Ammonium Persulphate
2006-06-06 by stewart_bakeruk
Hi, Although I have been a lifetime user (addict) to Ferrice Chloride, I would like to try something a bit cleaner. Can anyone advise where I can purchase small quantities of Ammonium Persulphate in the UK ? When I asked my local chemist about it she looked at me as is I was a serial poisoner ! Cheers Stewart G3RXQ
2006-06-06 by Andrew
> Stewart wrote: > Although I have been a lifetime user (addict) > to Ferrice Chloride, I would like to try > something a bit cleaner. > > Can anyone advise where I can purchase small > quantities of Ammonium Persulphate in the UK ? > > When I asked my local chemist about it she > looked at me as is I was a serial poisoner ! After having a many year addiction to Amonium Persulphate I recently kicked the monkey and found a new religion. I now use Cupperic Chloride and will never again look back. It is cheap, easy to make and never runs out. There are several good resources on the web for how to make and use it. It's like stepping up from codeine to smack. HOWEVER - if you only etch one board in a blue moon - Amonia Persulphate or FeCl are probably better ideas. In the UK you will be able to get either from RS components. (www dot rscomponents dot com )
2006-06-06 by Stefan Trethan
On Tue, 06 Jun 2006 08:28:21 +0200, stewart_bakeruk <stewart@...> wrote: > > When I asked my local chemist about it she looked at me as is I was a > serial poisoner ! > Cheers > Stewart > G3RXQ Either a chemical supply store or electronics supply store having pcb stuff. Both will see no reason to give you strange looks, the second usually sees fit to write a larger bill than the first. ST
2006-06-06 by Leon Heller
From: stewart_bakeruk To: Homebrew_PCBs@yahoogroups.com Sent: Tuesday, June 06, 2006 7:28 AM Subject: [Homebrew_PCBs] Ammonium Persulphate Hi, Although I have been a lifetime user (addict) to Ferrice Chloride, I would like to try something a bit cleaner. Can anyone advise where I can purchase small quantities of Ammonium Persulphate in the UK ? When I asked my local chemist about it she looked at me as is I was a serial poisoner ! I think that Mega Electronics sells it. Leon
Thanks to all of you who replied so promptly to my request. I now have some lines of enquiry to follow. Cheers & Beers Stewart G3RXQ --- In Homebrew_PCBs@yahoogroups.com, "stewart_bakeruk" <stewart@...> wrote:
> > Hi, > > Although I have been a lifetime user (addict) to Ferrice Chloride, I > would like to try something a bit cleaner. > > Can anyone advise where I can purchase small quantities of Ammonium > Persulphate in the UK ? > > When I asked my local chemist about it she looked at me as is I was a > serial poisoner ! > > Cheers > > Stewart > G3RXQ >
On Tue, 06 Jun 2006 08:51:03 +0200, Andrew <andrewm1973@...> wrote: > > HOWEVER - if you only etch one board in a > blue moon - Amonia Persulphate or FeCl are > probably better ideas. I wouldn't even be sure of that. There's no disadvantage of CuCl that i can see, so why would the others be better? As long as you have enough spare space to store your tank and two bottles of regenerating chemicals it really seems a good etchant. Of course if one can get the other etchants easier.... ST
It takes some time to make.
It takes some time to look after before use.
As you pointed out it takes some space.
Vapours from it can wreak things.
It does not etch as well as FeCl in an air
agitated tank. (line resolution)
You can't see the board like Amonia
Persulphate. (which may be good thing if
you only do a few boards and are not too
familiar with etching)
Your neighbours look at you funny and call
the anti-terrorisim hotline when you are
using it outside.
There will be some point where it is more
sensible to mix up disposable etchant and
then dispose of it.
That point might be one board in six months.
That point might be one board in two years.
I dont know where that point is - but it
will be somewhere.
For me - I am well above the point where CuCl
is a good idea and I love it very much (and
may marry it if Canberra changed the laws)2006-06-07 by Bill Maxwell
G'Day Andrew As you mentioned Canberra, could you tell me your source for the peroxide? I have no problem locating the acid, coutesy of swimming pool shops and hardware outlets but I have yet to embark on the search for a good source of peroxide in Oz. Thanks Bill ----- Original Message -----
From: "Andrew" <andrewm1973@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Wednesday, June 07, 2006 8:50 AM Subject: [Homebrew_PCBs] Re: Ammonium Persulphate >> > andrewm wrote: >> > HOWEVER - if you only etch one board in a >> > blue moon - Amonia Persulphate or FeCl are >> > probably better ideas. > >> ST wrote: >> I wouldn't even be sure of that. >> There's no disadvantage of CuCl that i can >> see, so why would the others be better? >> >> As long as you have enough spare space to >> store your tank and two bottles of >> regenerating chemicals it really seems a >> good etchant. Of course if one can get the >> other etchants easier.... > > It takes some time to make. > It takes some time to look after before use. > As you pointed out it takes some space. > Vapours from it can wreak things. > It does not etch as well as FeCl in an air > agitated tank. (line resolution) > You can't see the board like Amonia > Persulphate. (which may be good thing if > you only do a few boards and are not too > familiar with etching) > Your neighbours look at you funny and call > the anti-terrorisim hotline when you are > using it outside. > > There will be some point where it is more > sensible to mix up disposable etchant and > then dispose of it. > > That point might be one board in six months. > That point might be one board in two years. > > I dont know where that point is - but it > will be somewhere. > > For me - I am well above the point where CuCl > is a good idea and I love it very much (and > may marry it if Canberra changed the laws) > > > > > > > > > > > Be sure to visit the group home and check for new Links, Files, and > Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > Yahoo! Groups Links > > > > > > > >
2006-06-07 by Jeremy Taylor
Swimming Pool shops - It's called "shock" the brand I find around here is called baquil. it's 27% JT
----- Original Message ----- From: Bill Maxwell To: Homebrew_PCBs@yahoogroups.com Sent: Tuesday, June 06, 2006 8:11 PM Subject: Re: [Homebrew_PCBs] Re: Ammonium Persulphate G'Day Andrew As you mentioned Canberra, could you tell me your source for the peroxide? I have no problem locating the acid, coutesy of swimming pool shops and hardware outlets but I have yet to embark on the search for a good source of peroxide in Oz. Thanks Bill ----- Original Message ----- From: "Andrew" <andrewm1973@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Wednesday, June 07, 2006 8:50 AM Subject: [Homebrew_PCBs] Re: Ammonium Persulphate >> > andrewm wrote: >> > HOWEVER - if you only etch one board in a >> > blue moon - Amonia Persulphate or FeCl are >> > probably better ideas. > >> ST wrote: >> I wouldn't even be sure of that. >> There's no disadvantage of CuCl that i can >> see, so why would the others be better? >> >> As long as you have enough spare space to >> store your tank and two bottles of >> regenerating chemicals it really seems a >> good etchant. Of course if one can get the >> other etchants easier.... > > It takes some time to make. > It takes some time to look after before use. > As you pointed out it takes some space. > Vapours from it can wreak things. > It does not etch as well as FeCl in an air > agitated tank. (line resolution) > You can't see the board like Amonia > Persulphate. (which may be good thing if > you only do a few boards and are not too > familiar with etching) > Your neighbours look at you funny and call > the anti-terrorisim hotline when you are > using it outside. > > There will be some point where it is more > sensible to mix up disposable etchant and > then dispose of it. > > That point might be one board in six months. > That point might be one board in two years. > > I dont know where that point is - but it > will be somewhere. > > For me - I am well above the point where CuCl > is a good idea and I love it very much (and > may marry it if Canberra changed the laws) > > > > > > > > > > > Be sure to visit the group home and check for new Links, Files, and > Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed]
Might just prove a little tricky here in rural Tassie andrew but thanks for the tip. I'll give it a try. What strength was the hydroponics store stuff? Bill
----- Original Message ----- From: "Andrew" <andrewm1973@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Wednesday, June 07, 2006 10:31 AM Subject: [Homebrew_PCBs] Re: Ammonium Persulphate > Bill wrote: > G'Day Andrew > As you mentioned Canberra, could you tell me > your source for the peroxide? I have no > problem locating the acid, coutesy of swimming > pool shops and hardware outlets but I have yet > to embark on the search for a good source of > peroxide in Oz. Well - my reference to Canberra was the fact that the federal govt just overturned a law alowing gay marraiges. There reasoning for this was that the federal law defined marraige as a "union between a man and a woman to exclusion of others". This shot down my idea of marrying cupperic chloride that I love so much. (unless I can prove the chemical in question is female) I myself DON'T live in Canberra. I live in Brisbane. I get my H2O2 from a local hydroponics store. I guess there are keen tomoato growers all around OZ. I think I pay $15UAD for 500mL. Be sure to visit the group home and check for new Links, Files, and Photos: http://groups.yahoo.com/group/Homebrew_PCBs If Files or Photos are running short of space, post them here: http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ Yahoo! Groups Links
2006-06-07 by Andrew
> Bill wrote: > Might just prove a little tricky here in rural > Tassie andrew but thanks for the tip. I'll > give it a try. No hydroponics stores in Tassie ? Do they just grow their smoking tomatos out in the open down there :P Don't worry - I wont make any Tasmanian jokes. Here in Brissy we normally are too busy making Ipswich jokes. You can get buy without H202 for the CuCl etchant. It just makes it a lot easier to start it up. >What strength was the hydroponics store stuff? It was that stuff they call "40%" which is some measure of volume gas or something. It's realy 27% or something similar from what other posters have said.
2006-06-07 by fenrir_co
--- In Homebrew_PCBs@yahoogroups.com, "Andrew" <andrewm1973@...> wrote: > > > Bill wrote: > > Might just prove a little tricky here in rural > > Tassie andrew but thanks for the tip. I'll > > give it a try. > > No hydroponics stores in Tassie ? Do they just > grow their smoking tomatos out in the open down > there :P > > Don't worry - I wont make any Tasmanian jokes. > Here in Brissy we normally are too busy making > Ipswich jokes. > > You can get buy without H202 for the CuCl > etchant. It just makes it a lot easier to > start it up. > > >What strength was the hydroponics store stuff? > > It was that stuff they call "40%" which is some > measure of volume gas or something. It's realy > 27% or something similar from what other posters > have said. > Here in the states I get '40 Volume' to regenerate FeCl3, which is 12% I believe (About 3% per 10 Volume, which has to do with how much oxygen it gives off, the conversion is irritating) in hairdressers supply stores (Sally Beauty Supply for those who need it in the US). It's used as hair bleach. Other stores don't usually carry anything over 20 Volume. Peroxide over 3% (standard drugstore strength) is dangerous. Handle with care.
2006-06-07 by Mycroft2152
Oh,yes. check the Beauy Supply shops for H2O2. Y0u can ususally get up to 40 volume (12%). Myc --- Andrew <andrewm1973@...> wrote: > > Bill wrote: > > G'Day Andrew > > As you mentioned Canberra, could you tell me > > your source for the peroxide? I have no > > problem locating the acid, coutesy of swimming > > pool shops and hardware outlets but I have yet > > to embark on the search for a good source of > > peroxide in Oz. > > Well - my reference to Canberra was the fact > that the federal govt just overturned a law > alowing gay marraiges. There reasoning for this > was that the federal law defined marraige as a > "union between a man and a woman to exclusion > of others". > > This shot down my idea of marrying cupperic > chloride that I love so much. (unless I can > prove the chemical in question is female) > > I myself DON'T live in Canberra. I live in > Brisbane. > > I get my H2O2 from a local hydroponics store. > > I guess there are keen tomoato growers all > around OZ. I think I pay $15UAD for 500mL. > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
--- In Homebrew_PCBs@yahoogroups.com, "Jeremy Taylor" <jt@...> wrote: > > Swimming Pool shops - It's called "shock" the brand I find around >here is called baquil. it's 27% > > JT Be careful here, and make sure it's the right chemical. Most 'shock' I've seen is chlorine-based.
2006-06-07 by Stefan Trethan
On Wed, 07 Jun 2006 00:50:10 +0200, Andrew <andrewm1973@...> wrote: > It takes some time to make. Not really, if you start with HCl and H2O2 you can immediately etch boards and just have it grow. Remember the other etchants are usually made up from powder or crystals as well, unless you get bottled FeCl. > It takes some time to look after before use. Does it? I usually drop the board right in and then add some H2O2 if i believe it is too dark to make the board. Every few months (if i feel like it) i'll measure molarity and add HCl, usually while waiting for a board to etch. > As you pointed out it takes some space. It does, but the other etchants require some too (maybe less though). > Vapours from it can wreak things. Indeed that is an issue. You need a lid on the tank. I have found it doesn't have to be totally airtight but it should be closed. > It does not etch as well as FeCl in an air > agitated tank. (line resolution) Ok. > You can't see the board like Amonia > Persulphate. (which may be good thing if > you only do a few boards and are not too > familiar with etching) That's not the case if you use a narrow tank (say an inch wide max.) and a light from the back. Either a torch or recently i found those small garage fluorescent lights that you usually stick inside a car work well too because the light is nice and even. > Your neighbours look at you funny and call > the anti-terrorisim hotline when you are > using it outside. Don't show them ;-). The other etchants may cause funny looks too... ST
> > andrewm wrote: > ST Wrote : > > It takes some time to make. > Not really, if you start with HCl and H2O2 you > can immediately etch boards and just have it > grow. Ok - yeah - I suppose. I made my CuCl in a big batch to the right concentration/density before ever using it - and that took a few days. If you go the HCl + H202 route you can etch WHILE making it. Question for you though. Is it very aggressive on resist and does it undercut much when doing it like that ??? I have found if the acid is very high in my CuCl I seem to get more undercut than when it is lower. Is there a disadvantage to making it as you use it ? Or should I recomend that route to everyone that asks me ? > Remember the other etchants are usually > made up from powder or crystals as well, unless > you get bottled FeCl. Probably comes down to the philosiphy of "making CuCl" again. I made mine to be CuCl right from the outset rather than HCl+H2O2. And that was a lot more work than "add XXX grams of power to XXX mL of hot water" > > It takes some time to look after before use. > Does it? I usually drop the board right in and > then add some H2O2 if i believe it is too dark > to make the board. Every few months (if i feel > like it) i'll measure molarity and add HCl, > usually while waiting for a board to etch. Yeah - If you use it a lot you don't need to check it every time. Mine goes for weeks/months without use - so I have to check molarity/density almost every time before I use it. (usualy needs water) > > Vapours from it can wreak things. > Indeed that is an issue. You need a lid on > the tank. I have found it doesn't have to be > totally airtight but it should be closed. I solve the wreaking things problem by keeping it outside in a big PE storage box - (thats what leads to the last problem) > > Your neighbours look at you funny and call > > the anti-terrorisim hotline when you are > > using it outside. > > Don't show them ;-). The other etchants may > cause funny looks too... Ah - but I used to do my other etching inside. Now there is nasty HCl fumes I have to do it outside and wear clothes while etching. (maybe I am just moaning at having to wear clothes - I dont know) But - still big thumbs up to CuCl. ALL you people out there - if you etch regularly - use it :D
On Wed, 07 Jun 2006 10:56:54 +0200, Andrew <andrewm1973@...> wrote: > Ok - yeah - I suppose. I made my CuCl in a big > batch to the right concentration/density before > ever using it - and that took a few days. > If you go the HCl + H202 route you can etch > WHILE making it. > Question for you though. Is it very aggressive > on resist and does it undercut much when doing > it like that ??? > I have found if the acid is very high in my CuCl > I seem to get more undercut than when it is > lower. > Is there a disadvantage to making it as you use > it ? Or should I recomend that route to everyone > that asks me ? If you use large amounts of HCl and H2O2 it will definitely be more agressive. You'll tend to do that because you don't want to add stuff too often. But it isn't dramatic if you don't go crazy and make it too strong, you can definitely etch boards normally. If your tank allows it you can start with a lower qantity so there is space left for it to grow. You'll also reach higher densities faster. I started mine "from zero copper" and it worked very well. I had to add H2O2 each time for quite a long time, and i still need to regenerate about each second or third board now, the density is still way below normal. > Yeah - If you use it a lot you don't need to > check it every time. Mine goes for weeks/months > without use - so I have to check molarity/density > almost every time before I use it. (usualy needs > water) > Since i started from zero copper i have yet to reach normal density so i didn't add any water yet. A reason for not adding any form of copper was that i don't want to have to dispose of it unnecessarily. > Ah - but I used to do my other etching inside. > Now there is nasty HCl fumes I have to do it > outside and wear clothes while etching. > (maybe I am just moaning at having to wear > clothes - I dont know) lol, it would surely draw strange looks if you forgot the clothes while etching outside. I use CuCl inside with no problems. About half a meter to the right is the store for thin steel round stock (welding wire, piano wire,..) A meter to the left are my two 7k series tek scopes (which i would probably guard with my life ;-) ), and so far i haven't seen any corrosion at all that i would attribute to it. The key is to keep the HCl molarity as low as possible. It will also make it less agressive to OHP pen ink. During etching when the bubbler is on some fumes must surely escape, but with the lid on most droplets seem to deposit and run back into the tank. I ran it closed loop for a while but the droplets would stick the valves of the air pump. > But - still big thumbs up to CuCl. > ALL you people out there - if you etch > regularly - use it :D I only used FeCl before, what a pain with the stain... Also used HCl/CuCl without a permanent tank for a while, but the mesing about with bottles and cleaning and all really wasn't nice. It is great to have a tank that doesn't require any preparation or cleaning. I even made the PCB holder so it is operated by a lever from the outside, so i don't need to touch any "wet" parts or clean them. Sure one must consider if the effort is worth it, for one board a year it wouldn't pay to make a tank. ST
