Best method for 2oz copper on 1/16" boards?
2007-04-02 by d1camero
Hi all,  I am building a tube guitar amp PCB.  It requires heavy
copper on thick boards.  I would like to use 1/8" boards, but cannot
find any locally.  Anyways, here are my plans:
Toner transfer method using Phoenix TTS paper (all I can get here in
Canada).  Then I plan to etch using MG Chemicals Sodium Persulphate
and hand agitation.
Is this reasonable for this thick of copper, or should I try a
different method.  Any hints, tips, or related sites would be appreciated!
thanks
Don
Re: Best method for 2oz copper on 1/16" boards?
2007-04-02 by donahn
> and hand agitation.
appreciated!
> thanks
> Don
You could probably get this to work, but for thick through hole parts
in tube amps, I believe the reason for 1/8" board is stability in the
face of higher heat levels.  Single sided is not going to cut it
though, as one thing that helps is having plated through holes to
hold the part mechanically in place.  Supposedly, you should use
double sided just to have a solid metal eyelet holding the part to
the pcb.  This is even if traces only run on one side.  So for a high
quality tube amp built on a pcb, you should farm out the pcb
construction for the plated through holes.
Read this for more info:
http://www.aikenamps.com/PCBorPTP.htm
If you're going to homebrew you might want to try eyelets through a
plain (no copper) pcb.  Here's more info:
http://www.eham.net/articles/16053
Although using eyelets seems rather low tech, it looks like it is
considered a high quality (though labor intensive) construction
technique.  Old Fender amps in the 50s and 60s (preCBS) used eyelets
and apparently they are still reliable.
Cheers,
Don
2007-04-03 by d1camero
Thanks for the info Don.  I am actually quite well versed with Aiken,
eyelet construction, PTP, turret construction versus PCB.  What I am
looking for is feedback on how best to expose and etch 2 oz copper on
thick boards.
Anyone else?
2007-04-03 by pgdion1
> and hand agitation.
appreciated!
> thanks
> Don
Hi Don,  I haven't tried TT on anything heavier than 1oz but with my
results I believe it would work well on 2oz boards, especially for
something like a guitar amp with wider traces.  I use Ferric Chloride
to etch mine and even left in for too long, the toner is still solidly
adhered to the board,. It takes some good scrubbing to remove it even
after all of the etching is done (I use fine steel wool with alcohol
to strip it off and polish up the copper - works great).
I haven't tried the Sodium Persulphate but I did try Hydrochloric Acid
twice and it does attack the toner after a while. The board needs to
come out as soon as etching is done or the toner starts to lift. I'm
not sure if it would hold up for a 2oz etch or not. And I'm not sure
where the Sodium Persulphate is compared to these others.
Here's one tip for 1/8" boards, do 2 1/16 inch single sided
boards and bond them together with epoxy (or maybe even contact cement
would work).
Phil
KA0HBG
2007-04-03 by Thomas P. Gootee
> 4c. Re: Best method for 2oz copper on 1/16" boards?
>     Posted by: "d1camero" a8723@... d1camero
>     Date: Mon Apr 2, 2007 6:40 pm ((PDT))
> thick boards.
> Anyone else?
For the etching, you might want to try using Muriatic Acid and Hydrogen
Peroxide, instead of the Sodium Persulfate.  It would be much cheaper, much
more readily available, and should work at least as well.
I have the details of the etchant "recipe" on a webpage, at
http://www.fullnet.com/~tomg/gooteepc.htm .
Good luck.
- Tom Gootee
2007-04-03 by warrenbrayshaw
--- In Homebrew_PCBs@yahoogroups.com, DJ Delorie <dj@...> wrote:
> "d1camero" <a8723@...> writes:
> > Phil, thanks for the info.  Good idea about the sandwich - I think I
> > will try that!
> Beware that epoxy softens when heated.  If that's an issue, use
> something like J.B.Weld, which is more heat tolerant.
The MSDS (Material Safety Data Sheets) for J-B WELD shows that there is
10-20% iron powder in the resin and hardner. Perhaps this would not be
a good
choice for laminating PCB material with the chance of a short via the
adhesive layer.
http://jbweld.net/techinfo/index.php
Re: [Homebrew_PCBs] Re: Best method for 2oz copper on 1/16" boards?
2007-04-03 by Roland Harriston
Actually, I believe that " J.B. Weld"
is simply a two-part epoxy system with iron
powder added.
Same basic characteristics as generic
epoxy material.
Since the iron powder does not "crosslink"
with the epoxy system, I'm not sure what
viable function it serves, save for making
the system appear to be metallic.
Once hardened, (crosslinked) it does not "soften" to any
great extent when heated, but rather, will
decompose and burn if the heat rise is
high enough.
Roland F. Harriston
> > > will try that!
> a good
> adhesive layer.
> <http://jbweld.net/techinfo/index.php>
2007-04-03 by DJ Delorie
"warrenbrayshaw" <warrenbrayshaw@...> writes:
> is 10-20% iron powder in the resin and hardner.
Doh!  Nevermind.  Still, epoxy and heat don't get along, something to
keep in mind.
(jbweld is known to me because it's used to hold model rocket engine
mounts in place, instead of epoxy)
2007-04-03 by Stefan Trethan
> keep in mind.
Why do you get that impression?
FR4 _IS_ glass in an epoxy matrix.
In fact, JB weld itself is an epoxy if i'm not mistaken, only they take
more $ for the brand and packaging.
There are different kinds of epoxy, for example the cheap 5 minute stuff
is far less strong and resistant to chemicals than the longer curing
versions. I expect it is also not very good with heat but i never used it
in such an application. Shouldn't be too tricky to get hold of a high
quality epoxy that is comparable to the PCB itself.
If stuff gets that hot in electronics there's a problem somewhere anyway.
ST
"Stefan Trethan" <stefan_trethan@...> writes:
From all the stories of motor mounts that fail due to epoxy softening.
And from my dad telling me to use a torch to remove epoxy plugs from
car parts.  And from HowItWorks showing heat-softened epoxy sheets
used for vacuum forming.
Yes, if a pcb gets that hot, something else is usually wrong.  But if
you're suing 2oz copper and 1/8 boards, I'm guessing you're probably
concerned about heat anyway.
My only point is, if you're concerned about heat, be careful about the
adhesive you use.
There are accountable reasons why PC boards heat up. Usually it is
because the designer
did not take into consideration how much current various traces on the board
need to carry.  There are formulas and calculations that the "pros" use
to design
high current carrying PC boards, especially in laying out power supply
boards.
With 2 oz copper, and proper design, one can make boards that can carry
a lot of current. I don't have a good feeling for what increasing the
thickness
of the substrate would do to make a properly designed PC board dissipate
more heat. Epoxy-glass  is not a very good heat conductor.
Heat sinks and fans usually handle heating problems, along with
properly engineered circuit trace widths..
Epoxy systems generally "decompose" when exposed to high temperatures,
and applying heat is a quick and dirty way of breaking down an epoxy bond.
I suspect that there are some toxic fumes emitted when epoxy systems are
decomposed via the application on intense heat.
Roland F. Harriston
> <mailto:stefan_trethan%40gmx.at>> writes:
> adhesive you use.
2007-04-04 by Jumy Cai
2oz is good,but I wanna know the PCB layers you layout? I mean you must consider the thermal derating in the preparation of your design.
----- Original Message ----
Sent: Wednesday, April 4, 2007 6:48:07 AM
Subject: Re: [Homebrew_PCBs] Re: Best method for 2oz copper on 1/16" boards?
to design
boards.
thickness
Roland F. Harriston
DJ Delorie wrote:
> "Stefan Trethan" <stefan_trethan@ gmx.at
> <mailto:stefan_ trethan%40gmx. at>> writes:
> adhesive you use.
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
http://tools.search.yahoo.com/toolbar/features/mail/
2007-04-12 by lists
In article <op.tp77d0xemg0lsf@tu-x2pj5qeyp2u4>,
Fact of life - valves get hot.
I have several times had to make PCBs to replace burnt out ones in old
commercial valve equipment. Admittedly the originals were Paxolin rather
than fibreglass but...
Usual scenario is the solder joints between the PCB and the valve-holder,
because of the heat and the cycling, start to go crystaline. They become
high resistance and "dry" which causes the generation of more heat which
passes back along the track softening the adhesive and causing the track
to lift off the board charring it at the the same time.
2007-04-12 by lists
In article <eus4im+q40f@...>,
Possibly but there is also the weight and leverage caused by valves. Not
forgetting the forces involved in getting them in and out of the sockets
periodicaly to replace them.
2007-04-13 by Len Warner
>high resistance and "dry" [snip]
At 3:24 pm ((PDT)) Thu Apr 12, 2007, stuart.winsor.lists wrote:
>[snip] but there is also the weight and leverage caused by valves. Not
In your experience and opinion, do the joints usually fail
1. through the body of the solder or
2. alongside the solder tag?
1. suggests to me either
a) simple work hardening and stress fracture, possibly
b) combined with recrystallization near the melting point,
while 2. hints at
c) brittleness though formation of an intermetallic compound
with something dissolved from the tags.
A high-temperature solder might reduce (a) and (b) by
being stronger and more stable at the working temperature
while a solder doped with small amounts of other metals
might reduce (b) and (c).
There are a fair number of online articles on solder metallurgy,
some produced by metals suppliers such as Johnson Matthey
and some propelled by the recent RoHS drive to lead-free solder.
Whether it's worth the bother of seeking something different from
what's already on the workbench, I can't advise ;-)
