finding ultra-thin copper sheet?
2007-02-10 by David McNab
Does anyone know how to get hold of blank PCB material, similar to the
usual 1.6mm thick copper-clad stuff, but ultra ultra thin?
I'm thinking about the recent threads about hacking inkjets to print
onto PCB via the CD tray.
The idea is if that the copper-coated medium is thin enough, it will be
able to pass through any unmodified inkjet. The other good thing is that
inkjets (as opposed to lasers) tend to have a much straighter paper
path.
Digikey only seems to sell 3/4" copper tape - way to narrow for most
boards.
Any ideas?
Cheers
David
Re: [Homebrew_PCBs] finding ultra-thin copper sheet?
2007-02-10 by Leon
Sent: Saturday, February 10, 2007 9:09 PM
Subject: [Homebrew_PCBs] finding ultra-thin copper sheet?
> Hi,
> path.
> boards.
> Any ideas?
How thin? PCB stock for multilayer boards can be quite thin, you might be
able to get some free off-cuts if you have a PCB manufacturer near you.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
> boards.
Oops - spoke too soon - Digikey has heaps: 473-1012-ND is 6x9 1/64"
single sided, they have plenty of similar under the search 'pcb copper
clad'.
Cheers
David
2007-02-10 by keith
On Saturday 10 February 2007 16:09, David McNab wrote:
> Hi,
> path.
> boards.
> Any ideas?
>snip<
How about SS 0.016" or DS 0.021" ?
If so try:
http://www.goldmine-elec-products.com/products.asp?dept=1034
They also have some carbide drill bits.
Keith Bowers - Thomasville, NC
2007-02-11 by Herbert E. Plett
try this
http://cgi.ebay.ca/Copper-Clad-FR4-PCB-Laminate-Material-Thin-SS-or-DS_W0QQitemZ140083554361QQihZ004QQcategoryZ4660QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
was mentioned before in this list
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/features_spam.html
2007-02-14 by otc_friend
I have here 0.125mm thick copper foil single-side coated with epoxy.
The Epson Color 640 accepts it in "thick mode" switch.
If you need some, drop me a line.
regards -
Henry
www.ehydra.dyndns.info
-----Urspr\ufffdngliche Nachricht-----
Von: "David McNab" <rebirth@...>
An: <Homebrew_PCBs@yahoogroups.com>
Gesendet: Samstag, 10. Februar 2007 22:09
Betreff: [Homebrew_PCBs] finding ultra-thin copper sheet?
| Hi,
| path.
| boards.
| Any ideas?
| Cheers
| David
| Be sure to visit the group home and check for new Links, Files, and Photos:
| http://groups.yahoo.com/group/Homebrew_PCBs
| If Files or Photos are running short of space, post them here:
| http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
| Yahoo! Groups Links
2007-02-15 by David McNab
> regards -
> Henry
Hi Henry,
Thanks for letting me know about that. I'm full of questions:
- are you a dealer?
- if not, who is your supplier?
- what sizes does it come in?
- is it flexible enough to tolerate the very curved printing path
  of an HP2550L Color Laserjet or a Brother 1670N mono laser?
- what are the retail prices?
- is it available in small retail quantities, or only bulk?
Cheers
David
> -----Ursprüngliche Nachricht-----
> | Hi,
> the
> be
> that
> | path.
> | boards.
> | Any ideas?
> | Cheers
> | David
> Photos:
> | Yahoo! Groups Links
2007-02-16 by otc_friend
Hi David -
>- are you a dealer?
At the moment, maybe ;-)
It was for another project left over.
I can ask the supplier for bigger sizes. At the moment I have 20 x 15 cm parts. One inch is 25.4 mm or 2.54 cm.
Probably it comes on roll.
I guess: if I etch the copper away, the back coating will be fully transparent. Great to make double-sided pcb. Just place front and
back beside, print and etch, fold front and back side (with markers). Laminate it for greater stability or leave the two foils
spray-glued as a elastic pcb.
(I removed a little copper mechanical and can now see thru like glass)
I don't know of your specific printers. It goes thru my old TI microlaser 600 w/o problems.
You must coat copper if you want to print on it with a laser. Electrostatic problem otherwise.
Some printer may work w/o coating, I heart.
If there is greater demand, I will look for supply.
You can have a single sheet. Of course, I'm located in Germany. Don't know postage prices to you.
At the moment I just printed a sample. There is a need for greater test series...
Hope that helps a little.
- Henry
Re: finding ultra-thin copper sheet?
2007-02-16 by Bert
--- In Homebrew_PCBs@yahoogroups.com, David McNab <rebirth@...> wrote:
> Hi,
I've seen copper sheet as thin as 010" and .005"  ( .127mm). DigiKey
sells it. They used to stock it but it looks like special order now
(just means there will be a delay in receiving it).
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=73577&Row=767389&Site=US
It's still FR-4 though so I'm not sure how flexible it is. Makes me
wish I still had my old TI laser printer. It had 2 output slots with a
lever to sent the paper out the top or out the back. The back slot was
limited bending of the paper for haevy card stock. Bet I could have
sent this through it.
Other idea I had, I don't know where to find the palin stock but my
company does some boards on polyimide (flex boards). It's not much
different then heavy paper and bends pretty nicely. If you can find
the stuff plain, it might work.
Bert
Re: [Homebrew_PCBs] Re: finding ultra-thin copper sheet?
2007-02-16 by Stefan Trethan
> Bert
Other than the tektronix phaser wax printer, is there even any definite
positive result with direct laser printing? I can think of many reasons
why it may not work, and don't remember any reports of success? Have i
missed or forgotten something?
I mean it's well worth a try, but when i tried with aluminum foil it
looked very bad, with my printer.
ST
Can you provide the digikey number? Your link is dead.
regards -
Henry
Von: "Bert" <bertd.geo@...>
Gesendet: Freitag, 16. Februar 2007 16:22
Betreff: [Homebrew_PCBs] Re: finding ultra-thin copper sheet?
| > Hi,
| Bert
| Yahoo! Groups Links
2007-02-16 by James McGee
Not ultra but pretty thin...I found 1/32 at a descent price, well its
26.88 USD.... But thats a 24"X36" Dont think it will pass through an
un-modified printer but maybe slightly modified (so it dosent have to
make the curved turn from the paper tray) If I could find some
sutible ink for this old lexmark Z23 I would try it myself...
J
> Hi,
will be
that
> path.
> boards.
> Any ideas?
> Cheers
> David
2007-02-17 by David McNab
On Fri, 2007-02-16 at 12:05 +0100, otc_friend wrote:
> Hi David -
> epoxy.
> >- are you a dealer?
If myself or anyone here gets success running the stuff through a laser,
you could well start getting orders :)
That's great for unmodified (reasonably straight paper path) inkjets,
especially since they're usually very good with arbitrary stock sizes.
Quite possibly could also mount on carrier sheet to run through a laser.
What should I coat the copper with?
Positive test results would surely generate some demand.
One or two sheets between the size of a credit card and a postcard would
be great. I'm in New Zealand. I could give you some $$ and send you my
address if you send me your paypal email address and a postage cost
estimate off-list.
> test series...
It would be a huge boost to be able to circumvent the thermal toner
transfer process, for many reasons such as:
 - eliminate artwork distortion
 - eliminate transfer failure areas
 - speed up the whole deal
 - allow for vastly finer artwork
It would give the advantages of photographic transfer, but without the
extra cost of photoresist boards (or photoresist spray), developer, uv
lamp etc.
Very, very interesting
Cheers
David
2007-02-17 by Z P
I am in Australia.
Local manufacturers of PCBs use mylar sheet clad in copper on one side only to manufacture flexible circuit boards and mobile antenna arrays which get wrapped aorund a suitable support.
I had been able to obtain offcuts from the local manufacturer, but i am sure they would supply the product if offered financial recompense.
So.. do call on your local manufacturers or laminate suppliers and ask for copper clad mylar. It is like a transparency sheet with copper on one side.
It will withstand light soldering and desoldering duty and makes a wonderful ground plane around assemblies which need shielding.
James McGee <ace@...> wrote:                                  Not ultra but pretty thin...I found 1/32 at a descent price, well its
 J
 > Hi,
 will be
 that
 > path.
 > boards.
 > Any ideas?
 > Cheers
 > David
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
2007-02-17 by Lez
looked good in my hp4l, but board would not go through, and when I
tried to convert to flat path I gave up it was too complicated for me
with all those gears.
It will however take about 3 or 4 sheets of standard a4 at a time
without a jam, so I think if I could get copper foil then that would
work, then epoxy glue it to some board before etching
For the moment I'm happy with the uniball paint pen (px203 white) in a
plotter, but useless for small tracks etc due to pen tip width.
2007-02-18 by robwell
1 oz sheet (.00135" thick) in a 12" x 25" for $3.95:
http://www.onlinemetals.com/merchant.cfm?id=129&step=2
You can probably ask them to cut it into 11" x 25"
1 oz is pretty thin so you might try 3oz, which is closer to paper
thickness (.00405). The downside is it is quite a bit more expensive
3 oz sheet (.00405 thick) in 12" x 25" for 14.15
I have no affiliation with these folks - just a happy customer.
Cheers,
Bob Welland
2007-02-18 by William Nelson
What do you glue it to and with what type of glue? The glues used in copper clad board are heat
and expansion tolerant this may be hard to find for use home users. The glue actually melts before
the solder so the copper can expand. This seems to be a hard thing  to do when there is already
thin PCB stock out there. There must be a lot of it out there as PCB manufacturers make millions
of multilayer boards every day. Not easy to find for some reason. I did find the Injectorall link
for a start. http://www.injectorall.com/index.htm
There has to be more sources than that. You can search the world now and it's still hard to find
what you want. Go figure.
2007-02-19 by Bert
> regards -
> Henry
Oh shoot, sorry about that.
Uncoated, Double sided  0.010":
    3x4.5  PC60
    4x6    PC61
    6x6    PC61-S
    6x9    PC62
   12x12   PC62-T
   12x18   PC63
Double sided  0.005":
    3x4.5  PC90
    4x6    PC91
    6x6    PC91-S
    6x9    PC92
   12x12   PC92-T
   12x18   PC93
Boards are made by Injectorall, looks like they sell direct as well.
http://www.injectorall.com/FR4uncoatedboards.htm
2007-02-19 by otc_friend
Thank you!
- Henry
Gesendet: Montag, 19. Februar 2007 15:24
| > regards -
| > Henry
|     3x4.5  PC60
|     4x6    PC61
|     6x6    PC61-S
|     6x9    PC62
|    12x12   PC62-T
|    12x18   PC63
|     3x4.5  PC90
|     4x6    PC91
|     6x6    PC91-S
|     6x9    PC92
|    12x12   PC92-T
|    12x18   PC93
| Yahoo! Groups Links
| > Hi David -
| > epoxy.
| > >- are you a dealer?
Yeah. My TI microlaser can load it.
Just a support paper with a glue strip to hold the copper sheet.
That is a really interesting question. I don't managed it until yet but not worked deep into.
I have a couple of ideas to test. If I can find free time...
| estimate off-list.
I sent you a pm.
| > test series...
The etch process will remain. And etch resistant removing.
| lamp etc.
That's why I'm interested. You can work on your project on the weekend or in a couple of hours. There is not need to wait for
delivery.
- Henry
2007-02-19 by mycroft2152
wrote:
If your laser will run card stcok, then most likely the thin flex pcb
material woll make it through the laser on a carrier sheet. There are
still other problems, some lasers add a fuser oil, which can prevent
adhesiosn. The copper has a large thermal mass as compared to paper.
The brand of toner will also make a huge difference.
If you scratch the drum with the foil, you're up the creek and have
to replace the drum.
I speak form experience. my old Laserjet IIIP+ worked fair, after but
changiong the toner cartridge, ti didn't work at all, My Samsung
ML2010 never adhered the toner to the pcb.
It was all worth trying, but there are some dangers. It is not going
to be that simple.
Myc
> | > Hi David -
> | > epoxy.
> | > >- are you a dealer?
laser,
20 x 15
inkjets,
sizes.
laser.
path
Don't
postcard would
you my
cost
> | estimate off-list.
> I sent you a pm.
greater
> | > test series...
toner
without the
developer, uv
> | lamp etc.
> delivery.
> - Henry
2007-03-21 by Bert
--- In Homebrew_PCBs@yahoogroups.com, "Bert" <bertd.geo@...> wrote:
> --- In Homebrew_PCBs@yahoogroups.com, David McNab <rebirth@> wrote:
> > Hi,
I found the ultimate thin copper sheet.  It's limmited to 1" wide
though. To be able to test the potential of copper sheet, I used 1"
wide copper tape.
I layed out my board to be only 1" wide (no length limit, mine was 3")
and then printed it on a test sheet of paper.
I then placed a sheet of laser transparency over the sheet and placed
 a strip of copper tape directly over the image and pressed it down tight.
I then ran the transparency with Cu tape through the printer (oriented
the same way as the test sheet was.
After this, a piece of polyimide tape would be placed over the back
for extra support and Viola ... instant flex circuit.
This was a perfect carrier for printing directly on the copper.
Sadly, as was expected (by ST I think), the copper does not pick up
enough toner. In areas where it did pick it up, the board looks great
but the overall print is spotty. I have a few other things to try but
doesn't look promissing in Lasers.
It make work in an inkjet except I'm not sure how well the carrier
sheet will survive the baking process. If someone tries it, let me know.
I'll post pictures of my results as soon as I take some.
Bert
2007-03-22 by Brian Pitt
> though.
these guys have 2" and 8" wide tape 4mil thick
http://www.warmoth.com/catalog/product_info.php?products_id=23040&osCsid=tkbe06t5vun338odk6411kput3
or here
http://www.stewmac.com/shop/Electronics,_pickups/Supplies:_Shielding/Conductive_Copper_Tape.html
and 3.5"x24"
http://www.guitarcenter.com/shop/product/buy_dimarzio_copper_shielding_tape?full_sku=364741%2e795&src=4WFRWXX
Brian
"Nemo me impune lacesset"
