Isolation milling - what do the cutters look like to do it?
2006-07-26 by lcdpublishing
Hi guys, Later this year (perhaps next year or whenever I get my machine done), I want to give isolation milling a try. At first I thought a small end mill would be the tool to use, but the more I thought about it, I suspect that is not the case. After thinking about it further, I believe it would make more sense to use a "pointed" tool shaped like a 'V' or something. Does anyone know of some sources for the tool bits that work good for isolation milling? Primarily, I would like to see some detailed photos or drawings as I would probably attempt to grind my own - seeing as Stefan got me thinking about that now ;-) Thanks Chris
