Success Finally!
2006-08-14 by jmumby2
I have chipping away at this for a little while and to be honest I was pretty much ready to chuck in the towel. Until I noticed on this group the use of glossy paper. I have been using OHPS but found I had to iron on about 4 before I had an adequate result. Well today I was fumbling in the paper room at work and found some glossy paper. So I thought 'last chance', and what do ya know 100% on ONE attempt! I am using a Brother HL-2040 if you have one of these check your advanced settings as you can increase the density (toner amount) here and also run 'Thicker paper' setting. I am not sure what the paper is called but if you go to the local copy shop and ask for a couple of sheets of glossy paper you should be sweet. Also just used a household iron for a fraction of the time also. Thanks for a great group!
