Mercury lamp for UV exposure
2006-10-13 by Leon Heller
I've just bought a ballast to go with a mercury lamp I bought on Ebay. I've
just connected them up and the lamp is working OK. I rather stupidly put it
on the bed with a dressing gown over it to keep the cat away, smelt burning
a few minutes later and found the lamp had burnt the duvet cover and the
dressing gown. 8-(
Next step is to remove the outer envelope and do some test exposures. I'll
rig up a suitable box to keep the UV away from me.
Leon
Leon Heller, G1HSM
Suzuki SV1000S motorcycle
leon.heller@...
Re: [Homebrew_PCBs] Mercury lamp for UV exposure
2006-10-13 by guja
do not remove the outer envelope. first make test exposures (with envelope).
Leon
Leon Heller, G1HSM
leon.heller@...
Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business.
2006-10-13 by Dwayne Reid
>dressing gown. 8-(
Couple of things: make sure that the phosphor is on the inside
surface of the OUTER envelope.  That pretty much guarantees that the
inside bulb is clear, and thus emits UV.
The reason I mention this is that I now see Mercury Vapor bulbs with
a clear outer envelope.  Box usually mentions that the bulb is "UV
safe" - this means that the inner bulb doesn't emit UV.
The other important thing is: that inner bulb needs to run hot.  The
existing outer envelope provides thermal insulation so that the inner
bulb can operate at the design temperature.
I wound up enclosing the inner bulb within a Hammond die-cast
aluminum box about 4" x 4" x 7".  A large hole on the bottom allows
the UV to escape, a mechanical shutter (motor driven) covers the hole
until the timer switch is hit.
The enclosure allows the bulb to operate near its design temperature:
its air-tight other than the single large hole facing downwards.  I
find that the bulb takes 5 to 10 minutes to come up to operating
temperature before I use it (don't really pay much attention to it:
the electronic ballast I use sort of squeals until the bulb reaches
operating temperature).
The whole thing works well - I'm on my 2nd bulb now.
dwayne
Dwayne Reid   <dwayner@...>
Trinity Electronics Systems Ltd    Edmonton, AB, CANADA
(780) 489-3199 voice          (780) 487-6397 fax
Celebrating 22 years of Engineering Innovation (1984 - 2006)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Sent: Friday, October 13, 2006 5:25 PM
Subject: Re: [Homebrew_PCBs] Mercury lamp for UV exposure
>>I've
>>it
>>burning
>>dressing gown. 8-(
Yes, I checked that.
That's a good idea, I think I'll do the same. I've got a ceramic socket for
the lamp.
Leon
Leon Heller, G1HSM
leon.heller@...
2006-10-14 by Zoran A. Scepanovic
Hello Leon,
> dressing gown. 8-(
> Leon
> Leon Heller, G1HSM
> leon.heller@...
  PLEASE DO NOT BREAK THE OUTER GLASS!
  You  will end up with lot of shortwave UV AKA UV-C. Photoresists are
  sensitive  (peak)  arround  340  nm  AKA UV-A. Also with outer shell
  removed,  you  will  generate  lot  of  ozone (O3) which reacts with
  haemoglobine  in  your  red  blood  cells  and other cells that need
  oxygen can not use in 'cause it's not O2.
  UV-C  can produce severe skin damage and is 'tethal' to your retina.
  Irreversible sight damage.
 Best regards,
 Zoran A. Scepanovic
 zastos@...
To estimate the time it takes to do a task:
 estimate the time you think it should take, multiply by two and change the unit of measure to the next highest unit.
 Thus, we allocate two days for a one hour task.
Please be advised what was said may be absolutely wrong,
and hereby this disclaimer follows.
I reserve the right to be wrong and admit it in front of the entire world.
2006-10-14 by Leon Heller
To: "Leon Heller" <Homebrew_PCBs@yahoogroups.com>
Sent: Saturday, October 14, 2006 6:31 PM
> Hello Leon,
>> I've
>> it
>> burning
>> dressing gown. 8-(
>> I'll
>> Leon
>> Leon Heller, G1HSM
>> leon.heller@...
It will be mounted in a light-tight box.
Leon
2006-10-14 by Stefan Trethan
On Sat, 14 Oct 2006 19:51:57 +0200, Leon Heller
> Leon
But in case it does no good (or little good) what is the point in breaking
the envelope?
Does it really speed up exposure that much?
ST
Sent: Saturday, October 14, 2006 8:01 PM
>> Leon
> the envelope?
Everyone else using them does it. It will also help with collimation as it
will be more like a point source. The high-speed exposure units used by PCB
manufacturers use much more powerful mercury arc lamps with special optical
systems consuming 3.5 kW or more and delivering 15 mW/sq cm of UV at the
PCB!
Leon
2006-10-14 by guja
"envelope or not?" poll question.
Leon Heller <leon.heller@...> wrote:  ----- Original Message -----
To:
>> Leon
> the envelope?
PCB!
Leon
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
If Files or Photos are running short of space, post them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Yahoo! Groups Links
2006-10-15 by Norm Stewart
I've used a 400 watt hi-bay lamp (480V ballast) without an envelope
since 1973 - same bulb still going strong.  Just keep it in a complete
enclosure with a slot to insert the PCB sandwich.
Norm
> <mailto:leon.heller%40bulldoghome.com>> wrote: ----- Original Message
> From: "Stefan Trethan"
> To:
> >> Leon
> breaking
> > the envelope?
> as it
> by PCB
> optical
> PCB!
> Leon
> Photos:
> <http://groups.yahoo.com/group/Homebrew_PCBs>
> <http://groups.yahoo.com/group/Homebrew_PCBs_Archives/>
> Small Business.
2006-10-15 by Leon Heller
Sent: Sunday, October 15, 2006 1:36 AM
The high-power exposure units use special "short arc" lamps, which emit a
lot of UV at the correct frequency. They give a very intense point source,
which is ideal, but are not very easy to use having very high trigger
voltages and high operating temperatures. They can also explode
unpredictably and have a short life. It would be nice to have one of those,
but they are simply too dangerous, even for me. 8-)
Leon
