Homebrew_PCBs
Archive for Homebrew_PCBs.
Determining the "Weight" of copper on PCBs?
2006-08-31 by lcdpublishing
Hi Guys,
I buy all my PCBs from "Surplus" dealers. Now that I have a bit of
collection going AND that some of my designs are getting a bit
more "powerful", the weight of copper is getting important. Does
someone know what the thickness of copper is for the different weights?
Example 1 oz. copper is .001" thick or something similar
Chris
Re: Determining the "Weight" of copper on PCBs?
2006-08-31 by dl5012
Hi Chris,
Try this URL
http://www.streamlinecircuits.com/streamline/pg_thickResist.shtml
Your guess was pretty close; 0.0014" for 1 ounce copper cladding.
The 1 ounce info is correct (I've seen that number before), the half
ounce thickness in microns is wrong; should be closer to 18um. And
the first entry is 0.125 ounce, not 125...
Dennis
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
<lcdpublishing@...> wrote:
> Hi Guys,
weights?
> Thanks
> Chris
Thanks much Dennis - that's what I was looking for!
Chris
--- In Homebrew_PCBs@yahoogroups.com, "dl5012" <dl5012@...> wrote:
> Hi Chris,
> Try this URL
half
And
> Regards,
> Dennis
> <lcdpublishing@> wrote:
> > Hi Guys,
of
Does
> weights?
> > Thanks
> > Chris
2006-08-31 by herby1620
> Hi Guys,
> Thanks
> Chris
I saw the following on a web site and wanted to follow thru on the
math, so here it is:
Density of copper is 8.94 grams / cc. (cc = cm * cm * cm)
Recall that there are 454 grams per pound (3 places, rounded)
Thickness in um =
0.5 * 10000 454
---------------------- * ---- = 17 um
2.54 * 2.54 * 16 * 144 8.94
Some of the numbers used (for reference):
0.5 = ounces/sq-foot (amount of copper)
10000 = um/cm (microns per cm)
2.54 = cm/inch
16 = ounces/pound
144 = square inches/square foot
It boils down to:
oz/sq-ft * 34.16 = micron thickness
(applying a 25.4 um/mil conversion)
oz/sq-ft * 1.34 = mills thickness (thousandth of inch)
A calculator program comes in handy to figure this out, along with
some unit analysis to make sure it all fits.
I saw other references, but this "formula" seems to have some basis on
it. If some of the constants are wrong, feel free to correct them.
One reference indicates a density of 8.92 grams / cc for copper.
As a side note, sometimes I hear on _This Old House_ (the PBS TV show)
the rain gutter workers refering to 20 oz copper stock. Turns out
that those guys measure it the same way, so it is probably a copper
industry standard. I suspect that 1 oz copper wouldn't work in that
application.
Hopefully this will help someone.
Re: [Homebrew_PCBs] Determining the "Weight" of copper on PCBs?
2006-09-01 by Stefan Trethan
On Thu, 31 Aug 2006 21:06:53 +0200, lcdpublishing
> Hi Guys,
> Thanks
> Chris
1oz/sq ft is 35um
0.5oz/sq ft is 18um
2oz/sq ft is 70um
1um is 10^-6m.
ST
Re: [Homebrew_PCBs] Re: Determining the "Weight" of copper on PCBs?
On Fri, 01 Sep 2006 00:18:05 +0200, herby1620 <herby1620@...> wrote:
> Thickness in um =
> 0.5 * 10000 454
> 2.54 = cm/inch
> 16 = ounces/pound
I certainly know _why_ i love the SI! That's just frightening...
I certainly also love google - enter the following line as a search term:
8920kg/m^3*1ft^2*35micrometer in oz
and you get
1.0230976 ounces
The good thing about google calculator is it can deal with units and do
the conversions for you. And if you have a mistake in the formula, like
divide somewhere instead of multiplying, the result will just not come out
in the correct unit. If i do that on paper i need to engage brain to check
that....
Sadly it does not (yet) know the density of copper automatically it seems.
ST
2006-09-01 by lcdpublishing
Google is cool! I am going to have to experiment more with that
function of it.
wrote:
> > Thickness in um =
> > 0.5 * 10000 454
> > 2.54 = cm/inch
> > 16 = ounces/pound
search term:
> and you get
> 1.0230976 ounces
and do
like
come out
to check
> that....
it seems.
> ST
