Stupid- simple tip but worth it ....
2006-09-13 by lcdpublishing
Hi guys,
Many of us make double sided boards and have to create vias from one
side to the other. Often it's a piece of wire or a cut-off leg of a
component.
For power routings I just realized that a header pin is great!  During
diagnostics, testing, etc., it's always handy to have a place to clip
on a test lead for checking voltages etc.  A header pin allows for
that and creates the via.  Just a simple realization this morning, but
in case you have not thought about it, there you go!
Chris
Re: Stupid- simple tip but worth it ....
2006-09-13 by derekhawkins
>component.
First option to explore would be the leg of an existing installed thru
hole (TH) component (headers included). That's why the move from TH to
SMD doesn't always reduce the amount of hole drilling for the
homebrewer as drastically as some would have us believe. SMD needs more
forced or dedicated vias.
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
<lcdpublishing@...> wrote:
RE: [Homebrew_PCBs] Re: Stupid- simple tip but worth it ....
2006-09-13 by Tony Smith
I think he meant you can use it as a test pin, ie clip an alligator clip to
it to take measurements.
Might not be overly successful, real test pins are flared at the end to stop
the clip falling off...
Tony
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of derekhawkins
> Sent: Thursday, September 14, 2006 2:47 AM
> Subject: [Homebrew_PCBs] Re: Stupid- simple tip but worth it ....
> >Often it's a piece of wire or a cut-off leg of a component.
> installed thru hole (TH) component (headers included). That's
> why the move from TH to SMD doesn't always reduce the amount
> of hole drilling for the homebrewer as drastically as some
> would have us believe. SMD needs more forced or dedicated vias.
> Be sure to visit the group home and check for new Links,
> Files, and Photos:
Re: [Homebrew_PCBs] Re: Stupid- simple tip but worth it ....
2006-09-13 by Stefan Trethan
On Wed, 13 Sep 2006 19:26:45 +0200, Tony Smith <ajsmith@...>
> to
> stop
> Tony
Who says you can not simply make test leads with header sockets?
Much better than a clip lead.
You can also buy round solder pins that are excellent for this purpose,
with matching female connectors.
ST
> > clip to it to take measurements.
> at the end
> > to stop the clip falling off...
> > Tony
> this purpose, with matching female connectors.
Sheesh.  You can make your test pins out of barbed wire for all I care.
Just don't complain when the leads fall off after you bump it.
Tony
On Wed, 13 Sep 2006 20:11:09 +0200, Tony Smith <ajsmith@...>
> Tony
I'll have you know in lotsa high quality lab instruments the test pins are
normal square header pins (0.64mm).
I'm also not the one complaining, i'm the one with the soldering iron who
can make a couple of test leads ;-)
There is even a whole lab lead system based on that connector, you can
readily buy leads and probes and adapters and hooks and clips and... the
whole lot in miniature just like with 4mm (and 2mm) round plugs, from
reputable manufacturers such as hirschmann, and others. Tektronix uses
them for example in logic analyzers. They don't seem to agree that the
leads will just fall off if you bump them.
If you think a alligator clip is better than a matching plug/socket
connection.. well..
To the reasonable people who might want to make such leads, use better
quality sockets like used by berg connectors. The cheap sockets are one
sheetmetal part, stamped and folded cleverly so that part of the shape
forms the contact spring. Of course this is not an ideal spring, so it
will get tired after some use. If you find a high quality connector you
will notice a separate piece of spring material used which lasts much
longer.
You know, if you criticise some post you should really make sure your
facts are sound, ideally beforehand. I would save me time not having to
defend my opinion.
ST
2006-09-13 by Sander Pool
I often use .1" pitch Berg connectors as test points. Very convenient. I
use a flexible wire with a Berg connector on one end (shrink tubing
around it to prevent shorts) and bare wire on the other that I grab with
an alligator or other clip.
In fact when I put together my M128 board from http://www.bdmicro.com I
put headers in that are long enough that the bottom part fits in a
breadboard and the top ones accept connectors. Sweet.
    Sander
>> Tony
> connection.. well..
> longer.
> defend my opinion.
> ST
My point was that the leads of existing installed TH components are
potential vias and test pins. A scopes probe will probably hold better
to a resistor lead than an upright header pin.
Just a simple suggestion guys - no need to get excited.   My point
being that while you can use the leads of resistors and other
components to make vias, sometimes you need a via where there isn't
such a component. Normally, I just stick a piece of wire in the
hole, solder it on both sides, clip it off and move on.
However, when measuring voltages, I like to clip (with an aligator
clip) my VOM to the board, then probe for voltages or whatever. I
don't normally think to add some sort of test points on my boards -
crap, I can barely make a board!
Thinking a bit further, even using a scope this is handy to have.
While ground pins are handy, sometimes the positive voltage pins are
handy too.
I can understand the need for something better than a header pin,
however, I always seem to have them laying around and they are a bit
more stiff and sturdy than typical cut-off leads and such.  So, that
was my thinking.
Chris
2006-09-14 by derekhawkins
Header pins make the best homebrew vias IMO. All my dedicated vias are
clipped header pins. However, a dedicated via is always a last resort.
2006-09-14 by Tony Smith
> all I care.
> > Tony
> test pins are
> soldering iron who
it
> connector you
> lasts much
> longer.
> sure your
> having to
> defend my opinion.
> ST
As I said, sheesh.
Hobbiests are cheap and use dodgy stuff which doesn't work all that well at
times.  Not exactly the newsflash of the century.
Good thing I didn't insult your mother, I'd be still reading your response.
Chill out, dude.  You're either smoking too much wacky baccy or not enough.
Tony
2006-09-14 by Stefan Trethan
On Thu, 14 Sep 2006 14:40:56 +0200, Tony Smith <ajsmith@...>
wrote:
> As I said, sheesh.
> at
> response.
> enough.
> Tony
What are you talking about? Have you actually read my post?
I clearly established header pins as test pins are _not_ dodgy stuff,
which is what you claim as i understand it.
If you say tektronix uses dodgy stuff, well, that's an opinion too but you
are probably standing alone there.
I'll just ignore you from now on for apparent lack of reason. My claim
that square test pins make fine test points was sufficiently established,
while there isn't many arguments coming from you apart from "it'll all
fall off".
ST
> > As I said, sheesh.
> all that well
> > at
> > response.
> baccy or not
> > enough.
> > Tony
> dodgy stuff,
> opinion too but you
> My claim
> established,
> "it'll all
> fall off".
Yeah, header pins, leaving the component lead long, works fine.  As I said,
hobbiests are cheap.  And they use the cheapest clip going, being the
alligator clip.  When you pick up the board and turn it over, half the time
they either fall off or short against something else.
Using header pins as vias can lead to solder joint failure.  Won't stop
people doing it, but at least you know there's a possibility for failure.
If you've got better stuff, go use it.  Some people don't use test pins at
all.  Some people have never seen pogo pins.  Most don't have a scope.
It's called homebrew for a reason, ghetto tech might be a better word.
Here's a good ghetto example - http://uanr.com/sdfloppy/.  Work?  Sure.
Ghetto?  Sure.  Possible problems?  Sure.  Vibration, crosstalk, all the fun
stuff.
My point was simply real test pins are a funny shape for a reason.  Why this
surprises you or why you actually care enough to respond is beyond me.
Tony
On Thu, 14 Sep 2006 19:09:15 +0200, Tony Smith <ajsmith@...>
> said,
> time
> at
> fun
> stuff.
> this
> Tony
Ok, when i meet a Fluke or Tektronix or Siemens or Norma engineer i will
tell them that they are doing it all wrong and square pins are not
acceptable for test pins. I'm not sure if they will be insulted when i
tell them they are ghetto technicians ;-).
I'll just tell them the great Tony Smith has said so, and he must know
after all, i'm sure they'll immediately see their folly.
No many people will indeed not have seen a pogo pin, because they are
utterly useless for anything other than series production testing. We were
talking about test _pins_, not _pads_, you do remember that?
I care enough to respond because i can't stand it when people write
nonsense and insist on it without giving any decent reasons, let alone
proof.
ST
> better word.
> Work?  Sure.
> crosstalk, all the
> > fun
> > stuff.
> reason.  Why
> > this
> beyond me.
> > Tony
> engineer i will
> insulted when i
> must know
Yep, while you're at it, ask them if they use alligator clips.  Or do they
use parrot clips, which tend to hang on better.
Tony
On Thu, 14 Sep 2006 20:02:59 +0200, Tony Smith <ajsmith@...>
> they
> Tony
I would expect they use the _proper_ _matching_ _receptacle_ which anyone
can easily do with little or no cost, certainly less than an alligator
clip.
ST
> clips.  Or do
> > they
> > Tony
> which anyone
> alligator
> clip.
> ST
Sigh.
And my original comment was alligator clips tend to fall off striaght pins.
Look folks, round and round it goes, where it stops only ST knows.
Tony
On Thu, 14 Sep 2006 21:21:47 +0200, Tony Smith <ajsmith@...>
wrote:
> Sigh.
> pins.
> Tony
Any my response to that was that alligator clips are the wrong tool to go
about the job, and that suitable sockets should be used, which reply you
attacked by saying they'll fall off as well.
You know this is email, it is easy to go back and look what someone said,
so don't try to turn around the facts:
Tony:
> > > I think he meant you can use it as a test pin, ie clip an alligator>
> > > Might not be overly successful, real test pins are flared> > at the
> end> > to stop the clip falling off...
> > > Tony
ST:
> > You can also buy round solder pins that are excellent for> this
Tony:
> Tony
My point was, and is, that square header pins are excellent test pins,
especially if you use the proper (free to build, cheap to buy) test lead
to probe them (with a 0.64mm socket on the end). Examples of very
reputable manufacturers show they they too believe square pins are
suitable test pins. You subsequently claimed use of square pins means poor
homebrew quality (remember: ghetto tech).
If you would just believe that square header pins are accepted industry
standard for test pins, and not a botch job, and that alligator clips are
simply not the most suitable tools to use on them, then i wouldn't have to
repeat myself all the time.
ST
2006-09-15 by Tony Smith
> > Sigh.
> off striaght
> > pins.
> > Tony
> wrong tool to go
> which reply you
> someone said,
> Tony:
> an alligator>
> flared> > at the
> > > > Tony
> ST:
> Tony:
> all I care.
> > Tony
> test pins,
> buy) test lead
> pins means poor
> accepted industry
> alligator clips are
> wouldn't have to
Must be a peculiar property of the internet where two people who agree on
something can go around and around and around and around and bore the rest
of the world shitless.  Or decides that Poland needs invading or something.
Once more, slowly, with picture.  In colour too!
Exhibit One:
http://www.jaycar.com.au/products_uploaded/productLarge_5515.jpg.  Look
children, a component.  If you have a double sided boards, and you solder
both sides of a lead, you can made a via.  If you don't cut the lead short,
you can use it as a test pin.
Exhibit Two:
http://www.jaycar.com.au/products_uploaded/productLarge_1183.jpg.  An
alligator clip, so called because it looks like the jaws of one.  Ain't that
cool?  You can uses these to connect to your test pins.  Sweet!
Exhibit Three & Four:
http://www.jaycar.com.au/products_uploaded/productLarge_1487.jpg,
http://www.jaycar.com.au/products_uploaded/productLarge_7558.jpg.  Don't
like using component leads?  A bit too ghetto?  Bit flimsy for you?  Well,
try these!
Exhibit Five: http://www.bbc.co.uk/parenting/images/300/bw_crying_girl.jpg.
This is you after you clip an alligator lead to exhibit one, three or four
and it goes wrong.  The smoke really gets in your eyes after it leans over
and shorts something out, and having to clip the damn things back on all the
time gets annoying.  Thank $deity for teddy, he understands.  (Yeah, black
and white.  Sorry!)
Exhibit Six:
http://www.jaycar.com.au/products_uploaded/productLarge_1189.jpg.  Or you
could use these.  Don't need no stinking test pins, you can hook then
direcly to the leg of an IC if need be.  Won't short and won't fall off.
Yay!
Yes, alligator clips suck.  Yes, there are better things.  Gosh, that's what
I said, wasn't it?  Alligator clips fall of pins?  Which is why the message
is titled 'stupid simple tip', not 'this is the way you are supposed to did
it like all the research labs and manufacturers and people with letters
after their names do'.  Yeah, and they get cheap sometimes too.
No doubt ST will respond with a carefully constructed response that says
exactly the same thing as this one, advancing the field of Homebrew PCBs
exactly nowhere.  Imagine what would happen if it was something important.
Meantime, I'll go and do something more interesting, like watching the grass
grow.  (hmm, needs mowing.)
Far out, brussel sprout.  I'll have what you're smoking.
Tony
(Yeah, I've too much free time)
2006-09-15 by Stefan Trethan
On Fri, 15 Sep 2006 19:05:20 +0200, Tony Smith <ajsmith@...>
Ha! that sounds to me damn close to someone invoking Godwin's Law! :-)
Look, i don't care if you admit you were wrong or if you claim i
misunderstood you, as long as you agree square header pins can very well
make decent test pins everything is fine with me.
ST
2006-09-15 by lcdpublishing
Well, seeing as I started this whole mess, it's time again for me to
voice some comments and opinions...
Aligator (or some folks call them crocidile) clips are just fine and
dandy for me.  They are what I can purchase, I know how to use them
(even for purposes that are frowned upon).  I use the type with the
insulation on them.  Yes, they pop off at times, yes I know that, so
I deal with it.  If I had other types of clips on hand, I would
probably have them too.
I have seen square pins used for "test points" on a variety of PCBs,
at least that is what I think they are for.  Usually it's just a
square pin poking up through the PCB - sometimes with a marking,
sometimes not.  I figured if others use it for what I believe to be
test pins, AND by combining it's function to that of a via, you get
two "Features" out of one device.
I have also seen other things used for test points, I don't know
what they are called, but they are round and have a head on it -
sort of looks like a nail.  I can see the benefit to those, but
don't have them on hand, nor do I intentionally purchase them -
don't know what they are called (Posts ?).
Otherwise, how is everyone doing with their ink jet systems?
Chris
2006-09-20 by Tony Smith
> claim i misunderstood you, as long as you agree square header
> pins can very well make decent test pins everything is fine with me.
> ST
Well, back from watching the grass grow.  Very exciting.  Still need mowing.
Why can grass shrink when it rains?  More exciting than this thread anyway.
Yeah, round pin, square pin, component leg, triangular pin, one made from
barb wire, an (now, pay attention) alligator clip will short out or fall off
them all eventually.  Big deal.
As I said, nothing to go off and invade Poland for.
That's why I use the hook type clips.  Downside is they cost more, and only
seem to come in red & black.  If you have a different clip that just happens
to work superbly on a square pin, well, ain't that great.  I'll bake you a
cake in the shape of it.  Or Poland.
Tony
2006-09-20 by Stefan Trethan
On Wed, 20 Sep 2006 21:04:22 +0200, Tony Smith <ajsmith@...>
> mowing.
> anyway.
> off
> only
> happens
> a
> Tony
I'll not try any more, you seem incapable of processing what i say and you
just repeat the same thing over and over, so it's really no fun. You may
want to discuss this obsession about invading Poland with your consultant
though. ;-)
ST
> > only
> that just
> > happens
> I'll bake you
> > a
> > Tony
> i say and you
> fun. You may
> your consultant
> though. ;-)
> ST
Alligator clips tend to suck.  What's hard about that?
Tony
