Homebrew_PCBs
RE: [Homebrew_PCBs] UV Light Sources
2006-09-25 by John Craddock
I read somewhere on the web that a mercury vapour lamp with the outer uv blocking envelope removed gives a very good source of uv light for photo-pcb resist curing. Obviously removing the outer envelope would require that the uv exposure box be totally enclosed when the system is operating. Can any one confirm that this is comparable or better than the black-light fluorescent approach?
TIA
Regards
John C
Re: [Homebrew_PCBs] UV Light Sources
2006-09-25 by william.kroyer@kilroysprojects.net
Well mercury vapor bulbs are a popular choice for lighting amongst reptile owners because they offer a decent amount of UVB that is needed by a number of reptile species for proper vitamin D3 production but I don't know that it would be enough for curing the photo resist. For that you might want to look at the UV bulbs used in aquarium and pond UV sterilizers. They put out considerably more UV to the point that they can be hazardous if not totally enclosed.
Sent: Sunday, September 24, 2006 10:35 PM
Subject: RE: [Homebrew_PCBs] UV Light Sources
TIA
Regards
John C
2006-09-25 by Leon Heller
Sent: Monday, September 25, 2006 3:35 AM
It's a lot better (much shorter expoosure), but needs to be a long way from
the PCB/artwork for good collimation (something like 1 m, IIRC). I've got
some similar sodium lamps that can have the outer envelope removed. The
ballasts can be difficult to find. For accurate exposure I think you need
some sort of shutter arrangement as they take some time to warm up.
Leon
Re: UV Light Sources
2006-09-25 by Andrew
>> approach?
> enclosed.
Yes the mecury vapour lamps work fine for
PCB resist. Most expensive comercial
machines use them I think.
They also (as others have pointed out) need
to be run for a while to be up to temprature.
This means you either need to have some kind
of shutter to expose the PCB or as someone
else said (can't remeber who or when) you can
pre-heat them at a lower voltage and then up
the power for the exposure.
The light from them is also more like a point
source. This has good and bad points.
I good point is that you can more easily
collimate the rays. Bad point (as Leon-H
pointed out) you need to have the bulb at a
long distance from the PCB.
Fish tank STERILISING tubes are NOT suitable.
They are shorter wave length UV that is both
useless for the photoresist and dangerous.
AFAIK The arc lamps with covers removed also
produce dangerous UV rays as well as the
usefull (for PCBs) rays.
All up - I think that black light tubes are
probably the most convenient and easiest to
setup and use option.
They don't produce appreciable amounts of
dangerous UV. Several of them in parallel
will put out plenty of UV. They are easy
to get. I think the biggest problem with
them is they don't seem to age gracefully
(at least im my experience they didn't)
If you can't get or have surplus arc lamps
then they should be great for PCBs though.
> -----Original Message-----
> From: Leon Heller [mailto:leon.heller@...]
> Sent: 25 September 2006 16:27
> Subject: Re: [Homebrew_PCBs] UV Light Sources
> better than the
> long way from
> IIRC). I've got
> removed. The
> think you need
> Leon
Thanks Leon
For the collimation I was going to use a parabolic reflector. With a 16" (400mm) dia., reflector it would seem to be feasible to have a working exposure area of 12" to 18" (300 to 400mm) Instead of a shutter I was thinking of using a slide-in frame holder. In OZ we can get 250 watt self ballasting globes the run off our 240 volt mains supply. This set-up would be far less expensive than say 4 or 5 fluro tubes plus their associated ballasts, starters etc (at least in the antipodes).
Regards
John C
Sent: Monday, September 25, 2006 8:13 AM
>> better than the
>> long way from
>> IIRC). I've got
>> removed. The
>> think you need
>> Leon
> Thanks Leon
I was going to remove the envelope from one of my sodium lamps, but the cat
knocked it off the bench onto the floor and did it for me. 8-) I got some
ceramic bulb holders without any problems, I really must get a ballast and
try it out. I got the bulbs cheap on Ebay; I should have got one of the
units you mention, it would have been less trouble.
Leon
2006-09-25 by derekhawkins
Search these archives on >Colight DMVL-930<. A fellow recently posted
on a commercial setup here using twin mercury vapor bulbs that exposed
both sides of the board at once. Craddock must have at least searched
these archives for >mercury vapor< before starting this thread. Flags
raise when "people play the fool to catch the wise", begging the
question "What's his MO?".
2006-09-25 by twb8899
We had two DMVL-930 exposure units for dry film photoresist and they
used 1000 watt bulbs. When I closed the PWB plant I kept the best one
for my home shop and junked the other one since nobody wanted it at
the time.
I think the bulb part number is R1000 if my memory is correct. It's
just a standard 1000 watt mecury vapor bulb with a reflector. There is
no need to worry about collimation of the beam unless you are exposing
very large panels. Don't break the outer glass from the lamp unless
you want ozone.
Just the other day I saw a lamp assembly that would be perfect for a
homebrew exposure unit. It was a mercury vapor lamp with reflector in
a metal enclosure at the base of a flagpole. This lamp looked like a
400 watt bulb but that would work great for dry film resist. Just
build a box around the lamp assembly and leave a slot at the bottom
for your contact frame to slide in and out. The bulb could be about 12
inches from the contact frame.
At 400 watts I'm guessing about 45 seconds for exposure at 12 inches.
My system uses the 1000 watt lamps. They idle at 1000 watts and during
exposure they are overdriven to 1500 watts. Exposure time for DuPont
1.5 mil photoresist is 17 seconds. I do 5 mil lines and spaces daily
with this system. My film work is photoplotted on 7 mil thick films.
Dry film resist is negative acting and has a fast exposure time.
Positive resists are slower and will take longer to expose.
Tom
--- In Homebrew_PCBs@yahoogroups.com, "John Craddock"
> > better than the
> > long way from
> > IIRC). I've got
> > removed. The
> > think you need
> > Leon
> Thanks Leon
antipodes).
> Regards
> John C
>There is no need to worry about collimation of the beam unless you
>are exposing very large panels.
Hear, hear!
--- In Homebrew_PCBs@yahoogroups.com, "twb8899" <twb8899@...> wrote:
RE: [Homebrew_PCBs] Re: UV Light Sources
> From: derekhawkins [mailto:eldata@...]
> Sent: 26 September 2006 00:18
> Subject: [Homebrew_PCBs] Re: UV Light Sources
Snip
Derek
FYI in the English language we spell "vapor" as vapour, so a search missed it; sorry we don't have any American schools in OZ. Your insinuation in the snide comment above is pretty dammed offensive and totally uncalled for in a list such as this. FYI my "MO" is that over here a 250 watt mercury "vapour" globe of the self-ballasting variety costs AU$36 including the ceramic holder. Otoh 4 uv fluorescent tubes plus the control gear to go with them costs 5 times that amount. SAVING MONEY IS MY "MO".
Regards
John C
Tom, thank you very much for that information. I have a few questions mixed in context below.
> From: twb8899 [mailto:twb8899@...]
> Sent: 26 September 2006 04:17
> It's just a standard 1000 watt mecury vapor bulb with a reflector. There is
> you want ozone.
Is the reflector built into the globe i.e.. is it a PAR type globe or is it separate?
I was going to use a 250 watt self-ballasting globe. Do you think that would be OK?
Would you use a similar distance of 12 inches for a 250 watt unit?
Would 2 * 250 watt globes be a better way to go? I will be exposing Kinsten positive resist PCBs
> Tom
Once again Tom thank you for your guidance.
Regards
John C
2006-09-26 by derekhawkins
>missed it
Missed what? Searching on >mercury vapour< gives another set of hits
including this;
>>DO NOT break the outer glass shell of a mercury vapour lamp! It
>>will radiate a lot of short wave UV (UV-A) which is dangerous for
>>eyes and skin, and it generates lot of ozone (O3). Good results
>>could be obtained without breaking the outer glass shell.
I'm inquisitive too...What are you really up to? You're coming
across like a "Man dressed in black".
Re: [Homebrew_PCBs] Re: UV Light Sources
2006-09-26 by Russell Shaw
> Hear, hear!
I made a UV lightbox with a 125Watt HID lamp (HPR-125) 24" from the glass,
and in a cylindrical parabolic reflector (lamp lays horizontal). 90%+ exposure
happens in 30secs, and i found a good optimum to use is 90secs for
pre-coated negative pcb. The pcb is held against the glass by the lid
that has a layer of sponge.
Without the reflector and beam collimation, you'll need a bigger globe
for the same exposure time.
2006-09-26 by John Craddock
> Sent: 26 September 2006 10:05
> >missed it
> including this;
That was precisely the reason for my question (see the first post on this thread). I understand from my web searching that UV-A is the radiation band that actively polymerises the UV resist. I further understand that the more intense the UV-A radiation is the quicker the polymerisation. I have also read that the quicker the exposure, the better is the definition achievable. Seeing as the exposure unit would be fully enclosed, I don't see a problem with the eyes and skin bit. Anyway, from the research that I have done, it seems that the dangerous radiation bands are UV-B and UV-C; so your quotation is quite incorrect on that point but the UV-B and UV-C also is unblocked by breaking the glass filter. So the recommendation in that excerpt is appropriate for some purposes. However it is out of context so I cannot tell. The so-called solariums (facial tanners) rely on UV-A as their active radiation ingredient so it cannot be too harmful. Ozone has got me a bit worried though.
Still trying to get a range of views on whether mercury vapour is a better way to go than fluorescent.
That is your opinion. Problem with the English language I guess. Re-read the thread and reflect on whether you are being just a teensy bit paranoid.
Regards
John C
2006-09-26 by twb8899
There is
> > you want ozone.
or is it separate?
The reflectors in my exposure unit are external to the lamp. They are
made of thin polished aluminum sheet. You could probably just use
some cheap glass mirrors to do the same thing.
that would be OK?
I think a 250 watt bulb would work ok. Give it a try without the
reflectors first and you may find that it works fine for smaller boards.
I'm not familiar with Kinsten resist. You mentioned that it is
positive acting so it may take longer to expose no matter what type of
lamp you use. Try the 12 inche distance first and see how it works out.
I saw another mercury lamp this evening that was being used to light
up the side of a building. This one did have a 400 watt bulb and it
would make an excellent exposure unit. It had a polished stainless
steel reflector around the lamp. Check out one of these lamps to get
an idea of how it's set up.
BTW, my 1000 watt system also does a good job with silk screens. The
Autotype Five-Star emulsion takes 30 seconds and the diazo liquid
types take 90 seconds.
No matter what type of bulb you use it is a good idea to get a
Stouffer 21 step exposure strip to test your exposure times. If you
take just a little bit of time to calibrate your system the results
will be excellent. These Stouffer 21 step test strips are inexpensive
and a good tool to have on hand if you do any work with photoresist.
Tom
> Regards
> John C
> From: Russell Shaw [mailto:rjshaw@...]
> Sent: 26 September 2006 12:17
> Subject: Re: [Homebrew_PCBs] Re: UV Light Sources
> from the glass,
Thank you very much for that information Russell. Points like your experience on the exposure time and distance between light source and object provide a real contribution to my knowledge base and, no-doubt, many others on this list on this matter.
Regards
John C
2006-09-26 by Leon Heller
Sent: Tuesday, September 26, 2006 4:07 AM
Subject: RE: [Homebrew_PCBs] Re: UV Light Sources
>> >missed it
>> including this;
Several people remove the outer envelope, it has to be done with sodium
vapour lamps anyway. I think that the Hg lamps will emit a lot of UV as it
is. I used to get a lot of ozone from EPROM eraser tubes (germicidal tubes),
so I'm used to it. It gets converted to O2 quite quickly, and the main
effect is as an irritant. We will only have it on for a few minutes at a
time, so I can't see it being a problem.
They used to pump O3 throught the London Underground system at night, to
kill germs. Perhaps they still do. I think a carbon filter will remove O3,
they are used on photocopiers, which used to emit lots of ozone. At any
rate, the old Xerox ones did - I used to work for Rank-Xerox (UK). It was
produced by the corotron which charged the photoreceptor.
Leon
Leon Heller, G1HSM
Suzuki SV1000S motorcycle
leon.heller@...
2006-09-26 by Steve
> Snip
> > <andrewm1973@> wrote:
> Derek
> Regards
> John C
Please watch your language and your temper.
FYI, that's American English.... ;')
Derek, I must have missed something, I wasn't picking up any ulterior
(ulteriour?) motives.
Steve Greenfield
Moderated Re: UV Light Sources
2006-09-26 by Steve
I'm sorry to do this, but since you continue to be combatative and are
attempting to bait, you are now on moderated status.
Steve Greenfield
listowner
>globe for the same exposure time.
This is more to do with focus than collimation. Parallel rays would be
better than divergent rays but convergent rays would even be better
than parallel rays if shortest exposure time was the only goal.
2006-09-26 by Zoran A. Scepanovic
Hello Leon,
Tuesday, September 26, 2006, 9:52:31 AM, you wrote:
Some snippings :) and replies inbetween the lines
UV-C (UV-A) is long wave UV
Good one! Polymerisation is affected by UV-A
Absolutely true
Germicidal tubes (real ones produced by Phillips os Osram do not emmit
ozone. Their glass and gas combination are specificially formulated so
that these lamps do not emmit ozone.
> Leon
> Leon Heller, G1HSM
> leon.heller@...
For more mine replies on this subject please take a look at the
following messages in this group:
249
250
4116
13065
13086
Best regards,
Zoran A. Scepanovic
zastos@...
RAM = Rarely Adequate Memory
Please be advised what was said may be absolutely wrong, and hereby this disclaimer follows. I reserve the right to be wrong and admit it in front of the entire world.
That's just a roundabout way of saying you get the fastest exposure by
focusing all the light to a smaller area, maximizing the power density.
I designed the reflector to give parallel rays, and the result shows as
an even power density of the size larger than an A4 sheet.
>by focusing all the light to a smaller area, maximizing the power
>density.
If you remove the reflector and put a collimator in front of the lamp
you'll get your collimation without focus. Yes, nice low intensity
parallel rays.
> From: Steve [mailto:alienrelics@...]
> Sent: 27 September 2006 00:13
> Steve Greenfield
Well Steve you just created another lurker. Sorry I asked the question.
Regards
John C
2006-09-27 by william.kroyer@kilroysprojects.net
So basically UVB is useless for photoresist and it's UVA output that's key? Wouldn't
a full spectrum plant bulb work fairly well then? If I recall most put out a fair amount of UVA
and fairly cost effective.
Just something else that occured to me in regards to MV bulbs put to use for photoresist.
If you want to find them cheap/free make friends with some local reptile owners. Many of us
use them for the UVB that they emitt for a number of reptiles that require UVB for Vit D3
systhesis. The kicker is that UVB levels drop off to a point of being of no use for us
and as a result have to be replaced. However, they should still emitt plenty of UVA which would
longer wavelength UV.
Also beware of the self ballasting MV bulbs. I know of several people
that have had issues with them since the filaments tend to be quite fragile, especially when hot.
I have yet to hear of someone experiencing a failure with an externally ballasted bulb though.
Sent: Monday, September 25, 2006 2:26 AM
Leon
2006-09-27 by Russell Shaw
> parallel rays.
If you put a collimator (lens) in front of an isotropic light source such
that the cone of interception is 90 degrees (quite efficient for a lense setup),
then you'll only collimate 15% of the light (the other 85% is lost).
My cylindrical parabolic reflector intercepts light 270 degrees around the globe,
so 75% of the light is reflected. Because it is only parabolic in one axis, more
light is not collimated in the other axis, so hits the box sides.
Because the globe is laying horizontal and there is no light emission along the
axis of the globe, then not as much efficiency is lost.
The efficiency is certainly triple that of a lens collimator of similar area.
"Yes, nice low intensity parallel rays."
The intensity of parallel rays does not decrease with distance.
By using 24" of distance, the divergent rays from the globe is quite low
and the parallel rays are much more intense.
2006-09-27 by Steve
> > Steve Greenfield
Huh? I was taking Derek to task. How have I offended you?
Steve Greenfield
Re: [Homebrew_PCBs] Re: UV Light Sources - the MV HID
2006-09-28 by Adam Seychell
Also, remember window soda glass shuts off anything below 270nm so that
includes _all_ UVB. I haven't done side by side comparisons between the
various HID MV lamps, but I do know that standard phosphorised MV "white
dulux" works pretty well for photoresist. Might be better to get a clear
MV or the more expensive Philips 125W MV blacklight. Clear MV bulbs may
be available in the electrical section at supermarkets in the USA, but
here in Australia, clear bulbs are rare as hens teeth. I was forced to
buy a bulb with the phosphor coated.
As now everyone seems to be aware that photoresist are primarily
sensitivity to UVA, then buying specialized UV MV lamps will only waste
your money.
See figure 1 in,
http://www2.dupont.com/Imaging_Materials/en_US/assets/downloads/tech_bulletins/tb0169.pdf
My setup parameters are:
Lamp: 400W "dulux white" MV HID bulb,
Distance to PCB = 300mm
Materials in light: 3mm windows glass + 0.2mm inkjet Epson transparency film
Photoresist: "dry film" negative
Exposure time: 80 to 120 seconds
I would recommend 250W MV, as more suitable size for hobby work.
2006-09-28 by Steve
I don't know what you have against John Craddock, but I don't tolerate
bullying.
Derek, you are on moderated status.
Steve Greenfield
listowner
2006-10-03 by lists
In article <efenve+kenr@...>,
> Steve Greenfield
Probably because your comment appears to be to John's post, at least
that's how it appears to me viz:
> MONEY IS > MY "MO".
> Regards
> John C
2006-10-04 by Steve
--- In Homebrew_PCBs@yahoogroups.com, lists <stuart.winsor.lists@...>
> > Steve Greenfield
I spoke to him off list and we've got it all sorted out. I was upset
at Derek for baiting, and John for taking the bait. It didn't help
that one of my posts took days to show up, so it looked like I was
coming down on John while giving Derek a pass. I think it's sorted out
now.
Steve Greenfield
owner Homebrew_PCBs
