Laser Transfers
Laser Transfers
2006-08-08 by herby1620
While not strictly a "PCB" topic, it does relate to something used for
making PCBs.  I was thinking (dangerous, you know) about making a
front panel for another project.  Given that I desire "nice" artwork,
and have access to a laser printer, I was wondering about using laser
transfer methods (print to laser transfer "paper", iron on front
panel) to make a nicely designed front panel.
A couple of questions:
1)  How well do the laser transfer methods work?  I'm assuming that
one takes the transfer and makes it work on a PC board with an iron
(or some heat source with pressure).
2)  If I can get a color laser printer, would I get color transfered
as well?
3)  Quality?  Would it look "reasonable" for the task?
4)  Durability?  I was thinking of coating the whole thing with some
clear spray to make it last.
5)  Am I making any sense?  Is this idea a whole waste of time and I
should look to something else?
It seems to me that the transfer method would make for the ability to
have nice artwork/legends on my finished "box".  While I am not going
to dunk the "box" in some resist, the transfer method should be
similar, thus the questions.
Thanks for any feedback.
Re: Laser Transfers
2006-08-08 by lcdpublishing
Herby,
The only potential flaw I see with that process is the substrate you
will transfer to. It must be able to tolerate the heat during the
transfer process.  Color lasers work fine for toner transfer, I have
done it several times here for PCBs and other things.  For
durability, you will need to spray a clear coat on as you were
thinking about.  Sorry, can't recommend anything in particular there
but do some testing first.  I suspect some of the clears might
disolve the toner and cause it to bleed.  Probably one of the most
promising is a water based polyurethane - very durable and as water
is it's solvent, shouldn't cause any bleeding etc.
I will be doing some experiments this weekend for something similar,
but the substrate I have in mind is very questionable so I am not
expecting things to go good for me.
Chris
--- In Homebrew_PCBs@yahoogroups.com, "herby1620" <herby1620@...>
for
artwork,
laser
transfered
> as well?
some
I
to
going
Re: Laser Transfers
2006-08-08 by adicont2
I use a simple method for front panels. Ink Jet transparencies,
printed on reverse and glued on panel. The glue is important because
it can attack the ink.
The most durable method is to make a sandwitch: the base material (box
wall), printed film or even paper and a sheet of acrylic or plexiglass
bolted to base material.
Adrian
for
artwork,
laser
> as well?
to
going
Re: [Homebrew_PCBs] Laser Transfers
2006-08-08 by Stefan Trethan
> as well?
I made a very small aluminum plate once with my initials on it (to replace
the company plaque on a meter case i used for something else) to test the
viability of TT for front panels.
It worked just like on PCB.
I also made a house-number and name sign for putting on the front gate, to
make it easier for the various delivery services. I used PCB material for
that, but it was recently destroied by a not-so-skilled driver and i will
have to make a new one. I plan to try inkjet printing on formica sheet
this time.
So as long as your material is compatible to the heat needed for
transfers, and flat if you plan to use a fuser/laminator, it will probably
work just fine. You should use silicone paper so that you get a nice shiny
surface with no paper residue. A laquer coat is a very good idea. I used
water based acrylic for the house sign and it did well outside, well,
before it was broken.
There is also something called "water slide paper" that is basically toner
transfer with an intermediate step that allows application to a surface
which is not heat resistant.
ST
Re: Laser Transfers
2006-08-09 by scratch_6057
> toner transfer with an intermediate step that allows application to a
> surface which is not heat resistant.
> ST
This, http://www.supercaldecals.com is water slide paper for use with
INKJET printer. Others exist for laser printers
I was thinking along the same lines as the original poster, color toner
transfer, but it  looks like the "FREE" QMS magiccolor 2 printer I got
a couple of weeks ago has "issues" with picking up the glossy staples
printer paper.
Re: [Homebrew_PCBs] Re: Laser Transfers
2006-08-09 by Stefan Trethan
On Wed, 09 Aug 2006 05:10:21 +0200, scratch_6057 <dml.empsrch@...>
> printer paper.
Maybe just that roller surface having a problem.
You could always try and stick some other paper to the leading edge, if it
takes that?
ST
Re: Laser Transfers
toner
I got
staples
> > printer paper.
edge, if it
> takes that?
> ST
The printer will take standard 20lb paper, & I had thought about
using a strip  of "Avery" full sheet label on the leading edge,
or possably a piece of "3M" removable painters masking tape. If that
dosen't do then I'll try with a piece of the "staples" paper taped to
a full sheet of 20lb.
I talked to a guy the other day who said he has had success
rejuvenating  printer pickup rollers (and other rubber items
 of various types) by applying mineral oil in multiple coats.
According to him the rubber absorbs the oil and comes back
to "life". Anyone else ever hear of this trick? I know there are
other "roller rejuvenating fluids" on the market, any success stories?
The printer was an unexpected freebie so it is really
not at the top of the priority list right now, I'm sure you know
about those kind of things.
2006-08-09 by Leon Heller
Sent: Wednesday, August 09, 2006 2:22 PM
Subject: [Homebrew_PCBs] Re: Laser Transfers
> toner
> I got
> staples
>> > printer paper.
> edge, if it
>> takes that?
>> ST
I'd try roughening the roller with some emery paper.
I usually cut a piece of special paper like that roughly to size and stick
it to a standard A4 sheet. Apart from it feeding properly it saves money.
Leon
rubber roller Re: [Homebrew_PCBs] Re: Laser Transfers
2006-08-09 by Gus S Calabrese
Don't roughen the roller just yet... apply some oil of wintergreen
first and
see how that goes.
Gus
 > toner
 > I got
 > staples
 >> > printer paper.
 > edge, if it
 >> takes that?
 >> ST
stories?
stick
money.
Leon
Gus S Calabrese
Denver, CO
720 222 1309     303 908 7716 cell
Please include and do not limit yourself to "spam2006". I allow
everything with  "spam2006"  in the subject or text to pass my spam
filters.
Re: rubber roller Re: [Homebrew_PCBs] Re: Laser Transfers
On Wed, 09 Aug 2006 18:13:33 +0200, Gus S Calabrese <gsc@...>
wrote:
> oil of wintergreen
Oleum Gaultheriae, Oil of Wintergreen. True Oil of Wintergreen; composed
of about 96 per cent of methyl salicylate
Methyl salicylate (chemical formula C6H4(HO)COOCH3; also known as
salicylic acid methyl ester, oil of wintergreen, betula oil, methyl ester)
is a natural product of many species of plants. Some of the plants
producing it are called wintergreens, hence the common name.
ST
Re: Laser Transfers
2006-08-09 by lcdpublishing
I believe this was the thread where someone was asking about using
color laser printers for toner transfer to make panel fronts and
such.  I just did a quick test of a color transfer and it worked just
fine as I suspected.  The colors didn't change and the transfer
percentage was about the same with just plain black - some missing
spots.  This could have been due to the very quick and crude test as
well as the paper I was using.
If and when I get to trying out a clear coat, I will report back if
something works or doesn't work.
Chris
Re: Laser Transfers
2006-08-12 by beardmoredon
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
just
> Chris
Hi
I've been an observer in this group for a few months - finally there
is something I can contribute.
To use TT to make pront panels and such, try this.  Get some clear
plastic contact adhesive sheet (the kind sold by newsagents for
covering books).  Print a full-size normal (nor reversed) image of
your front panel on a white background using a laser printer (black &
white, or color). Cover the image with the clear contact sheet, and
rub with the back of a spoon or something to ensure good adhesion.
Immerse in cold clean water (no detergents) and remove the paper by
rubbing with your finger or a soft brush.  Be sure to get all of the
paper residue - the toner will remain stuck to the clear contact
sheet.  Allow the sheet to dry, then apply directly to the metal
panel - or anything else that is flat.  All done - your image, and a
protective coating all in one operation.
Good luck
Don Beardmore
2006-08-13 by Herbert E. Plett
> covering books).
some better description for those not in AU ?
Do You Yahoo!?
http://mail.yahoo.com
2006-08-13 by Lez
>  > covering books).
Well I understood I'm Uk, but then we had BluePeter and lots of sticky
backed plastic.
Maybe its also called ''coverfilm''
Its a film, about 0.75mm thick, comes in a metre wide roll in various
colours including clear, is adhesive coated on one side with a backing
paper, you cut to size, peel off the backing, and apply.
Often used for protecting the outer surface of books, and in much
bigger rools for houshold decoration, including covering internal
house doors to change design to match new decor.
Biggest brandname I think in uk was ''fablon''
>  Do You Yahoo!?
Lez
