Homebrew_PCBs
Inkjet Transparency Material
2006-12-19 by scratch_6057
This is basically just an FYI post, I know it reads like an
advertisement but I have NO connection with the company except being
a happy customer.
If you are one of those people who use Photosensitive boards to
produce your PCBs, and you are using the 3M, Epson or other Inkjet
Transparency media to make films, (positive / negative).
You may want to take a look at this
( http://screenprinters.net/product_group.php?gid=inkjetfilm ).
I have used this material with an old Epson Stylus 1160 and obtained
what I consider to be exceptional results compared to the other films
I have tried (also used with Stylus 660, results were not as good but
were useable). Unlike other films I have used which have a coating to
provide a tooth for the ink to bind to but take quite some time for
the ink to dry and allow for ink "pooling" causing non uniformity in
coverage, the coating on the film (above link) absorbs the ink almost
immediately. The coating acts as if it is some sort of gelatin which
soaks in the ink as it is laid onto the material.
My printer settings have been, Highest Density, Glossy Photo Paper,
High Speed = OFF, & whatever else I would normally use for a FINAL
Photo Quality Print.
Re: [Homebrew_PCBs] Inkjet Transparency Material
2006-12-19 by Russell Shaw
> a happy customer.
Is this the non-waterproof film?
The gelatine coated stuff is what the genuine epson inkjet film was anyway.
The HP, canon, and others all used that cruddy sand-paper film.
Been doing this easy stuff for 5+ years.
2006-12-19 by Leon Heller
Sent: Tuesday, December 19, 2006 2:20 PM
Subject: [Homebrew_PCBs] Inkjet Transparency Material
> a happy customer.
I get superb transparencies with Mega Electronics Jetstar Premium film in an
HP 5940 printer.
Leon
2006-12-19 by Bora Dikmen
As I understood, you print on this film with black ink
and then pose with UV. So there is no need to buy
waterproof version?
Did you use dry film, and laminate the PCB?
Best,
Dr.
> like an
> a happy customer.
> or other Inkjet
> negative).
> 1160 and obtained
> to the other films
> have a coating to
> quite some time for
> non uniformity in
> of gelatin which
> Glossy Photo Paper,
> use for a FINAL
Do You Yahoo!?
http://mail.yahoo.com
Re: Inkjet Transparency Material
2006-12-19 by derekhawkins
Similar to Epson's film at 1/3 the price. Worth a shot, thanks for the
link.
--- In Homebrew_PCBs@yahoogroups.com, "scratch_6057" <dml.empsrch@...>
2006-12-20 by scratch_6057
Russell Shaw
The seller has a waterproof film that is a little more $$.
The link is for the NON waterproof variety that I have
been using.
>The gelatin coated stuff is what the genuine Epson inkjet film was
anyway.
If memory serves the 3M is the "sand-paper" film also, that's what
I was referring to about a tooth for the ink to bind to AFTER the ink
dried but in my experience there were ink "pooling" problems.
Same story with "AVERY" (the label people) and "COPY FX"
film from "Letraset". The only other RETAIL transparency film
that I ever had any decent luck with was "BURLINGTON" from
Paris Business Products, but I've been told it is out of production.
So have I, it's nothing new to me, my (fragmented) graphic arts
experience goes back to the late `70s. Just posting for some who
may not have had similar experiences.
Bora Dikmen
>waterproof version?
As I understand this question, you are correct, Print, lay film and
board in contact with one another, expose.
The (dry) INK should be in direct contact with the photosensitive
board surface. For solder side a regular print works, If you are
printing a (top) component side your image needs to be MIRRORED
before you print it. If you sandwich things in such a way that the
thickness of the film is between the pattern image (ink) and the
photosensitive (board) surface then you will end up getting some
light leakage around the pattern edges.
I have not used the waterproof film, I personally see no need for
the added expense, except for the possible archival transparency
if I planed on producing large numbers of the same board over an
extended period of time. At that point I would seriously consider
REAL Litho films from Gerbers or send the files to a board house.
At this point, I'm using the more expensive pre coated board material,
the main reason being ease of access, (3 retail suppliers in my area).
2006-12-20 by Bora Dikmen
"At this point, I'm using the more expensive pre
coated board material, the main reason being ease of
access, (3 retail suppliers in my area)."
What is the minimum reliable trace width with these
pre-coated board material? 6 mils possible?
Best,
Dr.
Do You Yahoo!?
2006-12-20 by Leon Heller
Sent: Wednesday, December 20, 2006 6:58 AM
I can get 5 mils for text, but I'm not sure how reliable it is for tracks.
I've tried two short test tracks between 0.1" IC pads, and they were OK.
High-res resist is available for the pre-coated boards I use, and might be
better.
Leon
2006-12-20 by Richard
I run two traces in between .100" pads all the time and "never" had an issue.
I use the GC Positive Pre-sensitived Boards and their developer. Works great, cost a tad more.
Richard
2006-12-20 by derekhawkins
I've found the limitation to be the inkjet printer. Here's a 6X6 rules
torture test;
http://www.pbase.com/eldata/6_6_rules
The printer could not handle identical 5X5 artwork without defects so I
never tried it. However, less demanding real world 5X5 rules or less
shouldn't be a problem.
--- In Homebrew_PCBs@yahoogroups.com, Bora Dikmen <bora_dikmen@...>
wrote:
[Homebrew_PCBs] UV photoplotter
2006-12-20 by Marko Pavlin (home)
Hello!
I am following this nice group for a while. This is my first post.
I've got old X/Y coordinate table which used to be simple pick and place
machine. There's no Z axis and mechanics is not strong enough for
holding any machine with drill or mill tools. One crazy idea crossed my
mind... what if I put one UV light source to this machine and plot with
UV light directly to photoresist coated FR4? I can make small optical
mask with (e.g.) 10 mils aperture, which floats on thin air blowing
beneath the mask. It could act as single (fixed) aperture photoplotter
for direct exposure of PCB photoresist.... Is this kind of stupid idea?
Anyone had experience with that? Would be UV LED enough? Exposure time
is critical here, but I am talking about PCB prototyping.
Any comments?
Regards!
Marko
Re: [Homebrew_PCBs] Re: Inkjet Transparency Material
I actually use a laserjet to do mine, I had problems with over exposure on the inkjets because they apprently let some light thru.
Richard
Sent: Wednesday, December 20, 2006 7:55 AM
Subject: [Homebrew_PCBs] Re: Inkjet Transparency Material
torture test;
Typically, it's the laserjet that suffers from opacity issues and
pinholes when using transparencies.
Sent: Wednesday, December 20, 2006 7:12 PM
That's what I've found, as well. My inkjet transparencies are much denser
than I get with a laser printer.
Leon
Re: [Homebrew_PCBs] UV photoplotter
2006-12-20 by Neil Baylis
A UV LED would probably not be enough, but a UV Laser would. Unfortunately,
the UV Laser will be quite expensive. There may be some other UV source that
would work.
Neil
On 12/20/06, Marko Pavlin (home) <mp@...> wrote:
> Hello!
> Any comments?
> Regards!
> Marko
http://www.pixpopuli.com
2006-12-20 by David Griffith
On Wed, 20 Dec 2006, Marko Pavlin (home) wrote:
> Hello!
The field of homebreweing PCBs is full of nutty ideas, some of which work.
I'd call this nutty, but definitely not stupid. It's worth some
investigation to see if it's feasable.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
2006-12-20 by Phil Mattison
I guess the sensible thing to do would be to get some UV LEDs and some
boards and do some experiments. If it worked it would be better than masking
or milling. Since you can't find any print shops any more that will make a
good film negative or positive it's really hard to make a decent mask.
Phil Mattison
http://www.ohmikron.com/
Sent: Wednesday, December 20, 2006 8:10 AM
Subject: [Homebrew_PCBs] UV photoplotter
> Hello!
> Any comments?
> Regards!
> Marko
Photos:
RE: [Homebrew_PCBs] UV photoplotter
2006-12-21 by Tony Smith
> > Hello!
> > place machine. There's no Z axis and mechanics is not strong enough
> > for holding any machine with drill or mill tools. One crazy idea
> > crossed my mind... what if I put one UV light source to
> this machine
> > and plot with UV light directly to photoresist coated FR4?
> I can make
> > small optical mask with (e.g.) 10 mils aperture, which
> floats on thin
> > air blowing beneath the mask. It could act as single
> (fixed) aperture
> > photoplotter for direct exposure of PCB photoresist.... Is
> > time is critical here, but I am talking about PCB prototyping.
> of which work.
> some investigation to see if it's feasable.
It's already been done. Works well actually, definitely not nutty.
There's a web page out there somewhere of one that was home made, but there
are commercial versions. If I recall he attached the film to a cylinder
(which rotated) and the laser was moved across it. Like a lathe works.
Years ago (like 1990) I worked for a company that did bar code stuff. One
thing we did was film masters & bromides for bar codes. These were sent to
the printers who used them to print the product packaging.
The machine was an X-Y plotter with a laser, drew the images on a piece of
film which you then developed. Very nice sharp lines, very accurate too.
Downsides are it's a bit slow compared to a printer, and you need to have a
darkroom.
Controlled by a BBC micro, of all things!
Tony
2006-12-21 by Roland Harriston
It seems to me that I remember (many years ago) that there was a
"coordinatograph" type machine that we used
in the microwave design lab that did something like what is proposed
here. The difference would be that in the
device I recall, the "media" was like litho film. A light source moved
across the surface of the litho film, tracing
a microwave stripline configuration that was transferred to the film,
the geometry of the stripline configuration
having been programmed into the "coordinatograph" in X/Y coordinates.
The litho film negative that was produced was many times the size of the
actual stripline. A photographic
reduction process was used to establish the actual stripline size. The
advantage appeared to be that the
actual stripline dimensions were very accurate due to the photographic
reduction process.
I think the photoreduction process was, at one time, quite common in the
microelectronics industry
in making masks for integrated circuit fabrication. No doubt, other
techniques are used nowadays.
There are some rather powerful UV LED's available. Check out the UV
LED's in the latest
BG Micro online catalog at the URL below.
http://bgmicro.com/
Others on the list are probably familiar with the above described technique.
Roland F. Harriston
> ___
2006-12-21 by scratch_6057
> Richard
I can only envision a few instances where a Laser would give
better opacity results than an inkjet.
A) Transparency film used is for Laser ONLY. Inkjet ink
"pools" or "puddles"
B) Inkjet in DRAFT mode, I seem to recall some printers that
would "lock" into draft when the ink hit a certain low quantity
level remaining in the cartridge. Possibly a corrupt printer driver.
C) Really OLD Inkjet Printer i.e "360 dpi"
2006-12-21 by Richard
I have the old HP6 and I have had much better luck than using my Cannon Inkjet. Maybe it's the inks, but I have had no trouble with using the old HP.
Richard
Sent: Thursday, December 21, 2006 7:18 AM
> Richard
2006-12-21 by derekhawkins
>using the old HP.
In terms of opacity, pin holes and dropouts, there is no HP laserjet,
even with the best transparency match, that can do a better job than
the right inkjet with similar match. You would have to use vellum or
tracing paper with the laserjet to even things out. One example of a
right inkjet combo would be any of Epson's dye based printers and
Epson's transparency.
Maybe I've been lucky all these years, or the inkjet printers are better than they were.
When I first started, all the suggestions were to use a copying machine or a Laser Jet, and NOT to use an inkjet. I guess times have change. Maybe next time I'll try my new inkjet photo printer and see how it does.
Don't take me wrong, I'm cetainly not argueing, it just caught me by surprise, That is the only reason I kept this old laser jet around all these years. I never, never had problems going two traces between 0.100" pins.
I never could understand why everyone felt that was difficult. Again, guess I had been lucky.
I still will take the suggestions and advice I'm reading serious, no doubt some of youhave done this longer than me.
Richard
Sent: Thursday, December 21, 2006 11:00 AM
>using the old HP.
Recent Activity
a.. 25New Members
Visit Your Group
SPONSORED LINKS
a.. Printed circuit board
b.. Electrical engineering software
c.. Electrical engineering
d.. Electrical engineering career
e.. Bachelor degree electrical engineering online
Need traffic?
Drive customers
With search ads
on Yahoo!
Y! GeoCities
Share Your Resume
Show off your
talent and skills.
Yahoo! Groups
Start a group
in 3 easy steps.
Connect with others.
2006-12-21 by Stefan Trethan
> than they were.
> 0.100" pins.
> Richard
Older inkjets were pretty crappy machines.
Lasers never have trouble with thin taces, it is fill areas that get them,
and geometric distortion.
How many traces you get between 100mil pins also depends on the size of
pad you wish to leave.
ST
2006-12-28 by derekhawkins
For what it's worth, recently got some of the inkjet film referenced
below but it fared no better than the Office Depots and Apollos
tried. Maybe it was old stock or something.
Whatever, called Screen Printers and informed them that I would like
to return it, whereupon and to their credit (hopefully mine too
eventually), they gave me return instructions and no questions asked.
being
> a happy customer.
films
but
to
almost
2006-12-29 by scratch_6057
--- In Homebrew_PCBs@yahoogroups.com, "derekhawkins" <eldata@...>
referenced
like
asked.
Derek,
I'm sorry to hear that you had less than expected results
with the ScreenPrinters.Net film. I'm surprised that your
experience was less than acceptable. Would you be willing
to give details of what printer, ink and resolution you were
using? I'm wondering if the film was somehow resistant to the
absorption of the particular ink you are using?
