paint board cooper image using silk screen - someone with experience
2007-03-16 by juanabba
2007-03-16 by urbom
> I need to make about a dozen or so boards, and as I did not find a
> good paper/xerox printer combination, will like to go
> inkjetprint--->produce silk screen on a shop--->paint the design image
> to the cooper side--->etch the undesired coope
> any hints
> is a good one??
> kind of paint o be used????
> other hints????
> thanks in advance
> jaun
2007-03-18 by juanabba
>Hi Kevin
> Just finished 16 12"x18" boards this way. I used a 320 mesh screen,
> procap capillary film for the emulsion and fuji (sericol) quick dry
> enamel ink. Like all the other processes, cleaning the board well is
> very important. I think Nazdar ink would be fine too. You can
> retouch any pinholes after printing and take off any extra ink. I
> think that possibly an infrared bake after the initial cure might help
> keep the ink on the board if you are using an agressive etch. If yoy
> want any other information about the printing, and where to get
> supplies, let me know. (could probably send enough nazdar ink to keep
> you going for about a decade) The procap is super and gives good
> detail even though it is really costly.
> Kevin
> > any hints
> > is a good one??
> > other hints????
> > thanks in advance
> > jaun
2007-03-19 by Kevin Urbom
2007-03-20 by juanabba
>hi Kevin
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of juanabba
> Sent: Sunday, March 18, 2007 1:48 AM
> Subject: [Homebrew_PCBs] Re: paint board cooper image using silk screen
> Hi Kevin
> thanks for your answer
> I was talking to the professionals down here that produce the
> silkscreen mask, and I became very much sceptic whether the silk scren
> mask could transfer any line below 100 mil.
> They told me that the definition they have for the equipment that
> produce the mask is below 200 DPI.
> Is that the case at your country.???
> how do you produce the mask, using professional services or DIY
> method???
> Juan:
> Sorry for the delay.
> I did my silkscreen DIY. I bought a pre-stretched screen that is 230
> mesh fabric, and used chromaline procap 30 capillary film for the
> emulsion on the screen. With my 400 watt metal halide lamp at 32
> inches, the exposure time was about 35 minutes with an inkjet
> transparency made on 3M inkjet transparency stock. I tried a laser
> printer transparency, but there were way too many pinholes. The image
> is then washed out and dried. I screened white solvent based glossy ink
> onto the pc board and after drying, etched in CuCl. As far as how many
> mils you can do, all of the signal traces on the boards that I did are
> 50 mil traces, separated by 50 mils in the best case, and by about 20 in
> the worst case. I also did a 50 pin centronics connector that has .075"
> pads with .029 holes on about a 2.3mm x 5mm grid. All the holes in the
> pads showed and etched well eough to help guide the drill bit. There is
> a bit of a learning curve on how much to thin the ink, but once you get
> it right, screening the actual boards is really fast. If I quit being
> lazy, I'll take some pics and put them on the group site. I am
> confident that 20 mil traces would be possible with some practice
> Kevin
> Messages
> <http://groups.yahoo.com/group/Homebrew_PCBs/message/18192;_ylc=X3oDMTM2
> dTkyOTMyBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1z
> Z0lkAzE4MjA3BHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTE3NDIwNDE0MwR0cGNJZAMxODE5
> Mg--> in this topic (3)
> <http://groups.yahoo.com/group/Homebrew_PCBs/post;_ylc=X3oDMTJxNGdvbWoxB
> F9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1zZ0lkAzE4M
> jA3BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTE3NDIwNDE0Mw--?act=reply&messageNum
> =18207> Reply (via web post) | Start
> <http://groups.yahoo.com/group/Homebrew_PCBs/post;_ylc=X3oDMTJlZGRkc3JlB
> F9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmdHIEc
> 2xrA250cGMEc3RpbWUDMTE3NDIwNDE0Mw--> a new topic
> Messages
> <http://groups.yahoo.com/group/Homebrew_PCBs/messages;_ylc=X3oDMTJlaTZtM
> 2kzBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmd
> HIEc2xrA21zZ3MEc3RpbWUDMTE3NDIwNDE0Mw--> | Files
> <http://groups.yahoo.com/group/Homebrew_PCBs/files;_ylc=X3oDMTJmcDg3cGtt
> BF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmdHIE
> c2xrA2ZpbGVzBHN0aW1lAzExNzQyMDQxNDM-> | Photos
> <http://groups.yahoo.com/group/Homebrew_PCBs/photos;_ylc=X3oDMTJlb25iYWZ
> xBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmdHI
> Ec2xrA3Bob3QEc3RpbWUDMTE3NDIwNDE0Mw--> | Links
> <http://groups.yahoo.com/group/Homebrew_PCBs/links;_ylc=X3oDMTJmdDY5NGN2
> c2xrA2xpbmtzBHN0aW1lAzExNzQyMDQxNDM-> | Database
> <http://groups.yahoo.com/group/Homebrew_PCBs/database;_ylc=X3oDMTJjajZsM
> TBnBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmd
> HIEc2xrA2RiBHN0aW1lAzExNzQyMDQxNDM->
> Photos:
> <http://groups.yahoo.com/;_ylc=X3oDMTJkdDg0aWc5BF9TAzk3MzU5NzE0BGdycElkA
> zQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMTc0M
> jA0MTQz> Yahoo! Groups
> Change
> <http://groups.yahoo.com/group/Homebrew_PCBs/join;_ylc=X3oDMTJmNGV0ZGdpB
> 2xrA3N0bmdzBHN0aW1lAzExNzQyMDQxNDM-> settings via the Web (Yahoo! ID
> required)
> Change settings via email: Switch
> <mailto:Homebrew_PCBs-digest@yahoogroups.com?subject=Email Delivery:
> Digest> delivery to Daily Digest | Switch
> <mailto:Homebrew_PCBs-traditional@yahoogroups.com?subject=Change
> Delivery Format: Traditional> format to Traditional
> Visit
> <http://groups.yahoo.com/group/Homebrew_PCBs;_ylc=X3oDMTJkOGdwMnBzBF9TAz
> k3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwNmdHIEc2xrA2
> hwZgRzdGltZQMxMTc0MjA0MTQz> Your Group | Yahoo! Groups
> <http://docs.yahoo.com/info/terms/> Terms of Use | Unsubscribe
> <mailto:Homebrew_PCBs-unsubscribe@yahoogroups.com?subject=>
> Recent Activity
> 19
> New
> <http://groups.yahoo.com/group/Homebrew_PCBs/members;_ylc=X3oDMTJmNmliZX
> NkBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwN2dG
> wEc2xrA3ZtYnJzBHN0aW1lAzExNzQyMDQxNDM-> Members
> 2
> New
> <http://groups.yahoo.com/group/Homebrew_PCBs/spnew;_ylc=X3oDMTJmb2hqY3Vz
> BF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwN2dGwE
> c2xrA3ZwaG90BHN0aW1lAzExNzQyMDQxNDM-> Photos
> Visit
> <http://groups.yahoo.com/group/Homebrew_PCBs;_ylc=X3oDMTJlczdua3N0BF9TAz
> k3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBHNlYwN2dGwEc2xrA3
> ZnaHAEc3RpbWUDMTE3NDIwNDE0Mw--> Your Group
> SPONSORED LINKS
> * Printed
> <http://groups.yahoo.com/gads;_ylc=X3oDMTJjMHRtNTI4BF9TAzk3MzU5NzE0BF9wA
> zEEZ3JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA3NsbW9kBHN0aW1lAzExN
> zQyMDQxNDM-?t=ms&k=Printed+circuit+board&w1=Printed+circuit+board&w2=Ele
> ctrical+engineering+software&w3=Electrical+engineering&w4=Electrical+eng
> ineering+career&w5=Bachelor+degree+electrical+engineering+online&c=5&s=1
> 78&g=2&.sig=mV9PE82hdSlE9-KTSgm01w> circuit board
> * Electrical
> <http://groups.yahoo.com/gads;_ylc=X3oDMTJjcDBnODkwBF9TAzk3MzU5NzE0BF9wA
> zIEZ3JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA3NsbW9kBHN0aW1lAzExN
> zQyMDQxNDM-?t=ms&k=Electrical+engineering+software&w1=Printed+circuit+bo
> ard&w2=Electrical+engineering+software&w3=Electrical+engineering&w4=Elec
> trical+engineering+career&w5=Bachelor+degree+electrical+engineering+onli
> ne&c=5&s=178&g=2&.sig=OLCPaWpTecxApgvDRoZHwA> engineering software
> * Electrical
> <http://groups.yahoo.com/gads;_ylc=X3oDMTJjazF1cGQ4BF9TAzk3MzU5NzE0BF9wA
> zMEZ3JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA3NsbW9kBHN0aW1lAzExN
> zQyMDQxNDM-?t=ms&k=Electrical+engineering&w1=Printed+circuit+board&w2=El
> ectrical+engineering+software&w3=Electrical+engineering&w4=Electrical+en
> gineering+career&w5=Bachelor+degree+electrical+engineering+online&c=5&s=
> 178&g=2&.sig=8dKyV5lpIuBKDZx8cuB2nA> engineering
> * Electrical
> <http://groups.yahoo.com/gads;_ylc=X3oDMTJjdGlyN2xtBF9TAzk3MzU5NzE0BF9wA
> zQEZ3JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA3NsbW9kBHN0aW1lAzExN
> zQyMDQxNDM-?t=ms&k=Electrical+engineering+career&w1=Printed+circuit+boar
> d&w2=Electrical+engineering+software&w3=Electrical+engineering&w4=Electr
> ical+engineering+career&w5=Bachelor+degree+electrical+engineering+online
> &c=5&s=178&g=2&.sig=0iY88q82jkWYGIpFDG2Lxg> engineering career
> * Bachelor
> <http://groups.yahoo.com/gads;_ylc=X3oDMTJjdTNobDNzBF9TAzk3MzU5NzE0BF9wA
> zUEZ3JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA3NsbW9kBHN0aW1lAzExN
> zQyMDQxNDM-?t=ms&k=Bachelor+degree+electrical+engineering+online&w1=Prin
> ted+circuit+board&w2=Electrical+engineering+software&w3=Electrical+engin
> eering&w4=Electrical+engineering+career&w5=Bachelor+degree+electrical+en
> gineering+online&c=5&s=178&g=2&.sig=a6K9-_5jTKoTcsc8PgMl2w> degree
> electrical engineering online
> Top Scientist
> 10
> <http://us.ard.yahoo.com/SIG=12jhavs3h/M=493064.10322711.10977673.999752
> 7/D=groups/S=1705083291:NC/Y=YAHOO/EXP=1174211343/A=4438957/R=0/SIG=111o
> ctuig/*http://www.bix.com/contest/5406> Greatest Ever
> Share and vote
> on Bix.com!
> Y! Toolbar
> Get
> <http://us.lrd.yahoo.com/_ylc=X3oDMTJvOHBsdnRsBF9TAzk3MzU5NzE0BF9wAzIEZ3
> JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA25jbW9kBHNsawN0b29sYmFyBH
> N0aW1lAzExNzQyMDQxNDM-;_ylg=1/SIG=11c6dvmk9/**http%3A//toolbar.yahoo.com
> /%3F.cpdl=ygrps> it Free!
> easy 1-click access
> to your groups.
> Yahoo! Groups
> Start
> <http://groups.yahoo.com/start;_ylc=X3oDMTJvZHZzZG01BF9TAzk3MzU5NzE0BF9w
> AzMEZ3JwSWQDNDUwNTM2MQRncnBzcElkAzE3MDUwODMyOTEEc2VjA25jbW9kBHNsawNncm91
> cHMyBHN0aW1lAzExNzQyMDQxNDM-> a group
> in 3 easy steps.
> Connect with others.
> <http://geo.yahoo.com/serv?s=97359714/grpId=4505361/grpspId=1705083291/m
> sgId=18207/stime=1174204143/nc1=4438957/nc2=2/nc3=3>
2007-03-23 by juanabba
>screen
> > - someone with experienceglossy ink
> > Hi Kevin
> > method???
> > Juan:
> > onto the pc board and after drying, etched in CuCl. As far as howmany
> > mils you can do, all of the signal traces on the boards that I did are20 in
> > the worst case. I also did a 50 pin centronics connector that has.075"
> > pads with .029 holes on about a 2.3mm x 5mm grid. All the holesin the
> > pads showed and etched well eough to help guide the drill bit.There is
> > a bit of a learning curve on how much to thin the ink, but onceyou get
> > it right, screening the actual boards is really fast. If I quit beinghi Kevin
> > Kevin
> hi Kevin
> Thanks a lot for the comprehensive answer.
> I am trying to get the elements down here ( or finding a local
> replacement ) so I can try out your method.
> The doubt I have at this moment is the ink you use to silk screen the
> cooper after producing your mask.
> You mention "white solvent based glossy ink"), is that the correct
> spec????
> But before I understood you use either
> a> fuji (sericol) quick dry enamel ink
> or
> b> Nazdar ink would be fine to
> can you pls clarify this.??
> Thanks again, you are being extremely helpful
> best regards
> juan
> > Messages
> > Mg--> in this topic (3)<http://groups.yahoo.com/group/Homebrew_PCBs/post;_ylc=X3oDMTJxNGdvbWoxB
> > =18207> Reply (via web post) | Start<http://groups.yahoo.com/group/Homebrew_PCBs/post;_ylc=X3oDMTJlZGRkc3JlB
> > 2xrA250cGMEc3RpbWUDMTE3NDIwNDE0Mw--> a new topic<http://groups.yahoo.com/group/Homebrew_PCBs/messages;_ylc=X3oDMTJlaTZtM
> > Messages
> > HIEc2xrA21zZ3MEc3RpbWUDMTE3NDIwNDE0Mw--> | Files<http://groups.yahoo.com/group/Homebrew_PCBs/files;_ylc=X3oDMTJmcDg3cGtt
> > c2xrA2ZpbGVzBHN0aW1lAzExNzQyMDQxNDM-> | Photos<http://groups.yahoo.com/group/Homebrew_PCBs/photos;_ylc=X3oDMTJlb25iYWZ
> > Ec2xrA3Bob3QEc3RpbWUDMTE3NDIwNDE0Mw--> | Links<http://groups.yahoo.com/group/Homebrew_PCBs/links;_ylc=X3oDMTJmdDY5NGN2
> > c2xrA2xpbmtzBHN0aW1lAzExNzQyMDQxNDM-> | Database<http://groups.yahoo.com/group/Homebrew_PCBs/database;_ylc=X3oDMTJjajZsM
> > HIEc2xrA2RiBHN0aW1lAzExNzQyMDQxNDM-><http://groups.yahoo.com/;_ylc=X3oDMTJkdDg0aWc5BF9TAzk3MzU5NzE0BGdycElkA
> > Photos:
> > jA0MTQz> Yahoo! Groups<http://groups.yahoo.com/group/Homebrew_PCBs/join;_ylc=X3oDMTJmNGV0ZGdpB
> > Change
> > 2xrA3N0bmdzBHN0aW1lAzExNzQyMDQxNDM-> settings via the Web (Yahoo! ID<http://groups.yahoo.com/group/Homebrew_PCBs;_ylc=X3oDMTJkOGdwMnBzBF9TAz
> > required)
> > Visit
> > hwZgRzdGltZQMxMTc0MjA0MTQz> Your Group | Yahoo! Groups<http://groups.yahoo.com/group/Homebrew_PCBs/members;_ylc=X3oDMTJmNmliZX
> > Recent Activity
> > 19
> > New
> > wEc2xrA3ZtYnJzBHN0aW1lAzExNzQyMDQxNDM-> Members<http://groups.yahoo.com/group/Homebrew_PCBs/spnew;_ylc=X3oDMTJmb2hqY3Vz
> > 2
> > New
> > c2xrA3ZwaG90BHN0aW1lAzExNzQyMDQxNDM-> Photos<http://groups.yahoo.com/group/Homebrew_PCBs;_ylc=X3oDMTJlczdua3N0BF9TAz
> > Visit
> > ZnaHAEc3RpbWUDMTE3NDIwNDE0Mw--> Your Group<http://groups.yahoo.com/gads;_ylc=X3oDMTJjMHRtNTI4BF9TAzk3MzU5NzE0BF9wA
> > SPONSORED LINKS
> > * Printed
> > 78&g=2&.sig=mV9PE82hdSlE9-KTSgm01w> circuit board<http://groups.yahoo.com/gads;_ylc=X3oDMTJjcDBnODkwBF9TAzk3MzU5NzE0BF9wA
> > * Electrical
> > ne&c=5&s=178&g=2&.sig=OLCPaWpTecxApgvDRoZHwA> engineering software<http://groups.yahoo.com/gads;_ylc=X3oDMTJjazF1cGQ4BF9TAzk3MzU5NzE0BF9wA
> > * Electrical
> > 178&g=2&.sig=8dKyV5lpIuBKDZx8cuB2nA> engineering<http://groups.yahoo.com/gads;_ylc=X3oDMTJjdGlyN2xtBF9TAzk3MzU5NzE0BF9wA
> > * Electrical
> > &c=5&s=178&g=2&.sig=0iY88q82jkWYGIpFDG2Lxg> engineering career<http://groups.yahoo.com/gads;_ylc=X3oDMTJjdTNobDNzBF9TAzk3MzU5NzE0BF9wA
> > * Bachelor
> > gineering+online&c=5&s=178&g=2&.sig=a6K9-_5jTKoTcsc8PgMl2w> degree<http://us.ard.yahoo.com/SIG=12jhavs3h/M=493064.10322711.10977673.999752
> > Top Scientist
> > 10
> > ctuig/*http://www.bix.com/contest/5406> Greatest Ever<http://us.lrd.yahoo.com/_ylc=X3oDMTJvOHBsdnRsBF9TAzk3MzU5NzE0BF9wAzIEZ3
> > Share and vote
> > on Bix.com!
> > Y! Toolbar
> > Get
> > /%3F.cpdl=ygrps> it Free!<http://groups.yahoo.com/start;_ylc=X3oDMTJvZHZzZG01BF9TAzk3MzU5NzE0BF9w
> > easy 1-click access
> > to your groups.
> > Yahoo! Groups
> > Start
> > cHMyBHN0aW1lAzExNzQyMDQxNDM-> a group<http://geo.yahoo.com/serv?s=97359714/grpId=4505361/grpspId=1705083291/m
> > in 3 easy steps.
2007-03-23 by Kevin Urbom
> > Kevinhi Kevin
> hi Kevin
> spec????
> or
> best regards
> juan
2007-03-24 by qamar islam
>screen
> > Hi Kevin
> > method???
> > Juan:
> > Kevin
> hi Kevin
> spec????
> or
> best regards
> juan
> > Messages
> > Messages
> > Photos:
> > Change
> > required)
> > Visit
> > Recent Activity
> > 19
> > New
> > 2
> > New
> > Visit
> > SPONSORED LINKS
> > * Printed
> > * Electrical
> > * Electrical
> > * Electrical
> > * Bachelor
> > Top Scientist
> > 10
> > Share and vote
> > on Bix.com!
> > Y! Toolbar
> > Get
> > easy 1-click access
> > to your groups.
> > Yahoo! Groups
> > Start
> > in 3 easy steps.
> > sgId=18207/stime=1174204143/nc1=4438957/nc2=2/nc3=3>---------------------------------
