Homebrew Low Cost Reflow Soldering Oven & Controller
2006-05-27 by kilocycles
Don't know if it's been posted here, but here is a link for a toaster oven and Atmel AVR homebrew controller: http://www.circuitcellar.com/avr2004/DA3788.html Regards, Ted
2006-05-27 by Stefan Trethan
On Sat, 27 May 2006 20:06:25 +0200, kilocycles <kilocycles@...> wrote: > Don't know if it's been posted here, but here is a link for a toaster > oven and Atmel AVR homebrew controller: > http://www.circuitcellar.com/avr2004/DA3788.html > Regards, > Ted I'd like a similar oven, but the controller would need to have a temperature display. Also, i still believe a mechanical carriage would be better to achieve a good profile (sliding the PCB in from the side). The need to cure direct printed ink will push this SMD soldering oven project right up on the list of things to do. I'd be glad to have a fully working PID software for the atmega8, though i will use a thermocouple instead of the thermistor. Maybe i can use part of that project. Anyway, i'm not feeling brave enough to face off that microcontroller right now, maybe next saturday, at noon ;-) Maybe i decide to build it analog in the end to avoid all problems.... ST
2006-05-28 by William Kroyer
I don't have any real experience with designing using microcontrollers but it looks like there is a pair serial data pins open on the processor. Perhaps a serial LCD and an addition to the code would work? Another option might be to just use that projects as the inspiration for a PIC controlled version. I know you can drive a HD44780 LCD directly from a PIC. I would think you could drive a serial LCD module as well though I haven't specifically looked into that since I've only tinkered with the HD44780 so far. Stefan Trethan wrote: >On Sat, 27 May 2006 20:06:25 +0200, kilocycles <kilocycles@...> >wrote: > > > >>Don't know if it's been posted here, but here is a link for a toaster >>oven and Atmel AVR homebrew controller: >>http://www.circuitcellar.com/avr2004/DA3788.html >>Regards, >>Ted >> >> > > >I'd like a similar oven, but the controller would need to have a >temperature display. Also, i still believe a mechanical carriage would be >better to achieve a good profile (sliding the PCB in from the side). The >need to cure direct printed ink will push this SMD soldering oven project >right up on the list of things to do. > >I'd be glad to have a fully working PID software for the atmega8, though i >will use a thermocouple instead of the thermistor. Maybe i can use part of >that project. > >Anyway, i'm not feeling brave enough to face off that microcontroller >right now, maybe next saturday, at noon ;-) >Maybe i decide to build it analog in the end to avoid all problems.... > >ST > > > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBs > >If Files or Photos are running short of space, post them here: >http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ >Yahoo! Groups Links > > > > > > > > > -- <www.kilroysprojects.net> [Non-text portions of this message have been removed]
2006-05-28 by Robert Hedan
> -----Message d'origine----- > De : Homebrew_PCBs@yahoogroups.com > [mailto:Homebrew_PCBs@yahoogroups.com] De la part de William Kroyer > Envoyé : mai 27 2006 22:56 > À : Homebrew_PCBs@yahoogroups.com > Objet : Re: [Homebrew_PCBs] Homebrew Low Cost Reflow > Soldering Oven & Controller > > > I don't have any real experience with designing using > microcontrollers > but it looks like there is a pair serial data pins open on the > processor. Perhaps a serial LCD and an addition to the code > would work? > > Another option might be to just use that projects as the > inspiration for > a PIC controlled version. I know you can drive a HD44780 LCD directly > from a PIC. I would think you could drive a serial LCD > module as well > though I haven't specifically looked into that since I've > only tinkered > with the HD44780 so far. > Driving a HD44780 is as simple as it gets on a PIC, LCDOUT some text and that's it. Serial LCDs, now you're getting into some heavy stuff. You can do it, but it's not a walk in the park like a parallel HD44780. There are several controllers out there, figuring out the required code is not easy for a novice. If you're lucky, someone out there already has posted what you need. Some LCDs have a built-in font, some do not, some have lousy documentation, some don't even have a controller. Here are just a few controllers to give you an idea of the variety, and I'm sure there's tons more: Epson S1D15G00 Epson S1D13700 Epson sed1330 Epson sed1520 Epson sed1565 Hitachi hd66712u Novatek nt3881d22 Samsung ks0066u Samsung ks0108b Sanyo lc7981 Sitronix ST7066-0A Sunplus lc780a1v15 Toshiba T6963C Toshiba T7932 If I had to recommend one as a starting point, the Toshiba T6963C. It may not be the best, but it is flexible and there are several examples of PIC BASIC Pro code out there (assuming you are using PBP). Also, controllers have hardware limitations; the T6963C cannot drive a 320x240 pixel LCD. And that's another thing, pay attention to what controller you will be using. I had to learn several before I ended up where I am, lots of frustration and wasted time. Good luck, and Google is your fiend; just search for the controller name and PIC BASIC. Robert :)
Yeah I used an HD44780 display in an MP3 player project for my van recently just because of how simple it was to interface with. The only reason I suggested maybe a serial LCD for this project is because the microprocessor appears to have a serial port open and probably wouldn't require a massive change to the schematic since the real changes would be in the code. I guess it comes down to whether one is more comfortable reworking the circuit or the programming. But if serial LCDs are that much of a pain starting from scratch using this project for inspiration might be the better way to incorperate an LCD. Either way I'd love to see someone do something like this with an LCD readout. Robert Hedan wrote: >>-----Message d'origine----- >>De : Homebrew_PCBs@yahoogroups.com >>[mailto:Homebrew_PCBs@yahoogroups.com] De la part de William Kroyer >>Envoy� : mai 27 2006 22:56 >>� : Homebrew_PCBs@yahoogroups.com >>Objet : Re: [Homebrew_PCBs] Homebrew Low Cost Reflow >>Soldering Oven & Controller >> >> >>I don't have any real experience with designing using >>microcontrollers >>but it looks like there is a pair serial data pins open on the >>processor. Perhaps a serial LCD and an addition to the code >>would work? >> >>Another option might be to just use that projects as the >>inspiration for >>a PIC controlled version. I know you can drive a HD44780 LCD directly >>from a PIC. I would think you could drive a serial LCD >>module as well >>though I haven't specifically looked into that since I've >>only tinkered >>with the HD44780 so far. >> >> >> > > >Driving a HD44780 is as simple as it gets on a PIC, LCDOUT some text and >that's it. > >Serial LCDs, now you're getting into some heavy stuff. You can do it, but >it's not a walk in the park like a parallel HD44780. There are several >controllers out there, figuring out the required code is not easy for a >novice. If you're lucky, someone out there already has posted what you >need. > >Some LCDs have a built-in font, some do not, some have lousy documentation, >some don't even have a controller. Here are just a few controllers to give >you an idea of the variety, and I'm sure there's tons more: > >Epson S1D15G00 >Epson S1D13700 >Epson sed1330 >Epson sed1520 >Epson sed1565 >Hitachi hd66712u >Novatek nt3881d22 >Samsung ks0066u >Samsung ks0108b >Sanyo lc7981 >Sitronix ST7066-0A >Sunplus lc780a1v15 >Toshiba T6963C >Toshiba T7932 > >If I had to recommend one as a starting point, the Toshiba T6963C. It may >not be the best, but it is flexible and there are several examples of PIC >BASIC Pro code out there (assuming you are using PBP). Also, controllers >have hardware limitations; the T6963C cannot drive a 320x240 pixel LCD. And >that's another thing, pay attention to what controller you will be using. I >had to learn several before I ended up where I am, lots of frustration and >wasted time. > >Good luck, and Google is your fiend; just search for the controller name and >PIC BASIC. > >Robert >:) > > > > > >Be sure to visit the group home and check for new Links, Files, and Photos: >http://groups.yahoo.com/group/Homebrew_PCBs > >If Files or Photos are running short of space, post them here: >http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ >Yahoo! Groups Links > > > > > > > > > > -- <www.kilroysprojects.net> [Non-text portions of this message have been removed]
2006-05-28 by Stefan Trethan
On Sun, 28 May 2006 04:55:38 +0200, William Kroyer <william.kroyer@kilroysprojects.net> wrote: > I don't have any real experience with designing using microcontrollers > but it looks like there is a pair serial data pins open on the > processor. Perhaps a serial LCD and an addition to the code would work? > Another option might be to just use that projects as the inspiration for > a PIC controlled version. I know you can drive a HD44780 LCD directly > from a PIC. I would think you could drive a serial LCD module as well > though I haven't specifically looked into that since I've only tinkered > with the HD44780 so far. I'd much prefer a parallel LCD. Even i could add that in about 5 minutes since i already have code for it. Actually the display was the first thing working with my atmel, most of the time, anyway. But the thing is, i bought a handful of 24x2 displays at a surplus sale for 2eur each, but they have no backlight. I don't like LCDs without backlight. But i don't like buying parts when i have suitable ones at hand either... ST
2006-05-28 by mycroft2152
A parallel display can take up too many pins for the application. Most serial display are much more expensive. A good compromise is to use the PH Anderail serial driver kit for LCD's. These kits start at $5 and included a dedicated PIC acting as a serial to parallel LCD controller. The PIC takes care of all the overhead and has a built in command structure for display commands and works great! These guys http://www.wulfden.org/k107/index.shtml have just introduced a pcb to go along with PH Anderson's kit. It worth taking a look at. Myc --- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Sun, 28 May 2006 04:55:38 +0200, William Kroyer > <william.kroyer@...> wrote: > > > I don't have any real experience with designing using microcontrollers > > but it looks like there is a pair serial data pins open on the > > processor. Perhaps a serial LCD and an addition to the code would work? > > Another option might be to just use that projects as the inspiration for > > a PIC controlled version. I know you can drive a HD44780 LCD directly > > from a PIC. I would think you could drive a serial LCD module as well > > though I haven't specifically looked into that since I've only tinkered > > with the HD44780 so far. > > > I'd much prefer a parallel LCD. Even i could add that in about 5 minutes > since i already have code for it. > Actually the display was the first thing working with my atmel, most of > the time, anyway. > > But the thing is, i bought a handful of 24x2 displays at a surplus sale > for 2eur each, but they have no backlight. I don't like LCDs without > backlight. But i don't like buying parts when i have suitable ones at hand
> either... > > ST >
On Sun, 28 May 2006 15:32:20 +0200, mycroft2152 <mycroft2152@...> wrote: > A parallel display can take up too many pins for the application. > Most serial display are much more expensive. > A good compromise is to use the PH Anderail serial driver kit for > LCD's. These kits start at $5 and included a dedicated PIC acting as > a serial to parallel LCD controller. > The PIC takes care of all the overhead and has a built in command > structure for display commands and works great! > These guys http://www.wulfden.org/k107/index.shtml have just > introduced a pcb to go along with PH Anderson's kit. It worth taking > a look at. > Myc I'd prefer not to use another micro, if i really had to it would be an atmel so is it compatible with the rest. There's also a schematic out there showing how one can use an attiny or someting with very few (like 2 or 3) outputs to drive a hd... parallel LCD. I think they used a simple shift register. Anyway, not sure, i guess i would even prefer LED display here... Probably easier for me to just use a standard led panelmeter circuit (should have some of those around) and do the rest of the control analog as well. ST
2006-05-28 by Mycroft2152
To each his own.... The fact that Anderson used a PIC chip is irrelevant. You just send it a serial text command and it does the rest. Just like any ther serial LCD dispaly. Myc --- Stefan Trethan <stefan_trethan@...> wrote: > On Sun, 28 May 2006 15:32:20 +0200, mycroft2152 > <mycroft2152@...> > wrote: > > > A parallel display can take up too many pins for > the application. > > Most serial display are much more expensive. > > A good compromise is to use the PH Anderail serial > driver kit for > > LCD's. These kits start at $5 and included a > dedicated PIC acting as > > a serial to parallel LCD controller. > > The PIC takes care of all the overhead and has a > built in command > > structure for display commands and works great! > > These guys http://www.wulfden.org/k107/index.shtml > have just > > introduced a pcb to go along with PH Anderson's > kit. It worth taking > > a look at. > > Myc > > > I'd prefer not to use another micro, if i really had > to it would be an > atmel so is it compatible with the rest. > > There's also a schematic out there showing how one > can use an attiny or > someting with very few (like 2 or 3) outputs to > drive a hd... parallel > LCD. I think they used a simple shift register. > > Anyway, not sure, i guess i would even prefer LED > display here... > > Probably easier for me to just use a standard led > panelmeter circuit > (should have some of those around) and do the rest > of the control analog > as well. > > > ST > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> > You can search right from your browser? It's easy > and it's free. See how. > http://us.click.yahoo.com/_7bhrC/NGxNAA/yQLSAA/bGYolB/TM > --------------------------------------------------------------------~-> > > > Be sure to visit the group home and check for new > Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post > them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > > Yahoo! Groups Links > > > Homebrew_PCBs-unsubscribe@yahoogroups.com > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
On Sun, 28 May 2006 15:56:25 +0200, Mycroft2152 <mycroft2152@...> wrote: > To each his own.... > The fact that Anderson used a PIC chip is irrelevant. > You just send it a serial text command and it does the > rest. Just like any ther serial LCD dispaly. > Myc Yes, but i'm afraid i will take longer to get the serial comms working than anything else ;-) It would probably be easier for me to go with the next larger micro to get those additional pins for parallel mode. The idea of serial displays is a good one. Data volume is low, IO pins are expensive and brains inside the micro is cheap, so it is obvious to go serial. Having a converter might well be the most cost effective way since the parallel displays are still so widely available. ST
2006-05-30 by kilocycles
Stefan, Myc et al, The source page from which I found the link to the Atmel-AVR-controlled oven did have information, and code, for using various types of Atmel microcontrollers with HD44780 parallel LCDs. I'm more familiar with PICs, myself, and that means I've only toner-transferred the PCBs for the programmers and dumped hex code into the via the parallel port. I am working on an Atmel programmer for the AT90S2313, simply because I bought a bunch of them on eBay to make an LCF meter that reads out inductance, capacitance and frequency in Morse code, rather than the ubiquitous similar ones using PICs that display on LCDs. They are cheap, and I intend to give away the programmed chips and PCBs (the other components are fairly trivial) at our local low-power ham radio club meeting soon. Unfortunately, I'm at the wrong computer, and I don't have the link to the forum on this one. It was not avrfreaks.net, though. I'll find it and re-post it. They had a lot of interesting hardware projects on that forum. Regards, Ted --- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Sun, 28 May 2006 15:56:25 +0200, Mycroft2152 <mycroft2152@...> > wrote: > > > To each his own.... > > The fact that Anderson used a PIC chip is irrelevant. > > You just send it a serial text command and it does the > > rest. Just like any ther serial LCD dispaly. > > Myc > > > Yes, but i'm afraid i will take longer to get the serial comms working > than anything else ;-) > It would probably be easier for me to go with the next larger micro to get > those additional pins for parallel mode. > > The idea of serial displays is a good one. Data volume is low, IO pins are > expensive and brains inside the micro is cheap, so it is obvious to go > serial. Having a converter might well be the most cost effective way since > the parallel displays are still so widely available. > > ST ---snip---
