Homebrew_PCBs] Re: Spray Etching
2007-04-21 by Dale J. Chatham
I've been doing PCBs for a good 30 years, perhaps more...
I wonder why one would not use the garden sprayers one can buy from
Lowes and an aquarium pump?  It would be a balancing act between
pressure available and spray pattern, but I suspect it could be done.
> I built a spray etcher, admittedly it was a very substantial hobby
> project. It was about 3 years ago when I had my first attempt. You need
> tools like a lathe to fabricate pulley and other rotational parts, and a
> hot air plastic welder to make the tanks. There is lots of plumbing
> involved, hoses, brackets, and depending on how you do the spray arm
> oscillations, you need electronics for control. Learning how to prevent
> corrosion and leaks was another big challenge for me.
> I use two paralleled modified 12 volt Shurflo diaphragm pumps, giving
> approximately 2.5 bar at 14L/minute total into 4 fan nozzles positioned
> on opposite sides of the PCB. It is a double sided spray etcher, with
> PCB located vertically at the center of tank. The tank lid has a spray
> proof slot for the PCB to enter.
> Before anyone comments on the excessive effort in designing and building
> ones own spray etcher for the purpose of homebrew PCBs, I'll say its
> ultimately just part of a hobby and much like any home project.
> Adam
2007-04-21 by Adam Seychell
Adam
Re: Spray Etching
2007-04-21 by James McGee
Maybe I'm a little out of sync with the conversation, but my first
thoughts involve air and suction. like a siphon feed on paint guns and
sand blasters. a valve to control air flow, two plastic pipe joining at
a slight angle to form the suction. a tip for the spray pattern. Sort
of a large version of the cheap plastic model car airbrushes.
Any thoughts?
Re: Spray Etching
building
> Adam
I am not interested in knocking anyones design, I have a lathe, mill &
most other tools needed to construct hobby stuff.
I am interested if anyone has photos or links or parts lists, I'm in
Tasmania so no doubtedly I may not be able to get parts from the other
side of the world.
I am prepared to make an etch tank for hobby use that may get used
from 1 time per month to many times per week.
My preferred size board to fit would be no bigger than 200 x 300 mm as
that is the biggest board that will fit in my exposure unit.
Philip
> Any thoughts?
You might have a few ventilation problems. Remember , your not spraying
water on the garden. Such volume of air will force very undesirable
amounts of etchant mist out of the spray chamber. The etchant must be
contained. I'm not even going to ask if you were thinking of spraying
out in the open.
Adam
2007-04-21 by guja
you dont need spray etcher to make such boards.
  it is much easier to make tank that uses foam .
  you need tank (with angled board inside) , low pressure pump, simple bubbler and few litres of fecl .. and an (domestic) additive to make good fecl bubbles :)
building
> Adam
side of the world.
Philip
Ahhh...imagining that irresistible "new car" smell?
 Check outnew cars at Yahoo! Autos.
Re: Spray Etching
2007-04-22 by pcb.easy
Snip
Most Home-brew-ers like to KISS or Keep It Simple Sam. A simple bubble
etch tank with an aquarium tank air pump using a 300ml etch solution of
1 part ~30% HCl and 2 parts 3% H2O2 can etch a 6" * 9" board in about 3
minutes. This set up involves no heating of the chemicals, no pumps, no
electronics to control the spray nozzel pattern, and no spray mist.
This set up provides crisp lines, with out the mess. Sure a spray tank
is nice for production runs with multiple boards at a time, but as a
home-brew-er KISS works for most.
2007-04-22 by Stefan Trethan
On Sat, 21 Apr 2007 22:15:16 +0200, jcarlosmor <jcarlosmor@...>
wrote:
> I
The reason is it's old news, several of us have been there, done that,
tried that, and few are eager to go over it all again.
Look in the archives, virtually any form of spray etcher one can envision
has been tried or used or at least discussed at great length.
Suggest a topology, and i tell you roughly what was done about it since i
joined.
I personally tried making a rotary spray etcher, but it was way too much
noise and hassle for what it did. At the moment i think the setup with a
sureflow or flowjet membrane pump and either stationary or moving nozzles,
as some already use, would be the most reasonable. But still expensive and
complicated.
ST
Re: Spray Etching
2007-04-22 by James McGee
Sorry, I figured everyone had taken care of their ventilation
problems. I cant etch without proper ventilation, I want to
live ........... one breath of the stuff and I went to work outside.
That stuff WILL kill you. My suggestion is First take care of the
ventilation before you etch another board with any process.
 --- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@...>
guns and
joining at
Sort
> > Any thoughts?
spraying
be
spraying
> out in the open.
> Adam
CuCl of reasonable strength in a bubble etcher is no problem at all,
indoors with no additional ventilation.
Neither is FeCl i would presume.
I used to run the bubbler closed loop, but the mist made the valves in the
air pump stick (maybe it would've worked better had i added mist trap).
But even with the open loop air there is minimal smell and no irritating
fumes.
ST
2007-04-22 by Russell Shaw
Bubble and foam etchers are a very gentle agitation and etch everything
off in most cases. Many times however, traces of copper are left because
of stubborn resist caused by variations in pcb cleaning, coating, and age
of chemicals used.
A spray etcher with proper nozzles has a *very* hard fluid impact compared
to bubble etchers and really knocks off the last few percent of stubborn
cases.
> building
>> Adam
> side of the world.
> Philip
On Sun, 22 Apr 2007 14:00:30 +0200, Russell Shaw <rjshaw@...>
> of chemicals used.
> compared
> cases.
Maybe including the resist we want, considering many of us use
less-than-industrial-strength resist.
ST
2007-04-22 by Adam Seychell
Spray etching has the advantage of etching more downward and less
sideways. There is no other way of achieving that with non-spray etch.
Gravity can't help you either because insoluble film formed by FeCl3 or
CuCl2 etching at the copper surface does not fall uniformly or
predictably in a stagnate solution.
Still, I do not think its worth while a hobbyist building a spray etcher
  in order to improve etch factor.
Adam
