Circuit design for the motivated beginner: How to proceed?
2006-09-22 by bigjamma
Electronics are a new area of interest for me (my skills lean toward
mechanical design and fabrication, although I'm relatively
comfortable with programming). A CNC project has forced me to dive
head on into this world, and I'm in need of some tips to start out.
For example, I have a need to route the output of my drives on the
basis of a three-position switch: e.g. "Off | Mill | Lathe".
When "Mill" is selected, one group of output terminals become "live",
when "Lathe" is selected, a different group becomes live.
I could almost handle this if all outputs were 5V TTL signals.
Unfortunately, only 7 of the 9 are. The other two drive the motor at
up to 80VDC @ 20A. This is clearly beyond simple signal switching,
and I don't have the experience in power circuit design to figure out
how to proceed.
Another, perhaps simpler puzzler for me is how to take a 17VDC, 4A
unregulated signal and produce both a 5VDC & 12VDC regulated signal
from it. Presumably, it's a matter of finding suitable voltage
regulator ICs, but even approaching a simple circuit like this
completely solo has me a little nervous.
I realize this forum might not be the right place to post such
questions, so what is the appropriate place? While I'm open to book
suggestions (and am plowing through a ton right now), I really
appreciate the human interaction and practical advice that are best
found on forums. Any suggestions? Are there professionals out there
who offer design services for simple stuff like this at reasonable
prices?
Thanks in advance for any tidbits you're able to throw my way.
Re: [Homebrew_PCBs] Circuit design for the motivated beginner: How to proceed?
2006-09-23 by Brian Pitt
> how to proceed.
thats not good
disconnecting the motors while the system is powered up will blow
the drives pretty much instantly
you'd be better off getting the extra drives so you have one for
each motor ,using separate power switches for mill and lathe
and putting a switch box on the TTL signals only
Brian
"Nemo me impune lacesset"
RE: [Homebrew_PCBs] Circuit design for the motivated beginner: How to proceed?
2006-09-23 by Len Shelton
How many amps are you looking to pull through the 12 and 5 VDC lines?
>Len
2006-09-23 by Stefan Trethan
> how to proceed.
maybe contactors (relays) will be best, you won't need to switch rapidly
and very often?
Watch inductive kickback from the motor with any sort of switch, but
contactors are most tolerant to abuse.
Also make sure you don't kill the drivers, some stepper drivers like to
die if you disconnect the motor.
Yes, regulators, either linear or switching, depends on how much current
you need etc..
This is xactly the right place.
ST
Re: Circuit design for the motivated beginner: How to proceed?
2006-09-23 by derekhawkins
>up to 80VDC @ 20A.
Matches a Gecko G320 servo drive. Whatever, switching contacts in
the range 20A@80VDC would seem to be in order. But if it's the G320
then you can get by with a lower rating than that. IIRC, 20A is the
current it trips at so this is a peak rating not a continuous
rating. Also, will you ever be using 80VDC motors?
Once you've decided on the contact rating, I would recommend
115/120VAC relays/contactors driven by an appropriate solid state
relay. The SSR would only need TTL voltage levels for control. Here
is one being used to control a 3.5A 120VAC drill motor in my CNC
drill setup;
http://www.pbase.com/eldata/image/46673208
The wires on the left are in the 120VAC circuit and on the right is
the TTL level circuit. Note the part number and look it up on
Digikey's web site for zero crossing and snubber features. You
should be able to get by with one with a lower current rating based
on the relay/contactor coil current but keep the other features.
You should post this in the Electronics 101 forum if you haven't
done so already.
--- In Homebrew_PCBs@yahoogroups.com, "bigjamma" <bigjamma@...>
On Sat, 23 Sep 2006 11:04:00 +0200, Stefan Trethan <stefan_trethan@...>
> This is exactly the right place.
Oh sorry i didn't spot that this was not on E_101.
It belongs there of course ;-) (Thanks Derek for mentioning that)
ST
>thats not good disconnecting the motors while the system is powered
>up will blow the drives pretty much instantly
A separate 5VDC supply dedicated to control and a simple electronic
interlock can prevent switching in the presence of the 80VDC. That's
provided he goes for all TTL control as I suggested.
2006-09-23 by Steve
> done so already.
Yes, electronic design questions should be posted there, not here.
http://groups.yahoo.com/group/Electronics_101
Steve Greenfield
listowner of Homebrew_PCBs and Electronics_101
2006-09-23 by bigjamma
--- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@...> wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "derekhawkins" <eldata@>
> > done so already.
> Steve Greenfield
Thanks for the responses so far, everyone! I'll move the post over
there (had never heard of that group, so thanks).
Quick responses to the questions asked so far:
 - Yes, this is the Geckodrive G320 servomotor drive. I'll be using
72VDC motors with 8.3A continuous draw. My power supply is indeed
capable of producing 20A, so it's possible under heavy strain of a
single axis that a single drive could see 20A peaks.
 - For the 12V & 5V lines, I'd be looking at being able to supply at
least 1.5A, although the reality in use will probably be fractions of
an amp (logic circuitry, Gecko G100 pulse generator, limit switches
and encoders will be feed off of these supplies).
Re: [Homebrew_PCBs] Re: Circuit design for the motivated beginner: How to proceed?
2006-09-24 by Ron Yost
Hopefully Steve will allow me one post on this subject. I don't
belong to E101 as yet.
You may wish to join the CAD_CAM_EDM_DRO Yahoo group, too. This sort
of thing is right up their street, and there are folks there using
Gecko's in many different configurations.  Mariss Freimanis, the
designer/producer of Gecko drives, is a frequent contributor
there as well.
Here's the email add'y from his postings:
mariss92705@...
Good luck!
Ron Yost
2006-09-24 by Steve
> there as well.
I have not visited that list in quite a while, but when I read
regularly there they were -very- strict about staying on topic. Just
an FYI.
If you look in the Links here, under Related Lists and Forums, there
are a few CNC forums. Including two started as spin-offs from
Homebrew_PCBs.
CAD, CAM, EDM, DRO list
Very focused list about building many times of homebrew CNC machines.
http://groups.yahoo.com/group/CAD_CAM_EDM_DRO/
CNC PCB Design
Building and using a CNC mill to make PCBs and related parts. Started
by Dave Mucha as a companion list to Homebrew PCBs to move the CNC
specific stuff to it's own forum.
http://groups.yahoo.com/group/CNC-PCB_Design/
DIY-CNC
Building your own CNC machine. Mill PCBs, cases, parts, etc. Started
by Ballendo, a great companion group to Homebrew PCBs.
http://groups.yahoo.com/group/DIY-CNC/
Steve Greenfield
2006-09-24 by derekhawkins
There's also;
http://groups.yahoo.com/group/geckodrive
2006-09-25 by Steve
> There's also;
Then you should add it to the Links!
Steve Greenfield
