green TRF, toner transfer system 2007-03-06 by k6txd Hello Group Has anyone used the toner transfer system from directetch.com for making pc boards?
Re: [Homebrew_PCBs] green TRF, toner transfer system 2007-03-06 by DJ Delorie "k6txd" <k6txd@...> writes: > Has anyone used the toner transfer system from directetch.com > for making pc boards? I use that. The manufacturer is Pulsar, you might get more search hits with that. Do you have specific questions about it? A small TT board I did: http://www.delorie.com/pcb/r8c-1b-adapter/ Brass etching with TT (0.5mm pitch): http://www.delorie.com/pcb/brass/ Mounting an 01005 capacitor (0.4mm pitch IC, 7.8mil traces): http://www.delorie.com/pcb/first.html
