No more going to Radio Shack - First attempt with Muriatic Acid GOOD!
2007-04-11 by izzo47
Went to 3 RS for Ferric chloride all OUT....
Reading old msgs, I finally found that Lowe's had it, a Gal was 7 bucks.
I bought some regular 3% Hydrogen Peroxide. It work well and fast but
would like any feed-back on the recipe I used.
 1 part (200ml) 31.45% Muriatic Acid, 2 parts (400ml) Peroxide. Color
was light green, No heat used. Board went in first, pour the 400ml of
Peroxide on the board and in about 6 minutes it was done (small test
board) 3x2 inches. I did get a little scared when I measured the 400ml
of Peroxide in the same plastic cup as there maybe was a drop of the
Acid still in there and saw smoke/vapors for a second. I noticed that
during the clean-up with water it turns a nice light blue, natural I
guess?
Question is the recipe OK? Can it be fine-tuned.
Can it be saved and brought back to life to use again?
BTW if you can get your hands on the green tape they use at Wal-Mart in
the Photo Dept to attach leader cards that go through the film
processor, get some. It will not melt or leave any residue I am sure of
that as a friend that works there gave me a roll.
Re: [Homebrew_PCBs] No more going to Radio Shack - First attempt with Muriatic Acid GOOD!
2007-04-11 by Philip Pemberton
If that's anything like the Fujifilm tape we use on the film processor at
work, it's a thick-ish blue plastic tape with a silicone-based adhesive on the
back. Kinda like 3M Kapton tape, but thicker.
Phil.                         |  (\_/)  This is Bunny. Copy and paste Bunny
ygroups@...         | (='.'=) into your signature to help him gain
http://www.philpem.me.uk/     | (")_(") world domination.
Re: No more going to Radio Shack - First attempt with Muriatic Acid GOOD!
2007-04-12 by izzo47
I guess...all I know is if you tape your design to the copper and if
you use the hot iron method like I do it peels right off. When I
etched the board, wherever the tape was, was completely gone. I think
the heat in the film processor is only about 85-90C so I was
surprised.
--- In Homebrew_PCBs@yahoogroups.com, Philip Pemberton <ygroups@...>
wrote:
> SNIP <
processor at
adhesive on the
paste Bunny
2007-04-13 by skullworks
bucks.
but
Color
of
test
400ml
that
I
> guess?
Mart in
sure of
Blue would seem to indicate the formation of Copper Sulfate crystals.
