Homebrew_PCBs
Index last updated: 2026-03-31 01:30 UTC
Circle
Circle
2007-03-04 by alan00463
Has anybody ever cut, or tried to cut, a PCB
in the form of a circle? If so, how?
Re: [Homebrew_PCBs] Circle
2007-03-04 by Cristian
I can do that on my CNC milling machine.
Cristian
2007-03-05 by JanRwl@AOL.COM
In a message dated 3/4/2007 12:38:27 P.M. Central Standard Time,
alan00463@... writes:
Has anybody ever cut, or tried to cut, a PCB in the form of a circle? If so,
how?<<
Use a plywood fixture on a bandsaw. Or, if you are very skilled, make a
fixture for your router, using a CARBIDE-edged bit!
Or, if you are a lathe operator, first draw the circle with a Sharpie pen on
a sheet of FR-4 (or whatever), then manually bandsaw "outside" of the marked
circle (leaving 1.5-3 mm waste). Then fasten the "blank" to a
plywood-covered face-plate on the lathe with double-stick tape, and fasten a disk of
plywood about the dia. of your finished PCB circle over the blank, holding it in
place with a live center in the tail-stock, cranked up nice and hard. Then,
TURN the disk to final dim (and sand it!), being VERY careful. Don't breathe
that nasty glass/epoxy dust! Jan Rowland
<BR><BR><BR>**************************************<BR> AOL now offers free
email to everyone. Find out more about what's free from AOL at
http://www.aol.com
Re: Circle
2007-03-05 by Chris Horne
That was one of the main reasons for me converting an X1 micro mill to
CNC.
I have a proxxon clamped to the head so I can drill the boards and
then cut the outside shape without any intervention.
Before the CNC Mill, and depending on size.. I either used hole-saws
mounted in a pillar drill, cut them by hand on a hegner saw then disc
sanded them, or clamped them between an MDF faceplate and a rubber
block on the lathe and turned them.
Trust me.. if you do more than a few, CNC is the way to go.. and you
can cut any shape you like !
Chris
2007-03-05 by Stefan Trethan
> pen on
> marked
> fasten a disk of
> holding it in
> Then,
> breathe
If not many need to be done i suppose approximating the shape with any
type of shear or saw will do, followed by sanding to the final dimensions.
Dont breathe the dust.
ST
