inkjet cdtray mod clearly explained
2007-03-15 by vsmvdd
hello  this is my first post here
i got an RX560 inkjet epson 6 cartridge
multifunction stand alone picture printer
it uses waterproof inks and has cd dvd tray  to allow printing
first you may say a cd isnt a pcb  but  really
the head just detects white labels or a shinny surface!!!
so will print to the middle hole etc
as it never detects it on a pcb job
and maybe  a mod to the software
but i dont think so it can be customised fully
so  read the topic in this link
http://www.edaboard.com/ftopic164174-60.html
youll need to log into to see the pictures and files
and if you could let me know any comments please
it seems i can do a4 to a size of atleast 16cm x16cm so far with
stopper plates into the print tray
im scared to print further than this
for now till i check it out further
but i used extended tray with no problems etc...
anyway a quick trip to the oven  and off to the soft etch
perfect .... ! then printed on the silk in full colour
Re: inkjet cdtray mod clearly explained
2007-03-15 by docstein99
Couldnt find RX560 printer ANYWHERE (ebay, google, yahoo) this appears
to be available outside of the USA)
I did manage to find epsons RX580 printers, which sell for around $130
US.  There is an epson R260 printer which appears to be the same thing
without the "all-in-one" jumbo, that uses the same ink cartridges; that
sells for about $30 - $50
This is awesome work for a cheap printer, and 10 minutes in an oven.
--- In Homebrew_PCBs@yahoogroups.com, "docstein99" <docstein99@...>
appears
that
suffering succotash
that's cheep  this printer cost me £99.99
so four times the price in real money {hihi}
if it has a cd tray i would go and buy one !!!
and you guessed it  its not avalible in the uk
im sure if its basicaly the same chassis it will be as deep
i can find he R265  but not the R260
my modified small tray  does a grand job
im poised to tray a bigger board size
im off to the shop for supplies
and ill post more pictures on edaboard
a few things i noticed
polish the print board really well as per the method on edaboard
is the main thing
i also found warming the board up a little in hot water
before prining makes a better finish it also dried it faster
so for silk screen printing it doesnt smudge on
heavy saturation or colour mode black seems unaffected by smudging i
wonderif black is an different ink ????
this printer has 6 cartridge's
so has a white also
i notice some people using other inks  than original epson
just wondered why ???
ive had no issues at all
using the clara inks that came with the printer?
Thanks for any info
I'm very impressed!  Fortunately, I do have a cnc milling machine so
making a feed tray shouldnt be a problem.  Some more research I found
the lowest price for the printer is $79 at comp-usa.  Reading closer I
found that other price was a mail-in rebate if you bought the printer
and also a camera :(
Re: [Homebrew_PCBs] inkjet cdtray mod clearly explained
2007-03-15 by Stefan Trethan
I'm glad one of my old pictures is making people interested in this
method, maybe i ought to make more recent photos. I think the PCB carrier
with clamp and provisions for doublesided alignment might be useful, even
though i am at the moment not using it to make any PCBs.
Looks like this direct inkjet thing is really starting to take off, great
work!
Especially using different (standard) inks and different printers is
surely going to help things along a lot.
ST
I
well i made a small cd size pcb disk .5mm board
i had mixed results weep !!
becouse i didnt fry the board long enough
over direct heat i see after a re read {i'm too quick you see }
instead i oven baked it
ehhh eehhehehhehe !!
so ive reprited it
thou did rediscover dipping pcb in etchant for a few seconds
cleans the pcb board well
and  makes it a nicer surface for the next print !
this time ill dry it over night then bake it over the ring this time
and report the result tomorrow
the silk screen worked very well  a nice end ,,,
i recon direct application of an art fixer spray
is enought to seel it for good
see the pics one edaboard   link in previous posts
I
well if you make a cad tray design
as ive discovered
some ridges on it are needed for locking
{a small ridge on the far left top corner }
this will work  and will give  A5 {i think }
half an A4 down the middle and more
A4 is 297mm  ive printed upto 160mm deep so far
if i can help let me know and  share your cnc files
i think the camera rebate for me would have sold it for sure !!!!
> as ive discovered
Let me get this printer to prove me some results first.  If I cant get
it to work its going right back to the store.  I will simply cut a pcb
in the shape of a cd-rom and try and print to that.
If it works - I could use a hand with dimensions for a suggested layout
on a tray.  If it works, I may cut one and ship it to you.
> > as ive discovered
get
pcb
layout
ive done this to a cd shaped single sided board
trouble i came to is that it requires ink for mispro
well my one did other inks work
but so far this mispro seems the best choice
so ill order some from usa  i suppose
i cant find it in the uk so far...
ive uploaded the stuff i did today
i realise it would be a trial
and error from the start atleast i found out a few hints
http://uk.geocities.com/vsmvdd/artwork/
i placed in edaboard a design for an electroplater with ramp pwm
technique
if anyone doesnt know how to... thru plate..
