Laserjet 4 plus Problem !!!
2007-03-26 by Bruno St-Laurent
Hi guys , i'm trying to print a PCB of 2.5 x 10.25 inches dual layer ,
the print are proper lenght but the middle of the print don't match(
offset) !!!! it seem that the printing is not linear !!!
any of you have an idea ???
BSL
Re: [Homebrew_PCBs] Laserjet 4 plus Problem !!!
2007-03-26 by guja
print them both at same time. ( two cdrs, side by side)
Bruno St-Laurent <bsl88k@...> wrote:          Hi guys , i'm trying to print a PCB of 2.5 x 10.25 inches dual layer ,
BSL
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
Re: Laserjet 4 plus Problem !!!
2007-03-28 by teknochaman
Hi Guja,
Let me say that LJet stuff wasn't technically possible
when it appeared (mid 90's)
I used to register double sided for offset duplication
and I couldn't get it.
Trouble is the mechanism of the LJIV, as they weren't
prepared to 'register' precisely on both sides.
That could be work for the models being 'double-side
enabled' then corporate office printers of the mid
90's.
You'll ned to do some manual guide positioning system
for proper alignment.
Hope that helps.
Posted by: "guja" guja2001bg@...   guja2001bg
Mon Mar 26, 2007 2:03 pm (PST)
side)
Bruno St-Laurent <bsl88k@netscape. net> wrote: Hi guys
layer ,
print don't match(
BSL
Pregunt\ufffd. Respond\ufffd. Descubr\ufffd.
Todo lo que quer\ufffdas saber, y lo que ni imaginabas,
est\ufffd en Yahoo! Respuestas (Beta).
\ufffdProbalo ya!
http://www.yahoo.com.ar/respuestas
RE: [Homebrew_PCBs] Re: Laserjet 4 plus Problem !!!
2007-03-28 by Russ Blakeman
If working properly they will register correctly as long as you have the
thing to print exactly centered in the page. Also there is a duplexer you
can find cheap for the LJ 4 and 4 Plus, sits under the printer and you
remove the back cover where a cover for the duplexer replaces the back. The
duplexer is L shaped. You can also set an optional 500 sheet tray under
that. The LJ 4 and 4 Plus also has an envelope feeder option. All can be
found cheap enough. To upgrade memory dig out that old 72 pim ram from those
old 486 era machines.
The fuser on the 4 and 4 Plus are different and non-interchangeable. The
rollers and many other parts are the same  including plastics. Both can use
an inexpensive MIO type print server/network card.
I do this for a living and signs are an additional business added in the
last year although I have lots of experience in it since the 70's including
silk screening. Also if anyone ever needs a fuser rebuilt reasonably or
their printer repaired (UPS shippable no bigger) I can repair most brands
and models, inkjet, thermal, impact laser/LED and dye sublimation - assuming
I can get parts, if needed.
[mailto:Homebrew_PCBs@yahoogroups.com]On Behalf Of teknochaman
  Sent: Wednesday, March 28, 2007 11:30 AM
  To: Homebrew_PCBs@Yahoogroups.com
  Subject: [Homebrew_PCBs] Re: Laserjet 4 plus Problem !!!
  Hi Guja,
  90's.
  Hope that helps.
  side)
  layer ,
  print don't match(
  BSL
  Preguntá. Respondé. Descubrí.
  Todo lo que querías saber, y lo que ni imaginabas,
  está en Yahoo! Respuestas (Beta).
  ¡Probalo ya!
Re: [Homebrew_PCBs] Re: Laserjet 4 plus Problem !!!
2007-03-29 by Ross McKenzie
Not angry at you Russ...but I have received 4 copies of your posting all
time stamped 9:49. I guess Yahoo has "soiled its pants" again.
Ross
> ...... etc, etc....
2007-03-30 by Bruno St-Laurent
Did a small workaround to solved it !!! i printed first layer then
rotate drawing 180- degree then print the second layer(mirror)!!!,
Why ?? it prints the 2 layers the same way so they gets the same
offset in the middle , aligning properly for transfer !!!
--- In Homebrew_PCBs@yahoogroups.com, "Russ Blakeman" <rhb57@...>
have the
duplexer you
you
back. The
under
can be
from those
can use
in the
including
reasonably or
brands
assuming
>   -----Original Message-----
>   From: Homebrew_PCBs@yahoogroups.com
>   To: Homebrew_PCBs@...
>   Hi Guja,
>   90's.
>   Hope that helps.
>   side)
>   layer ,
>   print don't match(
>   BSL
>   ¡Probalo ya!
2007-03-30 by Lez
Now thats clever!
2007-03-30 by guja
It is much easier (and more accurate) to print both layers (placed vertically, top layer mirrored) in a single pass. “Offset” may vary.
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
2007-03-31 by Russ Blakeman
I'm not real fond of it making clones of my messages either then sending me
undeliverable messages. Seems to have stopped though.
[mailto:Homebrew_PCBs@yahoogroups.com]On Behalf Of Ross McKenzie
  Sent: Wednesday, March 28, 2007 9:45 PM
  Subject: Re: [Homebrew_PCBs] Re: Laserjet 4 plus Problem !!!
  Ross
you
  > ...... etc, etc....
2007-03-31 by Ross McKenzie
Yeah...not hard to see why some folks just walk away from technology
saying that is a fancy way of wasting time...and nervous energy.
Ross
> sending me
> <mailto:Homebrew_PCBs%40yahoogroups.com>
> <mailto:Homebrew_PCBs%40yahoogroups.com>]On Behalf Of Ross McKenzie
> To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
> Regards,
> Ross
> you
> > ...... etc, etc....
Message Repeats, was: Re: [Homebrew_PCBs] Re: Laserjet 4 plus Problem !!!
2007-03-31 by Mark Graybill
There's a message on the Yahoo Groups Team blog about the message
problem--including an apology:
http://blog.360.yahoo.com/y_groups_team
Apparently the Yahoo servers were accepting incoming emails, but not
acknowledging receipt, so the sending server's mail program would
wait, then try to send it again since as far as it was concerned the
message had not been successfully sent.
So far as I can tell, the problem is over (for the time being, at
least.)
-Mark
> Regards,
> Ross
Re: Message Repeats, was: Re: [Homebrew_PCBs] Re: Laserjet 4 plus Problem !!!
Thanks for that Mark. Like many others I suspect, I only receive Yahoo
group postings via email and therefore did not get the apology or
explanation until yours just now.
Ross McKenzie
ValuSoft
Melbourne Australia
> <http://blog.360.yahoo.com/y_groups_team>
> least.)
> -Mark
> > Regards,
> > Ross
2007-03-31 by Lez
Yahoo has done this in all the groups I know of this last week, but you dont
see it if you get your mail via google, I read it online, helps keep the
nasty viruses out unlike pop 3 servers etc.
(and I can read it at work, as they dont allow you to set up pop3)
2007-04-02 by Bruno St-Laurent
I do agree Guja ,but i can't find how to print both on the same page
with Altium !!!!
vertically, top layer mirrored) in a single pass. "Offset" may vary.
2007-04-02 by guja
It is very easy.
  You have to create postscript files of selected layers  (print-to-file).
  Than you can import them into CorelDraw, where you can align, flip, center, anything you need.
  I am not familiar with new programs, (mine is 20y old) but there must be option
  like Print-to-file or PS-printer.
  with Altium !!!!
Looking for earth-friendly autos?
 Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
