Check this out !!
Check this out !!
2007-02-23 by sam_jfs
Do you know this ?
http://www.jimdunlop.com/index.php?page=products/pip&id=259&pmh=products/p_and_e_detail
I�ve received one to repair and was quite surprised ! These graphics
are printed directly, the box it�s aluminum !
Yesterday i went into a screen printing company to take care of some
business and i have showed it to them, they have confirmed that it�s
digitally printed with one 3 or 4 axis printer.
We are having a bad time to find a good ink to print directly to
copper and these companies print high quality graphics directly in
aluminum boxes.
Any idea of which ink it is ?
Re: [Homebrew_PCBs] Check this out !!
2007-02-24 by otc_friend
There is a difference between homebrew and multi-million dollar business.
Epson is able to *print*a  20-layer pcb with their inkjet technology.
If you spent enough money, they print it where you want.
If you print on aluminium, you probably actual print on the micrometer thick aluminiumoxide layer.
- Henry
www.ehydra.dyndns.info
-----Urspr\ufffdngliche Nachricht-----
Von: "sam_jfs" <Samuel_joao@...>
An: <Homebrew_PCBs@yahoogroups.com>
Gesendet: Freitag, 23. Februar 2007 20:59
Betreff: [Homebrew_PCBs] Check this out !!
Do you know this ?
I\ufffdve received one to repair and was quite surprised ! These graphics
are printed directly, the box it\ufffds aluminum !
business and i have showed it to them, they have confirmed that it\ufffds
aluminum boxes.
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
If Files or Photos are running short of space, post them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Yahoo! Groups - Join or create groups, clubs, forums & communities. Links
2007-02-24 by William Nelson
Is this ink or paint? 4 axis painting? I never gave it any thought until now. How is the fine line
resolution on that box? You need pretty good resolution to do PCBs.
Re: Check this out !!
2007-02-24 by sam_jfs
Good resolution but no enough to make pcb´s. The important here it´s
the ink or paint used in that process and the machine that make this job.
It´s a bit logical isn´t it, but i didn´t though on that before! If
there is 3 or 4 axis CNC machines, why not printers ?
Re: [Homebrew_PCBs] Re: Check this out !!
2007-02-24 by Stefan Trethan
On Sat, 24 Feb 2007 18:20:26 +0100, sam_jfs <Samuel_joao@...>
wrote:
> Good resolution but no enough to make pcb�s. The important here it�s
> It�s a bit logical isn�t it, but i didn�t though on that before! If
I did not doubt they exist, but the question is what use is it for us? We
already knew there were flatbed printers to print signs and stuff, but
what use are they to us without winning the lottery first?
I don't think the same inks would work in cheap household printers.
ST
2007-02-24 by Steve
business.
More likely, the box is painted white with some conventional method,
then inkjet printed. But you barely need 300dpi to print something
like that.
I would not be surprised if they use HP thermal inkjet print heads.
us? We
> ST
Just curiosity...
About flatbed printers, or XY printers, i saw some years ago one of my
customers printing in PVC, it was some electrical components and he
used that printer to label them. He used some special Rottring black
pens to do it.
It´s not so hard to modify a XY printer and they are quite cheap (
used ), the problem is, finding the right ink to do this job ...
On Sat, 24 Feb 2007 22:35:14 +0100, sam_jfs <Samuel_joao@...>
wrote:
> Just curiosity...
> pens to do it.
> It�s not so hard to modify a XY printer and they are quite cheap (
Most of them seem to use UV cure ink.
There was even a webpage about an italian company selling small flatbed
inkjets specifically for PCB printing. I have not heard anything about
them since. Another italian company called Durst makes printers for
printing on ceramic tiles, they manufacture here in Austria.
Those flatbed printers also sometimes have white ink, which would be nice
for the people insisting on white component legend, but i don't think
those UV inks would work in epson heads (or any other consumer printer). I
may be wrong though and you are welcome to try, if you can get the ink,
which seems especially tricky.
ST
2007-02-25 by Brian Pitt
hobout squishing these two together
http://www.hackaday.com/2006/10/08/inker-the-hand-inkjet/
http://www.fabathome.org/wiki/index.php?title=Main_Page
Brian
2007-02-25 by Thomas
> It\ufffds not so hard to modify a XY printer and they are quite cheap (
>Brian
sniffing around here
http://www.xpress3d.com/Materials.aspx?sh=1
I dont see any info about the viscosity of these resins in the data sheets
but if they would pass through a printhead ok or be thinned down somehow and
then cured with an IR light source ... any thoughts
Thomas
> and then cured with an IR light source ... any thoughts
> Thomas
Ooops found it ... crazy day !!!
I was looking at the Somos 11120 & 14120 data sheet and it indicates 260 &
240 cps, how does this compare with the Durabrite / Mispro inks for
viscosity?
and I should have said a UV light source.
and some info here about the technology
http://www.xpress3d.com/Processes.aspx?sh=1
Thomas
2007-02-25 by mycroft2152
data sheets
somehow
> > Thomas
indicates 260 &
> viscosity?
> Thomas
data sheets
somehow
> > Thomas
indicates 260 &
> viscosity?
> Thomas
"Poise" is a unit of measure for viscosity -- centipoise is 1/100 of
a POISE. Water is 1  and olive oil is approxiamately 100.
Here's a link:
http://www.sizes.com/units/poise.htm
UV curable inks tend te be very thick, high solids liquids. They
reduce the VOC's (Volatile Organic Compound) released to the
atmsophere.
One way to reduce the viscosoity is by heating.
Most likely too thick to run through a home printer printhead.
Myc
data sheets
somehow
> > Thomas
indicates 260 &
> viscosity?
> Thomas
Ok, let's try it again :)
"Poise" is the unit of measure for viscosity. Centipoise = 1/100 of a
poise.
Water is 1, Olive oil is 100.
Here is a link:  http://www.sizes.com/units/poise.htm
UV curable inks are thick, high solids liquids. The main benefit is
that they have very little solvents, and therefore have low VOC's.
Volatile Organic compounds are not enviromently friendly and are
monitored by the government.
The arer probably too thick to run through a home inkjet printer.
Myc
data sheets
somehow
> > Thomas
indicates 260 &
> viscosity?
> Thomas
Re: [Homebrew_PCBs] Re: Viscosity (wascheckitout)
2007-02-25 by William Nelson
Notice on page 4 the vicosities of the inkjet inks, very low compared to the materials at
Expess3D, almost the same as water.
 But this is all encouraging for alternates to regular ink. Now does anybody have the time to
reseach all of these print head makers and all of the ink substitutes and try them out? Surely
somebody has a few extra years laying around.
Down at the bottom on page 8 is a lot of good reading if you can find them. It would appear that
the "Big Boys" are hard at work finding just the right resist we need. All we have to do is get
them to share.
