2006-08-20 by Herbert E. Plett
but you have to make sure you don't have any vias under the components.
also be careful with through hole components as not all allow for easy access
on the component side (bases, switches, caps, etc.)
--- Robert Hedan <
robert.hedan@...> wrote:
> > There are also rivets/eyelets you could put in the holes, but
> > the cheapest
> > way is to solder both sides.
> > ST
> Yupp, I've got a gazillion 330ohm resistors that I use for vias. I just
> hold one in a drilled hole, solder, cut, flip the board and solder the other
> side. It's not as beautiful as I'd like it to be, but it works and it's
> quick.
> Robert
Do You Yahoo!?
http://mail.yahoo.com
