Re: No Press N Peel, a Great alternative
2007-01-05 by teknochaman
Hello Gary and Chris,
Sorry for this if should be a dummy question:
Did you you mean that NO intermediate scanning+ toner
printing is done before doing transfer from magazine
image ?
Hope your explanations as didn't fully understood it,
probably as never saw a Maplin printed catalogue.
Greets,
Samuel
Re: No Press N Peel, a Great alturnative
Posted by: "lcdpublishing" lcdpublishing@...
lcdpublishing
Wed Jan 3, 2007 2:38 pm (PST)
Gary,
I too have tried various catalogs and magazines -
often with good
success. The only "Catch" I have experienced is when
the ink on the page transfers to the PCB along with
the toner. Turns out that the
ink is also etch resistant which of course creates
some problems.
Now if we could only convince the magazine and/or
catalog printers
to leave some blank pages for us, that would be super
duper!
Chris
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam \ufffdgratis!
\ufffdAbr\ufffd tu cuenta ya! - http://correo.yahoo.com.ar
Re: [Homebrew_PCBs] Re: No Press N Peel, a Great alternative
2007-01-06 by Gary Hoyles
All i meant was instead of using press n peel paper i use a sheet of paper from the maplin electronics catalogue. Its very thin and the toner does not stick to it after you have ironed it onto the board. it just peels off. No different to the way press n peel works.
still as with press n peel i still get problems. like today when i have tried to do a board three times now and always there is some little error that keeps bugging me.
I'm looking now for a better way to do these boards. press n peel method is hard work to get right. thinking of getting kitted out for UV now.
Gary
----- Original Message ----
Sent: Friday, January 5, 2007 8:34:37 PM
Subject: [Homebrew_PCBs] Re: No Press N Peel, a Great alternative
image ?
Greets,
Samuel
Posted by: "lcdpublishing" lcdpublishing@ yahoo.com
lcdpublishing
Gary,
often with good
some problems.
catalog printers
duper!
Chris
____________ _________ _________ _________ _________ __
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
¡Abrí tu cuenta ya! - http://correo. yahoo.com. ar
Do You Yahoo!?
http://mail.yahoo.com
2007-01-06 by Stefan Trethan
On Sat, 06 Jan 2007 02:36:47 +0100, Gary Hoyles <dimlow_uk@...>
> Gary
If you get almost good results with hand ironing you will get perfect
results once you convert an old fuser or buy a laminator.
ST
2007-01-06 by Leon
Sent: Saturday, January 06, 2007 1:36 AM
Subject: Re: [Homebrew_PCBs] Re: No Press N Peel, a Great alternative
I much prefer UV. It didn't cost me much to build a simple UV exposure
unit - something like 25 GBP. It looks very crude but it does the job. I'll
upload a photo of it, it'll give me a chance to use the Nikon D80 camera I
gave myself for Christmas.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Suzuki SV1000S motorcycle
leon355@...
2007-01-07 by teknochaman
Hello Stefan and All,
I had think about a fuser but never imagined a how-to
as DIY project details.
Are you thinking in a fuser as it's carried by
laserprinters or copiers ?
Which is the average size for a laminator ?
BTW , does it exist any cheapo brand/link for this
stuff ?
Auf Wiedersehen und Greets,
Samuel
Posted by: "Stefan Trethan" stefan_trethan@...
stefan_trethan
Sat Jan 6, 2007 12:43 am (PST)
<dimlow_uk@yahoo. co.uk>
i use a sheet of
the board. it just
works.
is some little
press n peel method
> Gary
will get perfect
laminator.
ST
Correo Yahoo!
2007-01-07 by Stefan Trethan
On Sun, 07 Jan 2007 02:13:48 +0100, teknochaman <teknochaman@...>
> stuff ?
> Samuel
Yes, like in laserprinters and copiers. You need to add a motor (i
recommend the ones normally used to rotate chickens on grill stakes, very
cheap and the chickens will thank you if you don't eat them). But any
geared motor will do (cheap battery screwdriver, RC serve etc.). You'll
also need to add a simple temp. control circuit (The fuser already has a
thermistor which you can use).
The advantage of a laminator is that it's ready made, but it may be too
cool and will run too fast, so you need more than one pass through, or use
another motor.
You might have to modify either so thicker material will pass, but the
fuser i took from a copier was just fine in that regard.
In my experience (and many have said so) it makes all the difference
compared to an iron.
ST
2007-01-08 by Gary Hoyles
Yes, let me see the photo's
What puts me off doing it is all the chemicals. But first i will
check out the laminator idea.
A question for anyone using a laminator. I see that most people that
are using a laminator are using some sort of gloss inkjet paper and
not press n peel, how good are the results with press n peel ?
Also what paper are the guys in the UK using, i have found that
 staples have a similar paper to the Basic injet gloss that i have
 seen in some us sites, is this the same paper ?
Gary
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: Gary Hoyles
 alternative
 of paper
 does not
 off. No
 have
 error
 method is
 exposure
 job. I'll
 camera I
> Leon
> Leon Heller
> leon355@...
2007-01-09 by Gary Hoyles
I'm guessing that the better results come from the higher temp you
get in a laminator or the fuser ?
Gary
> > stuff ?
> > Samuel
stakes, very
any
You'll
has a
too
or use
> another motor.
difference
> ST
2007-01-09 by DJ Delorie
"Gary Hoyles" <dimlow_uk@...> writes:
In my case, the iron was either too cool or too hot, with either too
much pressure or too little.  The laminator provided consistency.
2007-01-09 by Stefan Trethan
On Tue, 09 Jan 2007 01:00:17 +0100, Gary Hoyles <dimlow_uk@...>
> Gary
Also from the even pressure, and repeatability.
ST
