Homebrew_PCBs
Velleman PCB Etching Tank ET-20
2007-03-21 by Leon Heller
I've just bought one of the ET-20 Velleman etching tanks from Rapid
Electronics, it seemed good value at £34.95 + VAT. I've only tried it
with a small scrap of PCB material with a pattern scribbled on it
with a marker pen, but it seems to work very well, taking under 5
minutes to etch it using FeCl3. The tank includes an air pump and
heater. The bubbler is built-in to the base of the tank, and has the
orifices angled, so that the bubbles take a sort of circular path
rather than going straight up, which should help achieve even
etching. I managed to drop the board, clip and support wire into the
tank, but it was quite easy to fish it out with a long piece of
plastic.
It's a lot easier than the technique I've been using for years -
manual agitation of a plastic food container in a larger container
filled with hot water.
Here are the details:
<http://www.rapidonline.com/productinfo.aspx?tier1=Tools%
2c+Fasteners+%
26+Production+Equipment&tier2=PCB+Equipment&tier3=Etching&tier4=Etchin
g+tank+with+agitator+%26+heater&moduleno=77727>
Leon
Re: [Homebrew_PCBs] Velleman PCB Etching Tank ET-20
2007-03-21 by Norm Carlberg
Bad link
Try http://www.rapidonline.com/products.aspx?tier1=Tools%2c+Fasteners+%26+Production+Equipment&tier2=PCB+Equipment&tier3=Etching
Select Etching tank with agitator & heater
Norm
Sent: Wednesday, March 21, 2007 7:55 AM
Subject: [Homebrew_PCBs] Velleman PCB Etching Tank ET-20
plastic.
2c+Fasteners+%
Leon
2007-03-22 by Leon Heller
I've just etched a small board (ARM JTAG interface) using the new tank
and it looks very nice. The instructions suggest two minutes to warm
the solution after switching the heater on; I used about five minutes,
and at least 20 minutes is probably about right. Because of the low
temperature etching took about 15 minutes.
I used my usual photo-etch technique with artwork produced on an HP
DeskJet 5940 inkjet printer using Premium JetStar film. The text on
this board had the default 5 mils line width, and came out perfectly.
Narrowest track size was 12 mils, though.
Here is a photo of the PCB:
http://www.leonheller.com/pcb.jpg
Leon
2007-03-23 by Ronald Ausloos
Didn't you have any problems to fix that heating element in the tank? Here in Belgium , the heater is supplied with 2 big suckers. They even don't fit in that tank! So , I had to fix the heater with some rope .... Time to etch a pcb is the same like yours.
Ron
Leon
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
2007-03-23 by Bryan Pope
That looks *really* good! What process do you use for the photo-etch
technique? I searched the web and found that UV is the conventional way
to develop the resist but was looking through my Jameco catalog
yesterday and they offer a positive photo-etch package from Datak that
is supposed to only need a 100-watt incandescent to develop the
resist.. Has anyone used this product before and if so, what were your
results?
Cheers,
Bryan
2007-03-23 by Leon
Sent: Friday, March 23, 2007 2:50 PM
Subject: Re: [Homebrew_PCBs] Velleman PCB Etching Tank ET-20
> results?
As I said in my earlier post, I use an HP 5940 printer and JetStar Premium
film to create the transparency. I then expose the PCB (precoated positive
resist) in a home-made UV unit, and develop in sodium hydroxide solution.
Leon
2007-03-23 by Leon
Sent: Friday, March 23, 2007 5:27 AM
The heater hangs straight down in mine, the top assembly with the thermostat
control is a bit wider than the tank.
The suckers must be for an aquarium. I broke one of mine pushing it onto the
heater, I should have slid it on from the end. I don't need them, anyway.
Leon
2007-03-23 by Frederic Garbrecht
> results?
I have a little experiance with the Datak positive photoresist boards. I
followed the enclosed instructions to the letter (I also invested in an
exposure frame), used a standard incandescent bulb for a short exposure (couple
of minutes), and voila, very nice board. I've done a few; one was flawed by
overetching, but I wasn't paying enough attention...
Cheers
Fred
2007-03-24 by qamar islam
Leon <leon355@...> wrote: ----- Original Message -----
Leon
The fish are biting.
Get more visitors on your site using Yahoo! Search Marketing.
2007-03-24 by Dale J. Chatham
I made a tank some time ago. I cut a hole in the side slightly larger
than an aquarium heater, then put the heather through the hole and
sealed it with RTV (silicone sealant). I got a small aquarium water
pump and submerged it in the tank in the bottom. It worked as well as
any I've seen.
> From: "Ronald Ausloos" <ronald_ausloos@...>
> Leon
