Toner Transfer paper
2007-03-26 by mycroft2152
I've a combination of Samsung ML-2010 laser printer / Xerox 1910 laimnator and Sears catalog paper that has been working well for Toner transfer, that is until I refilled the toner with a generic toner. A new cartidge costs about $80, refills $6, a new printer $60 after rebates. The results were pretty spotty. I tried (again) a number of papers, including the Staples basic photo mentioned on the list. Unfortunately, the Staples Basic Photo paper actually laminated itself to the pcb and was worthless. As a last resort, I dug out some "laser foil". Laser foil is availible at stationery stores. It is similar to the green stuff that is used a protective coating in the press and peel sponge process. I attached a small piece to a carrier sheet and printed directly onto the back side of the foil. I then ran the foil, toner side down, through the laminator. After cooling, the foil peeled off easily and cleanly. I then etched the boards in muriatic acid. H2O2. The traces were very good. I'll definitely continue with this process. It is another technique to add to the list. Myc
