Homebrew_PCBs
how to reduce/eliminate pinholes with TT
2006-12-03 by Stefan Trethan
I was recently having some trouble with pinholes/etching through of very
wide traces or ground planes.
Today i realized something very significant: Paper surface influences
pinholes, possibly more than anything.
I usually use zweckform/avery paper, which has a matte clay finish. I had
the holes/etching through with this.
But because it was closer i used Verbatim paper today, with a shiny
surface. This paper is a little harder to remove, and heavier.
After printing i held it against the light and it was _very_ translucent.
Because it is heavier than my regular avery paper it will get less toner.
I was sure this would leave heaps of pinholes and stuff, since i had to
make a PCB with ground planes. To my surprise there is not a single
pinhole, the copper surface was pristine under the toner throughout. Even
though the toner was obviously more translucent on paper the glossy, flat
surface must help in keeping an even toner distribution, or something,
that prevents pinholes.
The pinholes bugged me, and i'm glad i finally realized why it is that i
sometimes got them and sometimes not. I was just thinking my toner must
run out, but this paper works perfectly.
Anyway, may seem obvious, but it took me long enough to realize it so if
you get pinholes try a glossy paper instead of a matte clay paper.
This paper is a bit harder to remove, and tends to peel off the board
outline or outermost traces. But that can be controlled by drawing a fat
board outline around the actual PCB.
ST
Re: how to reduce/eliminate pinholes with TT
2006-12-11 by Harry
Best papers i found where from some (german) companies IT Catalogues.
For instance from w w w.bcs.direct.de is very good. Even better , the
best i found, as it dissolves perfcetly in warm water with some
detergent is from a IT Training company: w w w.die-akademie.de.
After 10 minutes it nearly swims away..... and best of it..no cost..one
free catalogue is good for hundreds of boards....
This one gives ( using a HP 2100, original toner and a modified
laminator ) 100% reproducable results from black surface down to 5
mil !!!!
Harry
