Finally - next stop: large PCB inkjet printing
2006-07-07 by Stefan Trethan
Just received the spongeless carts with autoreset chips from ireland.
21eur for the whole set (14eur plus shipping as registered letter). Even
came with 4 funnly large diameter syringes i'm probably not going to use
and 4 blunt needles. I'm very positive about the place where i ordered
(<http://www.4-u-all.com>), payment via paypal worked although i do not
have a verified account as they state is required. Ordered on the weekend
and was here Thursday. Only thing strange about it is they put the
bubblewrap around the outside of the box, must be an irish thing or
something ;-). The carts did rattle around inside, but the box was still
in good shape.
Anyway, i'm glad now i will not have to worry about refilling or stupid
chips any more, and tomorrow i will _finally_ be making the first large
PCBs.
I really hope i can retire the laminator now, i had to borrow the large
solid state relay for the spot welder and the one it botched in to make a
few PCBs is a serious safety hazard...
ST
Re: Finally - next stop: large PCB inkjet printing
2006-07-07 by lcdpublishing
Good luck Stefan!!!
Please post some photos of your progress and achievments.  I have
out-of-town guests in for the weekend so my ink-jet nightmare will
be on hold for another couple weeks or so.
I am still upset about that jam-up - dumb,dumb,dumb.
ireland.
letter). Even
to use
ordered
do not
weekend
or
still
> in good shape.
stupid
large
> PCBs.
large
make a
> ST
Re: [Homebrew_PCBs] Re: Finally - next stop: large PCB inkjet printing
2006-07-08 by Stefan Trethan
I put the thing together today, the printer works fine now, currently
fiddling with the settings.
Etched a test PCB early on, but could already see there were problems on
the printout.
Some nozzles were not firing, i can see breaks where they where. Also i
had some significant puddling of ink on the ground area.
I've cleaned the head, all nozzles are firing properly now, but i'm still
struggling with the puddling.
Tried all 15 possible combinations of paper type and print quality, while
the results seem to vary there's some puddling on every setting.
The brightness/contrast settings do not seem to work to adjust the ink
amount. No change between 0 and +2, and over that there is no ink at all.
Maybe i would need to use a grey image or something instead of black.
The puddling may not be a problem for my normal PCBs, i made kind of a
challenging test pattern. The larger structures of the main text came out
well.
Well, some more tinkering needed to get it just right. But i could do a
PCB with it right now, and i'm sure after fine-tuning it will be much
better than the best toner transfer.
Also, a lot of work is needed on the curing issue. I think i can use that
old clothes iron upside down for that. I have calibrated the dial in
degrees some time ago. my gut feeling is the curing is only about driving
all the water out and not very critical, but i guess that is to be seen. I
expect tests with a few different temperatures and curing times are
required.
Oh, one more thing, the transparency setting does not use any black cart
ink at all. Only color ink. Some of the pther paper settings have a black
ink only option.
Chris, about the paper sensor: I think i know how you can fix that, it got
into the same situation.
My solution is to mount the paper sensor so it will "see" the carrier
plate directly by mounting it so the edge passes through. But the printer
expects a certain time delay from when it starts eating paper to when the
sensor should see it. So i cut out a notch from the side of the carrier
that will alow about 6cm of feed before the sensor is activated. The
procedure is to put the leading edge of the carrier into the printer
manually so the feed roller grabs it, before you send the print command.
I experimented for the ideal distance between sensor and the end of the
notch, and found the printer is quite tolerant (maybe from 2cm to 10cm or
so will work. Simply stick some tape to the side of a sheet and manually
feed it varying distances before starting the printing process.
ST
On Fri, 07 Jul 2006 23:45:30 +0200, lcdpublishing
<lcdpublishing@...> wrote:
> Good luck Stefan!!!
2006-07-09 by lcdpublishing
Hot dog, sounds like you are making some great progress!
The puddling is a very strange problem I don't understand yet.  With
the crude tinkering I did with the inks a few months back, I recall
seeing that problem.  But it seems as though the puddling looks more
like "Fish-eyes" that are seen when paint is applied over a surface
with silicone contaminates on it.  So, I am not sure it's the amount
of ink causing that puddling as it may be a contaminate causing it.
But in any case, I saw it with my crude tests, I believe Steve ran
into that problem, and now you.  If it is a contaminate of some
sort, it is common to all of us.
Thanks for the suggestions on that paper sensor.  I will have to dig
out that other printer and give it a go again.
currently
problems on
> the printout.
Also i
i'm still
quality, while
ink
at all.
black.
of a
came out
> well.
do a
much
use that
in
driving
seen. I
are
> required.
black cart
a black
> ink only option.
that, it got
carrier
printer
when the
carrier
The
printer
command.
of the
10cm or
manually
> ST
> > Good luck Stefan!!!
will
