How to DO thermocouple interfacing
2006-08-24 by Herbert E. Plett
> <John.Craddock@...> wrote: > > > > Hi Philip, > > Yes, I read the article and have been doing some research of > thermocouple interfacing. ... why so much complication? hardware is dead simple using a 1-wire interface from Dallas-Maxim. thermocouple feeds directly into an ADC (DS2761) that directly digitizes with a resolution of 15uV, measures digitally its own temperature and connects to a uP via one pin (and ground). also has a 2-5V ADC that can be fed directly from a pot (ie, setpoint). so, all is needed is this chip ( http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3468 ) plus a microP (I use Atmel Tiny), plus an opto-triac/triac pair or a solid state relay and a few passives, switches and a pot with a large knob. the process is all digital and the micro has the chance (responsibility) to implement whatever algorithm fits (from on-off to self adjusting) plus any bells and whistles (LCD display, serial logging, profile, etc). BTW, it DOES fit on a 1" x 2" board (exclusive of power and relay). I kept following this discussion in the hope somebody would come up with a two chip reasonable analog solution, but no, no such... (at least yet) __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
