tubes
tubes
2006-09-02 by adastra_2001
Lets start with what I don't really want. I don't want to make my own
library parts. Are there any free or low cost (<$300) PCB/Schematic
programs that have part libraries of tubes? I want to draw a schematic
and route a board with vacuum tubes (Valves)? Any ideas?
Re: [Homebrew_PCBs] tubes
2006-09-02 by Stefan Trethan
On Sat, 02 Sep 2006 15:32:17 +0200, adastra_2001 <adastra_2001@...>
Have you tried making the parts already or are you just afraid of the
unknown?
I make all my own libraries, always. If there is a useable footprint
already existing it always still needs changes anyway.
You will rarely find someone halfway serious with making PCB who is not
having his own libraries.
So instead of looking for a program that has tube footprints, i believe
you should rather look for a program that has a decent way of editing
footprints.
ST
2006-09-02 by Leon Heller
Sent: Saturday, September 02, 2006 2:32 PM
Subject: [Homebrew_PCBs] tubes
Just create your own parts, it shouldn't be difficult. It's very easy with
the Pulsonix software I use but it cost a lot more than $300.
Leon
Leon
Re: tubes
2006-09-02 by derekhawkins
Looks like there are some Eagle shared user tube related libraries
here;
http://www.cadsoftusa.com/download.htm
Follow the Libraries link.
--- In Homebrew_PCBs@yahoogroups.com, "adastra_2001"
<adastra_2001@...> wrote:
Re: tubes
2006-09-03 by adastra_2001
--- In Homebrew_PCBs@yahoogroups.com, "derekhawkins" <eldata@...>
> here;
> <adastra_2001@> wrote:
>I thank you for the link regarding Eagle Libraries. I have
downloaded them and I will try them. As far as the reluctance to make
my own library parts, yes that has a little to do with it as well as
the difficulty for me to make the physical measurements needed for a
tube socket that will work in a PCB program.
Re: tubes
2006-09-03 by derekhawkins
>As far as the reluctance to make my own library parts, yes that has
>a little to do with it as well as the difficulty for me to make the
>physical measurements needed for a tube socket that will work in a
>PCB program.
Heard you loud and clear. Nobody wants to reinvent the wheel but
sooner or later making your own parts from time to time becomes
necessary.
Re: tubes
2006-09-03 by jdizzlemynizzal
> --- In Homebrew_PCBs@yahoogroups.com, "derekhawkins" <eldata@>
> > here;
Circuit Maker 2000 Pro comes with tube parts for SPICE analysis. The
program is so old now though, that it isnt worth buying it from one of
those resailers. I was lucky to get my version from a former
university EE department.
Re: tubes
> >PCB program.
> necessary.
Yeah i'm always having to create my own libraries, danm companies want
7,000 from you so that you can retrieve databases that you can create
on your own for free. Then again time is money.
Re: [Homebrew_PCBs] Re: tubes
2006-09-03 by Leon Heller
Sent: Sunday, September 03, 2006 5:18 PM
Subject: [Homebrew_PCBs] Re: tubes
>> here;
You should be able to find the relevant dimensions for standard valve
sockets without too many problems.
Leon
Leon Heller, G1HSM
SV1000S motorcycle
leon.heller@...
2006-09-04 by YD
--- Leon Heller <leon.heller@...> wrote:
> From: "adastra_2001" <adastra_2001@...>
> PCB/Schematic
> related libraries
> >> here;
> "adastra_2001"
> Libraries. I have
> reluctance to make
> with it as well as
> for standard valve
> Leon
Are there still sockets for PCBs? All I find around
here are chassis mounts. The only time I ever made a
tube equipment with a PCB I just placed the connecting
pads at the edge. Another possibility would have been
making the mounting hole in the PCB and surround it
with the pads.
- YD.
Do You Yahoo!?
http://mail.yahoo.com
Re: tubes
2006-09-04 by adastra_2001
> > PCB/Schematic
> > related libraries
> > >> here;
> > "adastra_2001"
> > Libraries. I have
> > reluctance to make
> > with it as well as
> > for standard valve
> > Leon
> with the pads.
> - YD.>
yes tube sockets for PCB are still available. Both 9 pin and Octal.
Try: http://www.partsconnexion.com/catalog/tubesockets.html other
places have them too.
Re: tubes
2006-09-04 by jdizzlemynizzal
> > PCB/Schematic
> > related libraries
> > >> here;
> > "adastra_2001"
> > Libraries. I have
> > reluctance to make
> > with it as well as
> > for standard valve
> > Leon
> with the pads.
> - YD.
> Do You Yahoo!?
 I remember seeing a webpage site that used hot glue to make a socket
for a tube. Basically he made the socket by getting a plastic cube
cutting drilled holes for leads and then placed the tube into the cube
and pord hot glue in. He then removed the cube, and sucesfully made a
really crappy tube socket.
Re: tubes
> > here;
Simple measurement technique:
Take a bottle of ink and place on leads of tube. Take a piece of paper
and blot the tube down on to it. Creating the part really isnt that
hard its just annoying, which is the next step: Take whatever you use
to measure angle degrees and write down the degrees. Then measure the
radius of 1 pin on one side to the other side. Enter the left pin as
negative and the right pin as positive. Remember to set the origin as
0,0 for a the middle, invisible, refrence pin. A free program called
ProgeCAD will let you enter data like this, just remember to enter a
negative angle when going clockwise. Save as DXF or whatever and then
import. Its REAL simple and will save you 300 dollars. The whole
process should take only about 30 minutes.
If you get the numbers for me I could make the DXF file for you
(free), then you will just have to import it to whatever program your
using.
Re: tubes
--- In Homebrew_PCBs@yahoogroups.com, "jdizzlemynizzal"
libraries
> > > here;
make
as
for a
paper
use
as
then
your
> using.
Thanks for the method. I will keep this email. At present, I don't
have a set of calipers (my boss lost the one I loaned him) and I need
to order more of the sockets.
2006-09-04 by \M
One problem I feel when working with  PCB CAD-programs is that you can easily
operate and design in an X-Y plane but tubesockets and ICs in TO5 cans have their
connections rather polar oriented with a radius and a fixed angle between the pins.
And I have never seen any program that fixes that.
/M
PS Even got PCB sockets for the odd 12-pin compactron tubes. On the other hand I always
do my tubeprojects P2P between sockets and solder stands.
  using.
2006-09-04 by Stefan Trethan
> easily
> have their
> between the pins.
Target has tools to place elements in round patterns, you specify number,
diameter, angle etc...
In most programs you may find a function to rotate elements a certain
number of degrees. That can be used to generate points by rotating several
lines and a circle to give the radius, although here you still need to
place components manually. You can also try to create a pad component with
the reference point radius away and then placing several and editing the
orientation to the proper degrees, if that works in your software.
Last but not least you could always convert the polar coordinates into x/y
via formula or a pocket calculator.
A spreadsheet program ought to help with this.
ST
