Low cost spray etching
2006-07-25 by sethkoster
I'm working on a low cost Copper Chloride spray system for single and double sided boards and I wanted to run what I'm doing by you guys and see if anyone had already worked on this or had any thoughts. My plan is to use either 5 or 9 conical spray pattern applicators per side inside of a small one piece acrylic fishtake with a maximum PCB size of 8.5" X 11" and a practical working size of about 6" X 9". About 1" of the bottom of the tank will serve as the pump reservoir. I found that I can get a diaphragm pump with Viton fittings and Santoprene diaphragm for about $45 (both A rated for Copper Chloride). I checked on the applicators for aerosol cans and they're made of HDPE which is rated B for Copper Chloride, so I contacted Seaquist and asked them to send me 20 samples of their AR-100. Even though these have a B rating, I'm not too worried since if they fail they will be inside of the enclosed etching tank. If I can keep the temp below 72F I can use any kind of tubing (silicon and PVC are A1 rated), but since I don't want to be limited in that way I plan to use Santoprene because Viton is quite expensive. For fittings I think I have to stick with Kynar since these will be outside of the tank. I'm undecided about using HDPE because, even though it is B rated, the deluxe etching system by MG Chemical uses it for their tanks. I haven't sourced the tubing or fittings yet, so I plan on doing some calling this week. Hopefully I can get samples so as to keep costs down. I have set a limit of about $100 for this system because it is still much less than the $170 MG Chemical deluxe system. More than that and I don't think it can be considered anywhere near low cost for a hobbyist. I'd really appreciate any feedback, especially concerning using HDPE with Copper Chloride since that could make or break my budget. Also, if anyone knows low cost sources for flexible Santoprene tubing (3/8" ID) and/or Kynar T fittings (3/8" OD) I'd love to hear from them! Thanks, Seth
