drill before removing toner if you use TT
2007-02-12 by Stefan Trethan
This may seem obvious to many, but it is better to leave the toner on for
drilling by hand, since the black toner gives a better contrast than the
copper, at least with my lighting. I thought i mention it just in case
someone else has never tried it that way.
ST
Re: [Homebrew_PCBs] drill before removing toner if you use TT
2007-02-12 by Martin Klingensmith
It is interesting that you mention this because yesterday I tried
drilling before removing the toner. It's all really a personal
preference I believe. I think I can see the drill bit better when
contrasted on the bright copper.
Martin K
> ST
On Mon, 12 Feb 2007 19:37:16 +0100, Martin Klingensmith
> Martin K
i think it depends on the light, where it is and what intensity and color.
ST
2007-02-13 by David McNab
Too right!
As for myself, I always drill with a drill press stand, an 18 watt
mini-fluoro bulb close-up, and a 4x head magnifier. Pretty hard to
confuse the drill bit with the copper in *that* environment :P
Can't wait, though, for my mech eng to get back from his motorbike
touring and build the transport for my CNC tool. The CNC controller
won't give a damn what kind of light is present :)
Cheers
David
2007-02-13 by Stefan Trethan
On Tue, 13 Feb 2007 01:35:19 +0100, David McNab <rebirth@...>
wrote:
> Too right!
I dunno, i use a 10W car light shining down from the drill, from the side
and from behind. It makes the copper glare a bit and after a while my eyes
get tired from it and it looks too much like the epoxy around it. Not so
that i wouldn't see it but enough to stress my eyes much more than the
black.
Also, if i don't hit the exact center, the drill nicks the toner exposing
a bit of copper, so i can correct the position slightly to get it on
target.
ST
Re: drill before removing toner if you use TT
2007-02-13 by derekhawkins
That's the least IMO. It was cleaning the bit when necessary and
clearing the dust sufficiently away from the next nearby pad to be
drilled that got on my nerves. So much so that I devised an air
solenoid setup to clean the bit and blow away the dust while holes were
being drilled.
The same foot switch that operated the drill would operate the solenoid
and a shop Vac. The dust would be blown into a "cowl" attached to the
Vac. There was the sound of the drill, compressed air and the sound of
the Vac for each hole drilled...One unholy racket. But it was an
efficient setup otherwise.
<stefan_trethan@...> wrote:
Re: [Homebrew_PCBs] Re: drill before removing toner if you use TT
> being drilled.
I pointed the nozzle of the vac towards the drill, and made a u-shaped
baffle that i can slip on from the front, that goes all the way around the
drill. This gets all the swerf build-up on the drill, and most of the dust
on the board (enough so that it doesn't obstruct the next pads and get
into the air). A small amount of dust still seems to stick to the board,
could probably be reduced further with a better suction hood or the vac
cranked up higher.
The front of the suction hood is easily removeable so i can change drills.
It's loud and i hate the noise, but i hope to get a quieter vac some day.
Still much better than killing yourself with glassfiber dust.
ST
