Homebrew_PCBs
Direct Printing : how to begin
2007-03-20 by teknochaman
Hi everyone,
Got info about when direct printing' thread began this
year.
Keyword search was : 'Future floor polish',
Thanks Stefan!
With that hint I understood lot of things.
Still I have a few basic questions about how-to-begin
1.
Do I need a torch to hack a Epson C84 ? (was told that
about Stylus 880)
2. Guess that in all cases I'd need a flatbed tray or
surface to put there the phenolic or epoxy,
copper laminated substrates to be printed on.
3. Which inks are recommended and wonder if it's
possible to get cartridge refills ?
Hope your hints.
Sam
Preguntá. Respondé. Descubrí.
Todo lo que querías saber, y lo que ni imaginabas,
está en Yahoo! Respuestas (Beta).
¡Probalo ya!
http://www.yahoo.com.ar/respuestas
Re: Direct Printing : how to begin
2007-03-20 by Steve
--- In Homebrew_PCBs@yahoogroups.com, teknochaman <teknochaman@...> wrote:
> Hi everyone,
> year.
> Thanks Stefan!
> 1.
> about Stylus 880)
Take a look in the Links section, Inkjet Application of Etch Resist.
The one relevant to your question:
Direct Inkjet resist printing with Epson printers
Volkan and Stefan's tips to direct resist printing, using MIS Pro ink.
Thanks to James Newton for putting the pages together.
http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm
Please, those with links where you've posted info, add to that Links
folder.
Steve Greenfield
Re: [Homebrew_PCBs] Direct Printing : how to begin
2007-03-20 by Stefan Trethan
On Tue, 20 Mar 2007 03:52:15 +0100, teknochaman <teknochaman@...>
wrote:
> Hi everyone,
> year.
> Thanks Stefan!
Well, as i said, that keyword would turn up the very old posts about using
it in a HP, nothing ever worked back then, not even close, so no much
point in reading it unless you want to know how to kill a printer. The
good stuff is Volkan's post from 2006-4-13 and the following posts.
> 1.
> about Stylus 880)
My theory is that one needs high resolution or a printhead with many
nozzles or both to make it work. The old epsons i tried did not look
promising, the printout came out in individual lines. But it's only a
theory. Still seems safer to me to start with a printer similar to
something known to work.
Or at the very least a modified CD tray in a CD printer.
The initial results were with mispro, especially the yellow. More recently
we have had good reports about original epson inks.
ST
2007-03-20 by docstein99
> > about Stylus 880)
I just bought an 880 at a neighborhood thrift store (which BTW is a
good source for inkjet printers. Given that it would cost about $15.00
to ship ANY printer from ebay, I suggest everyone check their thrift
stores first, as I have seen them as cheap as $7.00 each)
I feel that ANY epson inkjet will probably work, and any used print is
likely to have problems, which I just buy the cheapest printer. Older
printers generally tend to be easier to hack apart, as well.
2007-03-21 by docstein99
Well after hours of wrestling and reading, I think I have to take this
back. I feel a brand-new printer is the only way to save yourself from
spending hours upon days to fix nozzle/head issues from used printers.
Unless anyone manages to find to buy a used one that they can check
before they buy it.
The problem now with the new printers is having to buy 6,7, and 8
expensive printer cartridges instead of two.
Re: [Homebrew_PCBs] Re: Direct Printing : how to begin
2007-03-23 by Stefan Trethan
On Wed, 21 Mar 2007 02:24:09 +0100, docstein99 <docstein99@...>
> before they buy it.
I don't agree. I bought a clogged C84 and the head was easy to clean. Try
to get one where the problem is obviously the vacuum clog, typical
description "I changed the cartridge and now it only prints blank pages,
i'm a silly girl and don't know what to do so i bought a new printer
instead". Oh, and of course "I'm sure it's very easy to fix" - it can be
run over by a truck and sellers will write that line ;-). I always wonder
how on earth they can possibly make such a judgement if they are too
stupid to repair it or even identify the fault...
It seems i can readily buy printers for under 10eur (bought the last one
for 1eur but then even paid 2eur because i did not have the right change
when fetching it ;-) ). I can buy a whole lot of faulty 1-10eur printers
for the price of a new printer.
Also, i'm not certain older printers will work, but that's only a theory.
ST
2007-10-09 by Patrick
Hello all -
A little update needed. I'm working on my second C84 conversion, and
had it working. But then the heads clogged(?), and after more
cleaning (even soaking for 2 days in a few mm deep isopropyl alcohol),
I can't get the ink to feed through the heads, at least not much.
Printing is very faint, and only the black print heads work. No
amount of having the printer clean its heads seems to have done
anything. Any hints? Is it time for a new broken printer?
2007-10-09 by Steve
Never, ever use just isopropyl to clean heads. It doesn't completely
dissolve all the ink, and worst of all it replaces/displaces the water
in the ink, then dries quickly and completely, leaving behind a
compacted hard mess.
I use a mixture of ammonia, water, and isopropyl. Details here:
http://www.polyphoto.com/tutorials/printheadcleaning
Do NOT think that more is better! Do NOT use undiluted household
ammonia, do NOT use lemoney scented ammonias, do NOT use bleach!
I've cleaned up a lot of clogged Epsons and never had to remove the
heads to do so.
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, "Patrick" <hmmmyes2wha@...> wrote:
> Hello all -
2007-10-09 by Steve
> Steve -
> That link appears broken. Can you send the full details - proportions,
> etc.?
> Norm
> Here is the link
> http://www.polyphoto.com/tutorials/PrintHeadCleaning/
Doh! Forgot the capitalization on my own link... thanks for correcting
that for me!
Exact ingredients and proportions on the link. Sorry it's not well
directed, I put it up after having answered the same questions a few
dozens of times on the Heat Transfers list. Put up quickly and not
redone since.
Steve Greenfield
Thanks for the advice Steve. So you think that I have a chance with
some more cleaning? The weird thing was I was in the middle of
printing when the ink stopped flowing. I guess that may bode well
actually..
2007-10-13 by bagmik
I recently discovered that people were printing PCB directly on copper
So I modified an old EPSON Stylus Color 600 to give it a try. Results
were poor, see photo album. I wonder how to avoid individual lines ?
recently
> ST
I will give a try to the mispro inks. By the way, wath's the number of
the epson inks that give good results ?
2007-10-13 by DJ Delorie
"bagmik" <bagmik@...> writes:
Hey! I've got one of these on the shelf; the black ink was dead last
time I used it (long ago) but the color inks at least worked (then,
will have to get it working again). Do you have tips or photos of
your conversion?
2007-10-14 by Michel Baguet
one more word, I used the SCC service utility to clean the print head
http://www.ssclg.com/epsone.shtml
your conversion?
Pinpoint customers who are looking for what you sell.
First, take a look at the results, the 3 photos in album "Stylus Color 600 original ink on copper" that I uploaded to get sure you wanna try.
I will probably try the Mispro inks, don't know yet where to find them, I'm living in Belgium. But I fear that results won't be better with this old printer.
So I'll do like others, find an used C84 or C87 to modify and try to get as good results as they do.
Nevertheless, here are some pictures with a description on how I modified the color 600.
On the front view (Pic 01) ,
- remove the cover (four screws) and the ouput bin,
- remove the platte which hold the 'pizza' (Pic 08) there are two screws,
On the back view (Pic 02), remove the automatic sheet feeder (two screws on each side), to do this, you
have to remove the top gear with a spring first, see pic 11
The print head assembly has to be dismounted to be able to remove a plastic part (Pic 09) from the paper input.
- on the top view (pic 12), remove the platte that hold the printhead ribbon cable, two screws,
- on the back, remove all the pressure roller (pic 13),
- on the left side view (pic 11), remove the three visible screws, there is a fourth screw on the front left side
- once all this done, remove the plastic part (pic 09)
- then reassemble all the stuff back
The automatic sheet feeder sensor has to be put back in place. Without it, the printer will always think there is a paper jam
Keep an eye on how the sensor is assembled to be able to reassemble it later
To do this, cut a part of the sheet feeder (pic 10) and about 5 cm (2") of the black axle.
Mount the sensor in place(Pic 03 - Pic 04)
As you can see, I used some plastic parts to keep the axle in place.
The paper sensor on the left side of the rear view (pic 05) has to be modified. The two lever form an angle of about 45°
I cut the axle in the middle and attach back the two pieces together with heat shrinking tube to form an angle of about 20°.
This modification is needed because the plastic part (pic 09) in the paper input has been removed and the paper sensor lever
doesn't rise enough anymore.
To be able to use 1.5mm tick copper clad, the print head need to be rised. This is easily done with the blue paper tickness lever
and the two black adjustment lever (pic 06), one on each side of the print head rod.
The input tray if made with a sheet of epoxy 2mm tick (pic 02) with a cutout for the paper lever sensor (pic 05)
To feed the copper clad, fix it with tape on a sheet of paper with a cutout of 9cm (pic 07). The printer expect a delay before
the paper pass on the paper sensor.
Things still to be done:
- find an ink that print correctly on copper and which is etch resistant (Mispro inks / original Epson ink ?)
- actually the input tray is kept in place with double sided glued tape, will use screws
- put an output tray to keep the copper clad horizontaly and avoid collision with the print head
- put a guide on the input tray to be able to feed the copper clad always the same way for double sided PCB
I got problem to attach the pictures to this mail (size too big) so I created a photo album in th group - Epson Stylus Color 600 mod
your conversion?
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
2007-10-14 by bagmik
A test with pre-heated copper @ 60°C (140F) give a better result
see photo album 'Stylus Color 600 original ink on copper'
2007-10-14 by Steve
I use SSC, too.
I've rescued a -lot- of clogged Epsons, some that have sat for years
after clogging.
Use the solution I gave on my site, and use lots and lots of
patience. And remember, if a little of something is good, that does
NOT mean that a lot is better! If I say to get the park pad damp,
that does NOT mean flooding it is better! More ammonia is NOT better.
And plain steam distilled or filtered water is better than any
alcohol.
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, Michel Baguet <bagmik@...>
head
2007-10-14 by DJ Delorie
Michel Baguet <bagmik@...> writes:
> wanna try.
Ick, looks like the ink would rather stick to itself than the copper.
Thanks for the instructions, though. Maybe I'll play with it anyway
if I get bored enough :-)
2007-10-15 by Michel Baguet
In fact, I didn't take care for the cartridges, they are the one that stood on the printer for at least a year and not epson brand but a pelican compatible.
So, I'm going to buy new inks and make more tests.
I believe that the ink lost its fluidity.
> wanna try.
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us.
2007-10-26 by Patrick
An update: Heads cleared, up and working - Windex on the park head
for a day worked wonders. No more isopropanol! In fact, I've found
if I use IPA to clean the copper, it causes blotching.
But another question - I'm getting random large drips off my print
heads, leaving big splotches in my circuits, and I don't get even ink
coverage - the first part of the board to print has thinner ink than
the later parts, which is quite heavy and well defined..
Any one else get drips???
Oh, also - - using mispro magenta with a little black, I bake the
boards in a toaster oven on high - and I can't get the ink off! I
haven't tried long soaks in acetone, but so far I can only get the ink
off with steel wool. Not exactly what I want to be doing to my nice
new boards.
How do I take off baked mispro ink?
