Looking for a source of those RINGs on PCB drills?
2006-07-25 by lcdpublishing
Hi Guys, As the subject title says, I am looking for a source of them. Actually, I really don't need a lot of them, I just would like to have enough to identify all the drills I have (or will have) and use. Most of the bits I have now already have the rings, but some don't. Chris
2006-07-25 by Stefan Trethan
On Tue, 25 Jul 2006 13:13:33 +0200, lcdpublishing <lcdpublishing@...m> wrote: > Hi Guys, > As the subject title says, I am looking for a source of them. > Actually, I really don't need a lot of them, I just would like to have > enough to identify all the drills I have (or will have) and use. > Most of the bits I have now already have the rings, but some don't. > Chris I had the same wish, so i got a set of drills at ebay with rings on most. I write the correct size on the ring with felt tip if i don't have the right one. To set them i made a special tool. ST
I have about 250 drills right now and about 80% of them have rings on them. I used to throw away the rings when the drill would break but have been keeping them since realizing the difficulty in getting them :-) The one supplier of drill bits I was using on Ebay has since gone - he had great sets with popular sizes. But those grab bags are handy as hell too - especially as I get further and further with my machine. Somehow I have it in my mind that this little machine is going to be able to do some pretty nifty things ;-) Chris --- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Tue, 25 Jul 2006 13:13:33 +0200, lcdpublishing > <lcdpublishing@...> wrote: > > > Hi Guys, > > As the subject title says, I am looking for a source of them. > > Actually, I really don't need a lot of them, I just would like to have > > enough to identify all the drills I have (or will have) and use. > > Most of the bits I have now already have the rings, but some don't. > > Chris > > > I had the same wish, so i got a set of drills at ebay with rings on most. > I write the correct size on the ring with felt tip if i don't have the
> right one. > > To set them i made a special tool. > > ST >
2006-07-25 by JanRwl@AOL.COM
In a message dated 7/25/2006 6:21:37 A.M. Central Daylight Time, lcdpublishing@... writes: As the subject title says, I am looking for a source of them. Actually, I really don't need a lot of them, I just would like to have enough to identify all the drills I have (or will have) and use. Most of the bits I have now already have the rings, but some don't.<< Chris! Do I imagine correctly that you will have only one or two of each size, and will hand-mark the ID-rings? Wow! Even my CNC PCB drill will BUST commonly-used sizes often enough that it has proven VERY economically-advantageous to buy-in those "reconditioned" boxes of 50 bits (JDR Microdevices, etc), ALL of which have properly MARKED rings. You might buy a box of those, and SAVE the rings off busted bits, for re-use. And SAVE the 1/8" shanks of the busted bits! They can be used for regrinding into engraving bits, braze-on "carbide edges" for specials you make, etc. Yeah, if I had to depend on one or two of "popular sizes" (like #56, for example), I'd be spending 70% of MY time waiting for delivery of the TWO replacements! I haven't needed a "professionally-did" PCB in so long, I don't even know if they will accept "2X camera-ready" artwork for new work as always, or now will accept ONLY whatever PCB-CAD layout "on-disk"! So, I haven't asked how THEY buy-in their bits. Boxes of 100? How many sizes do they keep in stock? Min. quantity of each size before reorder? Hmmm... I will have to try to remember to ask, next time I need PTH or multi-layer! Jan Rowland [Non-text portions of this message have been removed]
On Tue, 25 Jul 2006 21:38:45 +0200, <JanRwl@...> wrote: > > I haven't needed a "professionally-did" PCB in so long, I don't even > know if > they will accept "2X camera-ready" artwork for new work as always, or > now > will accept ONLY whatever PCB-CAD layout "on-disk"! So, I haven't > asked how > THEY buy-in their bits. Boxes of 100? How many sizes do they keep in > stock? > Min. quantity of each size before reorder? Hmmm... I will have to try > to > remember to ask, next time I need PTH or multi-layer! Gerber files, usually. They will stock several boxes of the sizes they have (number depends on company size i guess), and i would expect quite a few boxes with smaller numbers of the strange sizes too. Many seem to have them drills re-ground and cycle the boxes around.... ST
Yeah, I should keep the broken ones, if for nothing else, to sell for scrap value. I don't have any means of repointing or even grinding carbide here. I do have enough grinders I suppose that I could put a soft wheel or a diamond wheel on somthing though. I guess I better start saving them! I have not broken that many bits so far with my hand-drilling on the big drill press. Most of the times it is from whacking the side of the bit putting the board in place or something else stupid. Seldom break them when drilling though. I have been looking around for some boxes containing lots of the common sizes I use the most of .025", .035", .045", .055", .062", and .125". I would guess that 80% of the holes I have drilled so far are .035" and I did score a set of them. Chris --- In Homebrew_PCBs@yahoogroups.com, JanRwl@... wrote: > > In a message dated 7/25/2006 6:21:37 A.M. Central Daylight Time, > lcdpublishing@... writes: > > As the subject title says, I am looking for a source of them. Actually, I > really don't need a lot of them, I just would like to have enough to identify > all the drills I have (or will have) and use. > > Most of the bits I have now already have the rings, but some don't.<< > Chris! Do I imagine correctly that you will have only one or two of each > size, and will hand-mark the ID-rings? Wow! Even my CNC PCB drill will BUST > commonly-used sizes often enough that it has proven VERY > economically-advantageous to buy-in those "reconditioned" boxes of 50 bits (JDR Microdevices, > etc), ALL of which have properly MARKED rings. You might buy a box of those, and > SAVE the rings off busted bits, for re-use. And SAVE the 1/8" shanks of the > busted bits! They can be used for regrinding into engraving bits, braze-on > "carbide edges" for specials you make, etc. > > Yeah, if I had to depend on one or two of "popular sizes" (like #56, for > example), I'd be spending 70% of MY time waiting for delivery of the TWO > replacements! > > I haven't needed a "professionally-did" PCB in so long, I don't even know if > they will accept "2X camera-ready" artwork for new work as always, or now > will accept ONLY whatever PCB-CAD layout "on-disk"! So, I haven't asked how > THEY buy-in their bits. Boxes of 100? How many sizes do they keep in stock? > Min. quantity of each size before reorder? Hmmm... I will have to try to
> remember to ask, next time I need PTH or multi-layer! > > Jan Rowland > > > > > > > [Non-text portions of this message have been removed] >
On Tue, 25 Jul 2006 21:53:31 +0200, lcdpublishing <lcdpublishing@...m> wrote: > Yeah, I should keep the broken ones, if for nothing else, to sell > for scrap value. I don't have any means of repointing or even > grinding carbide here. I do have enough grinders I suppose that I > could put a soft wheel or a diamond wheel on somthing though. I > guess I better start saving them! When i was at school we made scribe tips out of them broken ones. Still have mine somewhere, it will work as a glass cutter ;-) There were PCB drills with a soft shank where they could cut a thread for screw-in tip replacement. But at some point they made them solid carbide. I keep them all, but have yet to find a good use (lacking a diamond wheel too). However, if you break one by chance with a short section of drill spiral remaining they can be used to drill or enlage holes in populated boards "freehand" where a normal length drill would break. I wish they'd make them with only 2mm or 3mm of thin end. They'd never break! Conrad Electronics from germany used to sell spear shaped bits like that, not sure if they still do. It might be possible to grind them shorter, but maybe it is too tricky to do by hand (although i'm usually fairly good at drill grinding) Anyway, with the pivoting drill press i managed to make some quite dull before breaking them. St
LOL! I can just picture me standing in front of a grinder today (with my bad eyesight) trying to hand grind a point on a .035" carbide drill bit :-) I can barely grind the .250" drill bits anymore :-( The more I think about it though, I am going to pick up either a soft-green wheel or a diamond wheel. I plan on giving the isolation milling a try when I get the little machine done (sometime during the next century). I suppose someone makes bits for isolation milling but I have not seen any in the grab-bags of bits I have been buying. So, in the spirit of doing everything else, why not make an attempt at grinding tiny bits to drive myself crazy ;-) Chris --- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Tue, 25 Jul 2006 21:53:31 +0200, lcdpublishing > <lcdpublishing@...> wrote: > > > Yeah, I should keep the broken ones, if for nothing else, to sell > > for scrap value. I don't have any means of repointing or even > > grinding carbide here. I do have enough grinders I suppose that I > > could put a soft wheel or a diamond wheel on somthing though. I > > guess I better start saving them! > > > When i was at school we made scribe tips out of them broken ones. Still > have mine somewhere, it will work as a glass cutter ;-) > > There were PCB drills with a soft shank where they could cut a thread for > screw-in tip replacement. But at some point they made them solid carbide. > > I keep them all, but have yet to find a good use (lacking a diamond wheel > too). > > However, if you break one by chance with a short section of drill spiral > remaining they can be used to drill or enlage holes in populated boards > "freehand" where a normal length drill would break. I wish they'd make > them with only 2mm or 3mm of thin end. They'd never break! Conrad > Electronics from germany used to sell spear shaped bits like that, not > sure if they still do. > It might be possible to grind them shorter, but maybe it is too tricky to > do by hand (although i'm usually fairly good at drill grinding) > > Anyway, with the pivoting drill press i managed to make some quite dull
> before breaking them. > > St >
On Tue, 25 Jul 2006 22:28:31 +0200, lcdpublishing <lcdpublishing@...m> wrote: > LOL! > I can just picture me standing in front of a grinder today (with my > bad eyesight) trying to hand grind a point on a .035" carbide drill > bit :-) I can barely grind the .250" drill bits anymore :-( > The more I think about it though, I am going to pick up either a > soft-green wheel or a diamond wheel. I plan on giving the isolation > milling a try when I get the little machine done (sometime during > the next century). I suppose someone makes bits for isolation > milling but I have not seen any in the grab-bags of bits I have been > buying. > So, in the spirit of doing everything else, why not make an attempt > at grinding tiny bits to drive myself crazy ;-) > Chris You think the soft green wheel will do them? I think i got one with that belt sander/grinder combo... But i would not expect the runout to be anywhere near acceptable to avoid breaking them bits... What sort of grinder do the diamond wheels need? ST
A green wheel would be tough to do it with, but it would work for making an engraving cutter. Keep in mind, you have to dress the wheels prior to, and frequently during grinding. I have used diamond wheels on mills and on "tool grinders". Obviously the mill isn't the tool of choice, but in a pinch you gotta do what you gotta do! Tool grinders have nice, exposed spindles so that you can manipulate the tool bit at various angles to the diamond wheel (usually a cup wheel). I suppose you could mount one on a bench grinder if you have the correct size arbor or adapter. You would also have to leave off the outer wheel cover so you have access. During my first few years as a machinist, I used to have to hand grind form tools for use in CNC machines. These tools were either carbide or HSS. The form tools where then used to mill slots on babbit bearings (thrust bearings). These slots allowed the oil to flow up onto the face for lubrication. The bad part of it was every bearing had a different profile for these oil grooves. It seemed as though the designers followed no standards, just drew up what looked good at the moment. So, I would have to grind up the tool by hand, making comparisons to radius gages etc. The good part is that while the bearings were made to exacting standards and inspected by the vendor, they were never really picky about those oil groves - thank goodness. So, back to the topic at hand, I used the green wheels on the bench grinder to create these. It was much faster for me to do it free hand at the bench grinder than to use jigs and such with a tool grinder and diamond wheels. So, you can do some very intricate stuff with green wheels, just don't try to do it fast ;-) Chris --- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Tue, 25 Jul 2006 22:28:31 +0200, lcdpublishing > <lcdpublishing@...> wrote: > > > LOL! > > I can just picture me standing in front of a grinder today (with my > > bad eyesight) trying to hand grind a point on a .035" carbide drill > > bit :-) I can barely grind the .250" drill bits anymore :-( > > The more I think about it though, I am going to pick up either a > > soft-green wheel or a diamond wheel. I plan on giving the isolation > > milling a try when I get the little machine done (sometime during > > the next century). I suppose someone makes bits for isolation > > milling but I have not seen any in the grab-bags of bits I have been > > buying. > > So, in the spirit of doing everything else, why not make an attempt > > at grinding tiny bits to drive myself crazy ;-) > > Chris > > > You think the soft green wheel will do them? I think i got one with that > belt sander/grinder combo... > But i would not expect the runout to be anywhere near acceptable to avoid
> breaking them bits... > > > What sort of grinder do the diamond wheels need? > > ST >
On Tue, 25 Jul 2006 23:00:38 +0200, lcdpublishing <lcdpublishing@...m> wrote: > A green wheel would be tough to do it with, but it would work for > making an engraving cutter. Keep in mind, you have to dress the > wheels prior to, and frequently during grinding. I plan on getting a dressing tool. Do i want one of the spiky wheely things or a diamond tool? I have several tool grinders, but i was worried the runout would never be good enough for the diamond wheels or i could not mount them precisely enough. I would not know how to dress a diamond wheel?? ST
Forget the "Spiky" things unless you want to remove a lot of material from the wheel in a hurry - good for rough work. Find a diamond "point" type - they are not too expensive. But you gain a lot of control during the dressing. You can also get a very round wheel that has as flat of surface as your hand can move sideways across the rest - my favorite type. Diamond wheels are dressed with a diamond point (from what I remember). However, you have to mount the point in a fixture to get it to work good. When you say you have a couple tool grinders, are you talking about the hand held things or what? Could you be referring to a bench grinder of some sort? I would be surprised if you have a "Tool grinder" as they are usually specialized type grinders for grinding tools and cutters. I have never seen one outside a machine shop's tool room. If you can, send me a picture of your grinder so I can better identify it. Chris > I plan on getting a dressing tool. Do i want one of the spiky wheely > things or a diamond tool? > > I have several tool grinders, but i was worried the runout would never be > good enough for the diamond wheels or i could not mount them precisely
> enough. I would not know how to dress a diamond wheel?? > > ST >
On Tue, 25 Jul 2006 23:50:14 +0200, lcdpublishing <lcdpublishing@...m> wrote: > When you say you have a couple tool grinders, are > you talking about the hand held things or what? Could you be > referring to a bench grinder of some sort? Just the cheap bench or wall mount grinders with a AC motor in the middle and two wheels one on either side. People use them here to grind chisels, lathe tools and drills and stuff. I also have a grinder for 1m (or so) wide wood planer blades, but that's another story and no good for this. I would like a way to straighten out the rounded edges of grinding wheels. Do you think the diamond wheels (cup form) could possibly work on those shop grinders? ST
That is a common bench grinder as I would refer to it, not a tool or cutter grinder like that used in a tool room. You certainly could through a diamond cup on it if you can find the right size adapters and such. The only precaution is making sure you are holding the tool good as you do your grinding. Sometimes, the cup wheels tend to grab more so than the general abrasive wheels. If you can find a cup wheel at a decent price, it sure would be worth it to have. Dressing the cup wheel will be your biggest problem as you won't have a way to securely hold the point. However, steady hands and good eyes can do remarkable things when forced to! That other grinder sounds facinating! If you every have your camera handy and think of it, shoot a couple pictures for me, I would love to see it. --- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Tue, 25 Jul 2006 23:50:14 +0200, lcdpublishing > <lcdpublishing@...> wrote: > > > When you say you have a couple tool grinders, are > > you talking about the hand held things or what? Could you be > > referring to a bench grinder of some sort? > > > Just the cheap bench or wall mount grinders with a AC motor in the middle > and two wheels one on either side. People use them here to grind chisels, > lathe tools and drills and stuff. I also have a grinder for 1m (or so) > wide wood planer blades, but that's another story and no good for this. > > I would like a way to straighten out the rounded edges of grinding wheels. > > Do you think the diamond wheels (cup form) could possibly work on those
> shop grinders? > > ST >
2006-07-25 by Andrew
> lcdpublishing wrote: > > <snip> > I would be surprised if you have a "Tool > grinder" as they are usually specialized > type grinders for grinding tools and > cutters. I have never seen one outside > a machine shop's tool room. > <snip> I know this is starting to stray off topic. BUT talking of grinders - has anyone used a Quorn for grinding tiny drills ? I am thinking of making a Quorn just for the fun of it and I wonder if it will actually be useful.
On Wed, 26 Jul 2006 00:37:29 +0200, lcdpublishing <lcdpublishing@...m> wrote: > > That other grinder sounds facinating! If you every have your camera > handy and think of it, shoot a couple pictures for me, I would love > to see it. Can do. basically a cup grinding wheel and a holder for the blade that moves left/right on dovetail ways. I was contemplating at some point if it may be used to grind precise ways for a CNC. ST
2006-07-25 by Bill Maxwell
I haven't used one for pcb drills but I dont see why it couldn't be used, once a suitable wheel had been found. I suspect you will be in for prolonged fun building a Quorn though. There are simpler small ctter grinder designs that would probably be equal to the task. My Quorn is still a collection of castings, apart from the main pillar and I suspect it will be a long time before I get it finished. Bill ----- Original Message ----- From: "Andrew" <andrewm1973@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Wednesday, July 26, 2006 8:50 AM Subject: [Homebrew_PCBs] Re: Looking for a source of those RINGs on PCB drills?
>> lcdpublishing wrote: >> >> <snip> >> I would be surprised if you have a "Tool >> grinder" as they are usually specialized >> type grinders for grinding tools and >> cutters. I have never seen one outside >> a machine shop's tool room. >> <snip> > > I know this is starting to stray off topic. > > BUT talking of grinders - has anyone used > a Quorn for grinding tiny drills ? > > I am thinking of making a Quorn just for > the fun of it and I wonder if it will > actually be useful. > > > > > > > > Be sure to visit the group home and check for new Links, Files, and > Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > Yahoo! Groups Links > > > > > >
>> andrewm wrote: >> I know this is starting to stray off topic. >> >> BUT talking of grinders - has anyone used >> a Quorn for grinding tiny drills ? >> >> I am thinking of making a Quorn just for >> the fun of it and I wonder if it will >> actually be useful. > Bill Maxwell wrote: > > I haven't used one for pcb drills but > I dont see why it couldn't be used, > once a suitable wheel had been found. > I suspect you will be in for prolonged > fun building a Quorn though. There > are simpler small ctter grinder designs > that would probably be equal to the > task. My Quorn is still a collection of > castings, apart from the main pillar > and I suspect it will be a long time > before I get it finished. Yes - fun is a relative term. There is still a lot of fun to be had from looking at unfinished castings isn't there ? I susspect I shall also shell out a few grand for a profesional grinder as well. It might just be nice if I could use the Quorn for something as well if I build it. And - yes - there are simpler ones around than the Quorn - but are they as pretty :D
2006-07-26 by Bill Maxwell
No Andrew, I agree that none are as pretty as the Quorn and I also agree that looking at castings is fun too. I have been using that justification for more than 10 years on some of my collection of castings. Bill ----- Original Message ----- From: "Andrew" <andrewm1973@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Wednesday, July 26, 2006 9:29 AM Subject: [Homebrew_PCBs] Fun Quorn Oxymoron was Re: Looking for a source of those RINGs on PCB drills?
>>> andrewm wrote: >>> I know this is starting to stray off topic. >>> >>> BUT talking of grinders - has anyone used >>> a Quorn for grinding tiny drills ? >>> >>> I am thinking of making a Quorn just for >>> the fun of it and I wonder if it will >>> actually be useful. > >> Bill Maxwell wrote: >> >> I haven't used one for pcb drills but >> I dont see why it couldn't be used, >> once a suitable wheel had been found. >> I suspect you will be in for prolonged >> fun building a Quorn though. There >> are simpler small ctter grinder designs >> that would probably be equal to the >> task. My Quorn is still a collection of >> castings, apart from the main pillar >> and I suspect it will be a long time >> before I get it finished. > > Yes - fun is a relative term. > > There is still a lot of fun to be had > from looking at unfinished castings > isn't there ? > > I susspect I shall also shell out a few > grand for a profesional grinder as well. > It might just be nice if I could use the > Quorn for something as well if I build > it. > > And - yes - there are simpler ones around > than the Quorn - but are they as pretty > :D > > > > > > > > > > Be sure to visit the group home and check for new Links, Files, and > Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > Yahoo! Groups Links > > > > > >
2006-07-26 by JanRwl@AOL.COM
In a message dated 7/25/2006 3:42:54 P.M. Central Daylight Time,
stefan_trethan@... writes:
ST: I can't answer your question by specifying a "usual grinder-motor"
which would be suitable, except to say it'd have to be one with very good
bearings, well balanced, so smooth-running, and I'd want at least 6000 RPM.
I made an arbor with a 12.7 mm dia. shank, which accepts 100 mm dia. X 3 mm
thick diamond-rim wheels (3 mm of O.D. is diamond-compound) and I use that in
my vertical mill ("Bridgeport" type mill). This makes it possible to do
relatively precision grinding by holding the bit being ground in a collet
fixture or vise on the mill-table, which can be moved with 0.0005 inch precision
fairly well in the X & Y directions. But I can get this spindle on up to about
3500 RPM before I am afraid to take it higher, lest the machine vaporize!
Jan Rowland
