On Fri, 11 Aug 2006 18:29:19 +0200, javaguy11111 <javaguy11111@...>
wrote:
> I have been following the inkjet process with great interest. I am
> curious though if the curing process is some kind of oxidation of the
> pigment or some other process.
> Perhaps some kind of enclosure for the hot plate (an upside down pan)
> and using something like helium to displace the oxygen might provide
> some intersting results.
At first i was certain it is just a matter of boiling off all water, but
now i know i was wrong because the effect starts at above 200C. Maybe it
is some other component boiling off - some glycol?
Apart from acting as a etch resist the curing will also make the ink much
more resistant to Acetone. But also air-dried ink will be much more
resistant to acetone after several days then when fresh.
As far as i know we do not know the composition of MISPRO ink. Maybe
someone could request a MSDS?
ST
