Homebrew_PCBs
C84 conversion
C84 conversion
2006-12-15 by Tuck Hartshorn
Stefan, the C84 conversion webpage says, "If you use very thin (60mil/1.5mm),
then skip these steps.
Am I missing something. To me, 60mil or 1/16" is quite thick. It used to be
the most common available but I see 1/32 and 1/64 is now fairly common, too.
Are you saying that the C84 will pass the smaller gauges without modification?
How thick can the C84 take before the head needs to be raised?
TIA,
(also, I'm curious as to why you chose the C84 if there is any other reason
other that it was "there")
Tuck
Re: [Homebrew_PCBs] C84 conversion
2006-12-15 by Stefan Trethan
> (60mil/1.5mm),
> be
> too.
> modification?
> TIA,
> reason
> Tuck
I don't remember saying that, could you give me a link so i can see the
context?
I selected the c84 mostly because it was the most plentiful, yes. You
could always find one on ebay for 1eur.
ST
Re: C84 conversion
2006-12-17 by mikezcnc
Yes, Steve said that a thin PCB 20 mils can pass without
modification and Steve is correct- that works fine. I will answer
and comment about the method:
1. Thank you Steve for letting us know about the C84 and mispro ink.
I followed your advice and while I had a hard time to follow it, it
was a very good info.
2. I duplicated all Steves experiments and I can tell you that teh
PCBs generated in that manner resemble near photo quality. The
method is fast (I can have a PCB in 20 minutes etched) and it seems
to be a bit better in quality than TT. Regrefully there are many
variables and Zoran actually had a point in this case but than again
I disagree with Zoran on photochemical being simple-- yes it is
simple if you buy sensitized PCBs ($$) but if you make them.. I can
write a dissertation if there is a demand)
3. What is wrong with printing on copper? The method is really cool.
You stick a PCB and off you have the pattern that can be heated up
and etched. Well, the printer C84 is $itty.I got one and learned on
it. Freeing up the heads is not for everyone. In fact not knowing
hte reader I can tell it is not for you... BS on the net about
cleaning is just that-BS. Having that C84 I then decided to use it
for learning about sheet metal. I reade and reread Steves directions
about nibbling on it and the results was I finally took a
reciprocating saw and cut above the slot. Now what? You have to
mount it so that it is true in three planes and true for CNC means
different trueness than for making wood cabinets. Bottom line is:
you won't be able to mount that cut off front rail so it holds its
position today and tomorrow. No way. If you have so much metal
talent I suggest sticking that head on a cnc machine that Dave will
have in January and now you've got something going!
4. So the good news is: you do not have to touch the sheet metal and
can remove few plastic parts and start sliding PCBs of 20mils or
thinner, right? Sort of. Like I said the printer is $itty.
5. But there is a light in a tunnel. People like morons keep buying
those poor quality printers C84 on ebay for big $$$s. They don't
know that they can have a brand new printer C88+ from CompUSA for
$80 and actually with some discounts for much less. Brand new. It is
the same printer jus brand new. As a reminder C86 also is the same
printer but also $itty quality.
5. So now you have a brand new C88+ and are ready to buy the inks.
You bought the inks, you isntalled the chips with the gooball and
are ready to print. Surprise! My c88+ printed crooked! I took it
apart and what happened? The pad looked like a used cotex, but with
black ink. I swear, those people at Epson sell rufubished printers!
I saw ink all over inside, I saw plastic parts labelled 'resprayed'.
Maybe collection of early engineering prototypes? Times are tough
for everyone, I guess. I used that printer for experiments: I warn
you, stay away from cutting metal. I was printing all right, but
getting anything resembling a pattern was impossible.
5. Another C88+ another day. I printed mispro ink. Frankly, IMO
misproinks might be a solution for some but the quality of colors is
unacceptable. Those people at mispro are color blind that they don't
see that they don't resemble epson colors. Stay away from mispro if
you want to have quality colors.
6. But all we care is that secret ingredient in yellow in magenta,
so who cares. I finally got C88+ printing, made the famous cut in
side (thank you Steve, that helped, great job you did!) and was very
happy. Heating it is no problem but takes some experimenting, no
biggie. The PCBs are etch resistant, except for the very thin traces
have tendency to underetch. Now: let'sention one thing: what I like
in a PCB is not what you like in a PCB> I am talking about
complelxity on the level of a PCB in desktop PC, ok? And that type
is achieveable with ease with, I would say 99% accuracy. Almost
photo quality.
7. So what seems to be the prblem? Well, few days later I revisited
teh experiment and the print head was clogged- ina brand new
printer. Cleaning, etc.. came out better but still for a brand new
printer it is surprising that Epson engineers don't have it in grip.
I am disappointed with the drying out ink when printer is not in use
and that pretty much disqualifies teh method unless you know youa re
printing daily and I hope it is often enough.
I don't have that problem with a laminator.
It amazes me that I read discussions on Make of people excited about
it, without understanding that even a brand new printer is not a
solutionn for printing PCBs. Was fun to try it but it is not a good
solution. It is probably the same problem liek with the plotter pens
that always dried out except here you cannot run the cartriges dry-
that mispro misfit is expensive. I feel sorry for peole who try to
make a living pinting on inkjet printers large size prints- there's
got to be a better way.
So who is going to present the next innovation?
Mike
Re: [Homebrew_PCBs] Re: C84 conversion
2006-12-17 by Stefan Trethan
I just want it known that i disagree with many points of this post.
I don't have the time right now to go into details though, just treat it
as not unanimously accepted.
ST
On Sun, 17 Dec 2006 22:38:29 +0100, mikezcnc <eemikez@...> wrote:
> Hi,
> photo quality.
> Mike
Re: C84 conversion
2006-12-18 by mikezcnc
Hi Stephan,
I have no intention of dicussing that subject either but I will
summarize again:
1. Direct printing on copper is a COOL method but the ink tends to
dry out in the printer head and when it dries out even teh cleaning
cartridges from mispro do not work. My suggestion is: stay away from
mispro inks- their color is not what epson envisioned for quality-
they are 'dirty' colors! Even if you get to the point of printing,
two days later it won't print and you brand new printer will behave
like it was from ebay. The reason? Dies out in a print head.
2. Do not buy Epson printers from ebay and do not buy Epson printers
refurbished- not worth it. And do not buy C84!!! Nor C86!!!
3. Mispro ink is good for printing on PCBs but if you think you
will use it as ink in your second printer- you will not: you have to
swap, according to Stefan, yellow cartridge with black. That makes
yellow cartridge black and by difusion... you get the picture.?
4. Your printer even if it only prints on 20 mil copper, ie without
conversion with the nibbling tool (you haven't lived yet if you have
not converted a C84 according to Stefan's direction: Stefan is a
genious and you are not :) -- even then you will not be able to use
your printer for printing for any normal prints unless your
application is on a small format or you enjoy having an alongated
cutout in paper on the right side....approximately 35mm :))
4. Good luck and PLEASE QUIT BUYING THOSE inferior Epson C84
printers. At least in US you can buy a brand new C88+ that does the
same job.
And yes: it was a major breakthru when Stefan (I guess theere was
another person invollved in that project) determined yellow and
magenta contain an ingredient which laminates at high temp. Beyond
that it is an excercise (I won't say "in futility, but close) and it
is not a method as convenient as TT. No way. Resolution? Depending
on your skill and application, can be very close, too.
Cost and economy: it is a nonsense to even consider the economy of
mispro inks application $$$$$$. You want to know something better?
Mispro resetter does NOT work on original Epson cartridges. Does
not, so you cannot re-use them for reinking the original ones. Am I
the only one in the world who decided to follow Stefan's directions?
Wow! We have so many writers on the subject :)) Mike
2006-12-18 by Stefan Trethan
On Mon, 18 Dec 2006 18:13:36 +0100, mikezcnc <eemikez@...> wrote:
> Hi Stephan,
> summarize again:
ok, i still disagree ;-)
ST
Re: C84 conversion
You are the best Stefan, and I respect you for that. What I have
learned from your description is that few men in this world can match
your talent :) You are that good. Mike
> > Hi Stephan,
> > summarize again:
> ST
2006-12-18 by Lez
On 18/12/06, mikezcnc <eemikez@...> wrote:
> Hi Stephan,
> summarize again:
Soak them.
I dont car if they are crap at photo prints provided they do good pcb
for people.
Should not dry out if the head is parked properly and the parking
rubber is intact.
No, buy a photocolour 900, take pcb upto a4 size and upto about 4mm
thick! beat that!
No, but I think it means put yellow ink in so it goes into the black nozzles
> same job.
yard sales / carboot sales, pick them up for nothing, so why not use them?
So what ink do we get then?
Lez
C84 conversion
2006-12-18 by Bora Dikmen
Hi Lez,
> upto about 4mm thick! beat that!
How much modification is needed is needed for 900?
I just disassembled the plastic cover of the R220, and
adjusted its head height with my hand to print on the
PCB. All took 1 hour since it was my first job.
Best,
Dr.
Do You Yahoo!?
http://mail.yahoo.com
MISPRO versus Edding pen's ink
I did not want sacrifice my brand new Epson R220
while trying edding pen's etch and water resistant
ink.
As you know, they are permanent ink markers used
as correction pens in homebrew PCB market.
One in my hand now is "edding 140 S, ohp marker".
But I am not sure that I can find its ink separately.
Any comments, any victim tried it?
Best,
Dr.
Do You Yahoo!?
2006-12-18 by Lez
On 18/12/06, Bora Dikmen <bora_dikmen@...> wrote:
> Hi Lez,
None, takes a plastic carrier for the cd thats about 3mm thick, a4 in
size, goes in from rear, opto alignments etc, spot on everytime.
I have never printed a real pcb as I only have dye based ink and they
wash right off, and being in the UK no UK store sells any decent ink,
and I wont pay $50 for an epson cartridge
I have printed onto PCB with paper stuck on with glue to test if it
would feed pcb, and had no problem, just dont have the right ink.
Lez
Epson 900 direct printing on PCB
2006-12-19 by Bora Dikmen
Hi Lez,
R220 can also print onto CDs. It has a narrow (1/3 of
A4) CD tray. I tried to print PCB via this utility but
it failed. The sensor in the printing head carefully
search a white blank CD is inserted in the right
place.
If it can not detect such a thing, it gives an error
of
"CD is not properly located in the CD tray" and
refused
to print.
Are you sure that we can print on A4 very easily?
What you mean by "opto alignments etc, spot on
everytime"?
If you use the print CD utility, I have serious doubts
Best,
Dr.
> > Hi Lez,
> size and
> 900?
> 3mm thick, a4 in
> on everytime.
> based ink and they
> glue to test if it
> the right ink.
> Lez
Do You Yahoo!?
Re: [Homebrew_PCBs] Epson 900 direct printing on PCB
2006-12-19 by Lez
> place.
> of
> refused
> to print
Yes isnt machine intelligence wonderful, the 900 OTOH, optically
detects a notch and a white square printed on the tray, not the disk.
I have tried standard 1.6mm copper fr4 about 1/3 of a cd size, inthe
cd cutout/indentation, worked fine, just ink wipes off as I have dye
ink cartridges.
So, printer fine, economy inks no good, maybe if I bought a $55
durabrite cartridge it would do PCB 'off the shelf'
Lez
