Toner melting points, pt. 2
2006-06-28 by dagmargoodboat
(Oops - a "tab" and a <cr> sent my first post before completion!)
Continuing...
PRINTERS / TONER USED
HP LaserJet 5L, original cartridge
Samgsung 1710, cartr. refilled with recommended toner from TonerKits.com
I made one print from each printer, on separate sheets from
the same package of Staples' paper, then measured:
a) the minimum temperature at which I could smear the
pattern with the iron (i.e., toner flows)
b) the minimum temperature at which decorative foil
would transfer to the toner (i.e., toner is 'tacky')
RESULTS
HP LJ-5L Samsung
toner 99 C < t < 106 C 98 C < t < 101 C
smears (210F < t < 222F) (209F < t < 213F)
foil 107 C < t < 112 C 78 C < t < 83 C
sticks/ (225F < t < 233F) (172F < t < 181F)
transfers
Given the recommended fusing temps., I was surprised the
toner melting points were as low as they are.
Best,
James
Continuing...
RESULTS
HP LJ-5L Samsung
transfers
Best,
James
