What can be expected from isolation milling?
2006-12-30 by lcdpublishing
Hi guys,
I am oh-so close to running some real boards on my CNC mill.  Having
never done isolation milling I am not sure of what the process is, or
is not capable of.
I bought a couple carbide 'V' cutters and will be giving it a try this
comming week.  I suspect the 'V' type cutters would be better than
trying to use a .010" or .020" diameter endmill.
Right now, with toner transfer, I can get fairly reliable results with
traces down to .012".  Anyone have any idea what can be done with
isolation milling?  Any suggestions, comments, advice, warnings, etc.
would all be appreciated!
Chris
Re: What can be expected from isolation milling?
2006-12-30 by crankorgan
The best site is done by Scott Holmes.(Grab the outlines_gcode.ULP
on that page) See first link. He explains the process very well. You
draw your layout in Eagle and then run the Outlines_Gcode.ULP to get
the Gcode. Make sure you don't make you drawing upside down. When you
are drawing in Eagle you are looking down at the top of the board not
the back.
http://mynock.dhs.org/pcbmilling/
http://www.luberth.com/cstep/PCBtest.htm
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
<lcdpublishing@...> wrote:
> Hi guys,
> is not capable of.
> Chris
2006-12-30 by jme87be
what do you think of this demo board from LPKF, 0.1 mils !! 5 tracks
between 2 IC pins !!
http://www.lpkf.com/images/1/713-muster-einseitige-leiterplatte.jpg
Regards
Jacques
> Hi guys,
Having
or
> is not capable of.
this
with
etc.
> Chris
Jacques, that looks fantastic to me!!!!  What type and size of
cutter did you use to make that board?
Chris
--- In Homebrew_PCBs@yahoogroups.com, "jme87be"
<jacques.meunier@...> wrote:
> Hi,
tracks
> Regards
> Jacques
> <lcdpublishing@> wrote:
> > Hi guys,
> Having
is,
> or
> > is not capable of.
try
> this
than
results
> with
with
> etc.
> > Chris
Chris,
it is a DEMO board from a manufacturer of very professional milling
machines. It is only a dream for me !!
You may download a very instructive PDF there :
http://www.lpkf.com/others/1/1026-product-catalog.pdf
Jacques
> Thanks
> Chris
> <jacques.meunier@> wrote:
> > Hi,
> tracks
> > Regards
> > Jacques
