Homebrew_PCBs
Archive for Homebrew_PCBs.
Wish to BUY: Completed direct PCB inject system.
2007-03-09 by James Newton
I have a friend who wishes to purchase a complete, ready to go, direct
to double sided PCB inject resist, soldermask, and
component "silkscreen" system. E.g. a converted Epson printer with a
reliable feed tray for double sided printing, the MISPRO inks pre-
loaded, the cartridge reseter and everything else required.
He is willing to pay $500. Any interest?
Re: Wish to BUY: Completed direct PCB inject system.
2007-03-09 by docstein99
direct
I dont believe that system even works yet, for a SINGLE sided board.
Paying $500 for a tested, operational do-nothing pcb printing machine
is also probably a little light.
2007-03-10 by jcarlosmor
--- In Homebrew_PCBs@yahoogroups.com, "James Newton"
direct
a
With all respects to the people that are going in the direction of
such a system, I think that you are aproaching the PCB making from
the wrong side. I do not know if all of you that post regarding
special inks for printers (like a PCB Santa Claus machine) are really
spending and efforting so much time. If you make a balance between
the different PCB making techniques, I believe that the winner is
(consuming less time and effort, with the added-value of the most
quality finishing) the dry-film methods (ala Thinktink). It is much
simpler to learn to imaging, developing, etc. properly, that to
trying to obtain a "really repetable and reliable" procedure with the
other methods. If I should be waiting for an incredible ink resist,
or for the most simple method in the world (without any effort of
mine) surely I did not had maked any PCBs in all these time.
2007-03-10 by crankorgan
jcarlosmor,
The direct method started out using floor wax. One guy was
telling people it was a done deal. I milled my circuit boards at that
time. There were people who pointed out that milling could not do fine
traces. While they discounted my efforts I sold hundreds of milled
boards for profit. I could produce a 4" X 6" board with lots of traces
for around $7. The same board done at a place in Texas cost me $16.50
each in lots of 30. Then I went retro producing booklets showing how
to perfboard a project and turn that layout into PCBoard artwork.
The direct method now works after years of hard work by a few
people. No matter what method you use you have to stay with it until
you iron out the bugs. All methods give somebody a problem. Just read
the posts.
John
> direct
> a
2007-03-10 by derekhawkins
Around here, affordability is probably the most important factor in
determining which method is chosen. Ease of use is probably next
followed by quality. Compared to TT, direct inkjet (when it gets off
the ground) promises to up the ante in terms of quality and ease of use
with modest increases in operational costs. Hence its popularity.
2007-03-11 by teknochaman
Hi folks,
Guess that I've missed the thread about of C84 direct
printing how-to.
Is that used in place of photoresist ?
I could imagine that after visiting:
www.Rep Rap.org
understood that there was a possible approach to trace
tracks (URL posted here days ago)
Think it is kinda 'conductive paint', isn't it ?
I don't know if RerRap.org will have a good
cost/benefit ratio for PCBs but think it should be
revolutionary when replicating 3D objects.
Furthermore if the gadget will have a price tag of
$400 next year !
By work experience I'm prone to use film r rather than
other ways so I can't imagine how the core C84 direct
printing system works
Hope any reference /link or short explanation about
how direct printing works.
Thanks in advance
Sam
Posted by: "jcarlosmor" jcarlosmor@...
jcarlosmor
Fri Mar 9, 2007 6:56 pm (PST)
--- In Homebrew_PCBs@ yahoogroups. com, "James Newton"
ready to go,direct to double sided PCB inject resist,
soldermask, and component "silkscreen" system. E.g. a
converted Epson printer with a reliable feed tray for
double sided printing, the MISPRO inks pre-loaded, the
direction of such a system, I think that you are
aproaching the PCB making from the wrong side.
machine) are really spending and efforting so much
time. If you make a balance between the different PCB
of the most quality finishing) the dry-film methods
(ala Thinktink).
It is much simpler to learn to imaging, developing,
etc. properly, that to trying to obtain a "really
repetable and reliable" procedure with the other
resist, or for the most simple method in the world
(without any effort of mine) surely I did not had
Preguntá. Respondé. Descubrí.
Todo lo que querías saber, y lo que ni imaginabas,
está en Yahoo! Respuestas (Beta).
¡Probalo ya!
http://www.yahoo.com.ar/respuestas
2007-03-12 by teknochaman
Hi everyone,
Want to share this link with hints about using the
proven method of film & photoresist :
www.pico-systems.com/PCBs.html
Better yet there can be found a project IMHO for
serious DIYers: a homemade photoplotter !
http://www.pico-systems.com/photoplot.html
Hope the above helps.
Samuel
¡Probalo ya!
