SolderPaste dispenser and Pick and Place.
2006-09-20 by Derek Barger
I thought some might be interested to see a couple of video of a
homemade solder paste machine and Pick and place.
These were done on a Taig with DenverCNC controller using Mach2 and my
modular work holding system.
Steve and I did this along time ago but just recently got the video up
on Steve's site.
http://www.ciciora.com/surface_mount.html
http://www.ciciora.com/picknplace.html
There is also a hotplate video melting the surface mount after the
pick and place was done.
Derek B.
www.hightechsystemsllc.com
Re: [Homebrew_PCBs] SolderPaste dispenser and Pick and Place.
2006-09-20 by Ross McKenzie
Hi Derek.
I don't know what the issue is...but I get a message saying "The
specified server cannot be found" on both of these links after I attempt
to start (after having read the introductory text).
Ross McKenzie
ValuSoft
Melbourne Australia
> on Steve's site.
> <http://www.ciciora.com/surface_mount.html>
> <http://www.ciciora.com/picknplace.html>
> Derek B.
Hi Ross,
I can send you the videos directly the Pick and place is  6meg the
solder paste is 2 meg and the reflow with a hotplate is 1.5meg.
I have had this happen myself when too many people are looking at a
site or if my internet connection is doing too much.
Derek B.
On 9/19/06, Ross McKenzie <valusoft@...> wrote:
> Hi Derek.
> Regards,
> Ross McKenzie
> ValuSoft
> Melbourne Australia
> > on Steve's site.
> > Derek B.
2006-09-20 by Stefan Trethan
On Wed, 20 Sep 2006 03:13:37 +0200, Derek Barger <Denvercnc@...>
> on Steve's site.
> Derek B.
That's great!
I like the way you position the component on the suction needle, i have
not thought of that!
ST
Thanks for the offer Derek. I will try again later. My ISP has limits on
email attachment sizes.
Ross
Derek Barger wrote:
> Hi Ross,
> Derek B.
> <mailto:valusoft%40optusnet.com.au>> wrote:
> > Hi Derek.
> > Regards,
> > Ross McKenzie
> > ValuSoft
> > Melbourne Australia
> > > on Steve's site.
> <http://www.ciciora.com/surface_mount.html>>
> <http://www.ciciora.com/picknplace.html>>
> > > Derek B.
> Photos:
> <http://groups.yahoo.com/group/Homebrew_PCBs>
> <http://groups.yahoo.com/group/Homebrew_PCBs_Archives/>
> > Yahoo! Groups Links
2006-09-20 by Leon Heller
Sent: Wednesday, September 20, 2006 12:54 PM
Subject: Re: [Homebrew_PCBs] SolderPaste dispenser and Pick and Place.
I just played them OK. Very interesting.
Leon
Leon Heller, G1HSM
Suzuki SV1000S motorcycle
leon.heller@...
2006-09-20 by WT
Hi, Derek.
Nice solder paste and pick & place machine. Very interesting.
Can I ask you to provide additional info and pictures of the solder paste machine? In particular, how the solder paste mechanism works. Also, details on what was used for the solder paste dispensing (needle, pump, motor, driver, software and timing control, etc.)?
I intend to use it to make a DIY paste (glue actually) dispensing in a folding and gluing machine for making boxes. Can I communicate with you in private for additional info?
Thanks in advance.
Weedy
  Sent: Wednesday, September 20, 2006 9:13 AM
  Subject: [Homebrew_PCBs] SolderPaste dispenser and Pick and Place.
  on Steve's site.
  Derek B.
RE: [Homebrew_PCBs] SolderPaste dispenser and Pick and Place.
2006-09-20 by Dave King
Ross
Probably already been suggested but why not put them on youtube or google
video
then you won't get hassled by isp about bandwidth useage. Or has the rush
for
everyone to view subsided? ;-]
How long does it take to do your board for each op (parts, paste,bake)?
Was the machine running full speed?
Dave
> Regards,
> Ross
> Derek Barger wrote:
> > Hi Ross,
> > Derek B.
> > > Hi Derek.
> after I attempt
> > > Regards,
> > > Ross McKenzie
> > > ValuSoft
> > > Melbourne Australia
> Mach2 and my
> the video up
> > > > on Steve's site.
> > > > Derek B.
> > Photos:
> > > Yahoo! Groups Links
> and Photos:
Hi Weedy,
It has been awhile since we have done this so if I get some details
wrong I will correct them latter. The solder paste is easier than than
the pick and place. We got some supplies from a manufacturer. The
needles and the O ring syringe cap with black hose.
CNCed the bracket to hold the solder paste syringe.
The controls are relatively simple a microprocessor or lots of timers
are need to control the solder paste and Pick a place.  We used a
portable air tank the type that you air up tires with that full you
can run quite a few boards before refilling. Less noise in the
basement. The air goes through a pressure regulator that is set to the
recommend pressure for the solder paste being used. I believe we set
this to about 10psi for this particular type. Next is a air solenoid
that is controlled by the microprocessor. At the right time the Mach2
sends a signal from the DenverCNC controller to the microprocessor to
fire the solenoid. The micro controls the timing in how long the air
solenoid is on. You can hear the second air solenoid release the
pressure after the first is closed. Mach2 will wait until the solder
has been dispensed then move to the next g-coded pad. If the pad is
very large it will double or triple shoot the pad for the proper
amount of solder.
By the way Steve was able to make a program that did most of the work
locating the pad location from the Eagle file. There was some hand
editing that still had to be done. Eagle doesn't do a very good job in
the order it makes the pads. That is why it does a lot of rapids to
other pads. If we had spent more time we could have optimized the
code.
The pick and place is more challenging. A vacuum and pressure is
needed this required quite a few solenoids, vacuum pump and the
portable air tank plus a 4th axis to position the surface mount parts.
We made a tube and stepper bracket. The tube mounts to the stepper
directly at the bottom the air/vacuum line is mounted the needle goes
on the end.
The stepper is used to orient the part to the board. It also functions
in the centering of the part. The vacuum of course is used to is used
to pick up the part then the air pressure from the tank is regulated
to a few psi. This is pulsed at a milli second to get rid of the
vacuum and push the part off of the needle. Miss alignment was not as
big a problem as it was thought it would be. You do have to be careful
moving the board to the hotplate some of the chip got bumped out of
place. The solder paste will pull them back in to position if they are
not out by very much. You can see the solder turn from a dull gray to
a shiny silver when it melts.
A lot of the parts where made from surplus. The vacuum pump was
something we had laying around. Very noisy. Solenoids were surplus.
Brackets and adapter were machined by us. Micro was an Atmel for some
of the project. Mach2 was used to run the g-code. A  macro in Mach 2
was made to signal the Atmel. Overall it was a very sucessfull
project. It is still used today for other prototype boards.
You can contact me anytime by email.
Derek
On 9/20/06, WT <pharmapack@...> wrote:
> Hi, Derek.
> Thanks in advance.
> Weedy
>   ----- Original Message -----
>   From: Derek Barger
>   on Steve's site.
>   Derek B.
2006-09-20 by Sander Pool
When I tried to watch the videos my graphics driver actually crashed. It
reverted to VGA, an interesting experience. I've watched thousands of
videos in the last 10 years and they have caused hangs, blue screens and
crashes but never this. Cool :)
    Sander
PS I updated the graphics driver and will try again later
Dave King wrote:
> Ross
> video
> for
> Dave
> > Regards,
> > Ross
> > Derek Barger wrote:
> > > Hi Ross,
> > > Derek B.
> > > > Hi Derek.
> > after I attempt
> > > > Regards,
> > > > Ross McKenzie
> > > > ValuSoft
> > > > Melbourne Australia
> > Mach2 and my
> > the video up
> > > > > on Steve's site.
> <http://www.ciciora.com/surface_mount.html>>>
> <http://www.ciciora.com/picknplace.html>>>
> > > > > Derek B.
> > > Photos:
> <http://groups.yahoo.com/group/Homebrew_PCBs>>
> <http://groups.yahoo.com/group/Homebrew_PCBs_Archives/>>
> > > > Yahoo! Groups Links
> > and Photos:
> > Yahoo! Groups Links
Hi Dave,
I think the rush is over.
We where trying for a ramp up and ramp down on the temperature for a
heat soak then cool off procedure. Using a temp sensors and a feedback
loop we where able to control it somewhat. The problem with the hot
plates is they are not made for precise heating. Some areas are hotter
than others and there are other problems with hot plates.  That is why
you see the board being moved is because of the hot spot. A toaster
oven maybe more controllable. Right now it is not perfect but it works
and we have had no problems with any chips. They maybe making
components more robust these days.  I am sure our low humidity helps.
The Taig machine was not moving at full speed. The motor we where
using were smaller than we normally use. Just what we had laying
around at the time. We also slowed it down so not to cause any sudden
movement that would drop the surface mounts. The vacuum pump was not
optimal for the application. A better pump and a storage tank would
have allowed a lot fast movement.
Derek B.
On 9/20/06, Dave King <KingDWS@...> wrote:
> Ross
> video
> for
> Dave
> clipped
Hi Sander,
It was made with Windows Movie Maker so I don't know what the problem is :)
Hope it works better latter.
Derek
>     Sander
> Dave King wrote:
> > Ross
> > video
> > for
> > Dave
> > > Regards,
> > > Ross
> > > Derek Barger wrote:
> > > > Hi Ross,
> > > > Derek B.
> > > > > Hi Derek.
> > > after I attempt
> > > > > Regards,
> > > > > Ross McKenzie
> > > > > ValuSoft
> > > > > Melbourne Australia
> > > >clip
Re: SolderPaste dispenser and Pick and Place.
2006-09-20 by derekhawkins
I thought smd-coordinate.ulp gave you this on a silver platter?
Sort the .smt and .smb output files on one axis.
--- In Homebrew_PCBs@yahoogroups.com, "Derek Barger" <Denvercnc@...>
Hi Dave King.
Ross here. I am the one having difficulty accessing DEREK's videos. I am
not the one serving the videos up to the readership.
Never mind. But thanks for the suggestion...for Derek <g>.
Ross
Dave King wrote:
> Ross
> video
> for
> Dave
> > Regards,
> > Ross
> > Derek Barger wrote:
> > > Hi Ross,
> > > Derek B.
> > > > Hi Derek.
> > after I attempt
> > > > Regards,
> > > > Ross McKenzie
> > > > ValuSoft
> > > > Melbourne Australia
> > Mach2 and my
> > the video up
> > > > > on Steve's site.
> > > > > Derek B.
> > > Photos:
> > > > Yahoo! Groups Links
> > and Photos:
> > Yahoo! Groups Links
Re: [Homebrew_PCBs] Re: SolderPaste dispenser and Pick and Place.
I just went to the Cadsoft website under ulp I still don't see the
file with the name smd-coordinate.ulp. You are probably right there is
better way to do it. If I ever find this ulp I will give it to Steve
to try. At the time that we did it there was nothing we found that was
available. You need 2 different reference points the center of the
part for pick and place and the center of each pad for solder paste.
One axis sorting does not give you the optimal g-code with the fewest
moves. Pads right next to the other pad will be skipped and come back
to latter. An intelligent sort that can handle 2 axises at the same
time is what is needed.
Derek
www.HighTechSystemsllc.com
Lol that will teach me for trying to respond while my wife is nagging me ;-]
Dave
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com]On Behalf Of Ross McKenzie
> Sent: September 20, 2006 3:48 PM
> Hi Dave King.
> Regards,
> Ross
> Dave King wrote:
> > Ross
> or google
> > video
> has the rush
> > for
> > Dave
> has limits on
> > > Regards,
> > > Ross
> > > Derek Barger wrote:
> > > > Hi Ross,
> > > > Derek B.
> > > > > Hi Derek.
> > > after I attempt
> > > > > Regards,
> > > > > Ross McKenzie
> > > > > ValuSoft
> > > > > Melbourne Australia
> > > Mach2 and my
> > > the video up
> > > > > > on Steve's site.
> mount after the
> > > > > > Derek B.
> Files, and
> > > > Photos:
> > > > > Yahoo! Groups Links
> > > and Photos:
> > > Yahoo! Groups Links
> and Photos:
2006-09-21 by Leon Heller
Sent: Thursday, September 21, 2006 12:27 AM
Subject: Re: [Homebrew_PCBs] Re: SolderPaste dispenser and Pick and Place.
The Pulsonix software I use can output a pick and place file, here is part
of one for one of my boards:
Ref    Part Name          Side   Placement Centre    Rotation
IC1    16F88              Top    (363.22,570.23)     0
CONN1  2X1                Top    (349.92,591.18)     90
CONN2  3X1                Top    (343.61,558.16)     0
CONN3                     Top    (343.61,547.37)     0
IC3    78L05              Top    (350.52,585.47)     270
C1     C1                 Top    (354.33,556.89)     0
C2                        Top    (356.24,539.75)     180
C3                        Top    (361.95,539.75)     180
C4                        Top    (356.24,542.29)     180
C5                        Top    (361.95,542.29)     0
Leon
Leon Heller, G1HSM
leon.heller@...
2006-09-21 by Derek Barger
Sure that looks fine for the center that is easy. Your first chip can
be an 18, 20, 28 pin package. You have to find every pin location for
that chip to put the solder paste down. That is the center of the pad
most of the time. Will that program do that and does it work with
Eagle? Looks like a good program but since the Eagle is paid version
we need to use it.
Derek
> Leon
> Leon Heller, G1HSM
> leon.heller@...
>> Place.
>> part
Sent: Thursday, September 21, 2006 7:04 AM
> we need to use it.
I wish people wouldn't 'top-post'! 8-( I've corrected it.
Pulsonix is the PCB software I use, and that output is one of the standard
output reports. It's not suitable for solder paste deposition, I think that
is done with a stencil by most PCB suppliers as it gives much better control
of the thickness and area covered and is much faster. I think a report could
be generated that is suitable for CNC placement of solder paste.
Leon
Leon Heller, G1HSM
leon.heller@...
2006-09-21 by WT
Hi Derek,
Thanks for the very informative message below.
I am finishing the CNC retrofit of my China made ZAY7032 Milling Machine and can try the method you did for the Solder Paste dispensing.
I will get in touch with you then if and when I need additional info.
Again, my thanks.
Weedy
  Sent: Thursday, September 21, 2006 1:41 AM
  Hi Weedy,
  amount of solder.
  code.
  on the end.
  Derek
  > Hi, Derek.
  > Thanks in advance.
  > Weedy
  > From: Derek Barger
  > on Steve's site.
  > Derek B.
2006-09-21 by Derryck Croker
Um, so how about trimming the bits of the message that you're not
addressing in your reply? I agree that top-posting is wrong, but when
one is then faced with having to scroll through a load of irrelevant
text to find the reply, especially when it says "me too"...
I know that the usual reason given is that the whole context can be
seen, but isn't that what archives are for??
Cheers
Derryck
2006-09-21 by derekhawkins
It comes with the product (ULP folder), it's in at least versions 4.09 -
 4.16. Just choose File/Run then choose it. Should give you X/Y
coordinates of the centers of all SMD pads on top (.smt file) and
bottom (.smb file) layers.
I know, my Excellon to G-code converter has such a sort. Wrote it
myself.
2006-09-22 by sciciora
<snip>
This seems to give you X and Y coords, but does not tell you the pad
size.  We needed the pad size info to determine how much solder paste
to put on each pad.  But this wasn't the tricky part; the pick and
place was a lot harder.
Not always faster! :-) I've tried all sorts of things, and having our
code report distance traveled.  Even then, we found that while one
sort may have less distance traveled, it might actually take longer to
do on the mill than a different sort with a longer distance traveled.
 If you Google "Traveling Salesman problem" you will most likely get
overwhelmed with academic studies... Even simple algorithms such as
"the next pad is the one closest to the current pad" are not always
the best.  If I were to spend more time on this, I think I would have
my program try several different algorithms, starting at random pads
on the board, and pick the one with the shortest distance traveled.
More of a Monty Carlo (yea, I know it's miss-spelled) type approach.
But I probably won't, because too many interesting projects, not
enough time...
Over-all, this was a very fun project that we threw together in less
time than some people spent arguing over which is the best way to do
such a thing.  And it actually came in handy when we had a crash
project developing the battery management system for the Lithium Ion
powered (www.a123systems.com) world's fastest electric motorcycle
(some videos on my web site as well).  Due to the extreme time
constraints, we didn't know all the component values until it was too
close to race day to have a contract manufacture assemble the boards
for us.  While the current implementation is not a heck of a lot
faster than assembling by hand, it kept us from going crazy putting on
the over 100+ surface mount components on approximately 40 boards we
assembled.
From my experience, if you are going to build 10+ of a board, and have
the time, it makes sense to have a contract manufacture do the
assembly for you.  They can have stencils made up, have all the neat
screen printing equipment, faster pick and place, better regulated IR
reflow ovens, etc.  But for prototyping just a few boards, or
extremely tight deadlines, the DIY approach can have some merit.  I
expect that in the future, I'll use the CNC Solder paste dispensing on
boards with 100+ components (less than that, it will be faster by
hand).  As for the pick and place, well, it takes a fair amount of
effort to setup.  For just one or two prototype boards, it is usually
easier to stuff by hand.  Especially if you build a section, test it,
debug it, move on to the next section.  If I have to make between 5
and 10, I'll probably take the time to set up the pick and place.  Any
more than 10, I'll most likely contract it out.
I guess the biggest thing I learned from this project is that surface
mount is not as scary as I first thought.  I wish I would have just
tried it a lot sooner.  You really don't need fancy equipment, even
like the stuff we built.  A good pair of tweezers, and if you are over
35, you may need something like "opto-visors" to help inspect your work.
Well, back to the day job, which is the main reason why I didn't post
about this sooner,
- Steven Ciciora
<snip>
