Qu about old reflow solder paste
2006-05-25 by Trevor Matthews
Hello out there!
  I've been experimenting with an old skillet in an effort to develop a
safe homebrew reflow profile.
  To test my reflow profile, I've been cooking scrap pieces of PCB with
a small quantity of old RS electronics solder paste on the board to
check that the solder melts etc.  The paste is best before wk 50, 2003.
  During these reflows, I heat the board to 225C max.  I have noticed
that the paste forms a crust on the board, which can be wiped off (as
per Stefans  suggestion)  but am concerned about the crust with respect
to its affect on component joints.
  Does this crust form on in date paste on component joints??
  Thanks for your help
  Trev
Re: [Homebrew_PCBs] Qu about old reflow solder paste
2006-05-25 by Stefan Trethan
On Thu, 25 May 2006 11:30:00 +0200, Trevor Matthews
>  Trev
Ok, this crust must be different from the one i described when using
plumbing paste for tinning.
Does it seem to contain tin particles or is it flux?
Will it reflow fully if you crank up the temperature a bit more (maybe try
with soldering iron if the skillet doesn't go higher).
I also use old SMD paste, it seems less tacky and harder to apply, but it
doesn't form a crust. I don't really think the old age is the problem.
Not sure.. but my gut feeling tells me your might have too low temperature.
Thanks for posting on list, i'm sure you'll see the benefit of other
people respondingn soon.
ST
2006-05-26 by Trevor Matthews
>> Trev
My next attempt with scrap was going to let the skillet go higher and
see what happens, but I've tried to melt it with my soldering iron -  I
can move it about and see bright tin underneath, but it doesn't change
the consistancy of the crust at all.  I thought I might try to reflow
the paste with just my soldering iron and see what happens then as well.
  Unfortunately, I can't run my skillet much higher than 180C without
leaving the lid on, which means I can't see what happens to the paste as
it melts, so I can't check to see if the crust is there straight away,
or if it forms over time (as it would if it melts, then oxidises as
temperature rises and as time increases)
thanks for your help
Trev
2006-05-26 by Stefan Trethan
On Fri, 26 May 2006 03:06:21 +0200, Trevor Matthews
> Trev
OK, if the crust does not melt/reflow when heated with an iron directly,
at normal soldering temperatures, i'm pretts sure something is wrong with
the paste.
I can assure you "working" SMD paste does not form a crust, it will reflow
with a shiny surface and some flux residue.
ST
2006-05-27 by Trevor Matthews
>>Trev
>the paste.
>ST
I've tried a couple of things and here are my results:
    1) I placed a couple of blobs of paste on my scrap PCB and melted
them with my soldering iron - success, the flux burnt off, and nice
shiny paste.  Even the paste I did not heat directly did the right thing.
    2)  Heated the scrap PCB in the skillet to about 250C.  No change to
the previous - grey looking surface to the reflowed paste.  Took the lid
off while it was still very hot and there was a puddle of grey surfaced
paste with a brown/yellow liquid (?flux) mixed in and surrounding it.
    3) Tried again without the lid on.  Noticed at about 120-150C the
paste seemed to partially melt - there was small balls of bright solder
inside the grey muck.  Over the next 20-30C the balls seemed to
disappear under the grey stuff.  The flux did not obviously activate, no
fumes. Continued to let the board heat up. Got the board so hot that the
substrate started to smoulder and the binding glue bubbling out the
sides of the board.  Still no joy.  Thought I'd try adding my soldering
irons heat to the process to see what happened.  Flux activated and the
paste seemed to do the right thing.
  Theory:  Skillet not transferring enough heat to the paste.  Would it
have anything to do with the board being unetched????
  Don't know how to fix the problem.  Should I try a toaster oven??
sparkfun.com document lots of problems with melting SMD connectors using
an oven and I've already tried to hand solder one compact flash
connector to a board - I'd prefer to reflow it with the other smd
devices if I could.
  What do those experts out there think???
  Trev
2006-05-27 by Russell Shaw
>>>Trev
>>the paste.
> devices if I could.
Should use a higher temperature for a shorter time to reduce oxidation
problems. Try 350degC.
2006-05-27 by Stefan Trethan
On Sat, 27 May 2006 05:16:45 +0200, Trevor Matthews
> devices if I could.
>  Trev
I still think your temperature is too low.
What board material did you use that decomposed?
I don't use a hotplate, so i don't know the tricks there, i use hot air
 from the component side.
Maybe try that. You need a hot air gun (preferrably with temperature
control) or some other hot air tool.
The oven could be just as problematic if you cannot get the temperature to
rise fast enough.
ST
2006-05-27 by Leon Heller
Sent: Saturday, May 27, 2006 4:16 AM
Subject: Re: [Homebrew_PCBs] Qu about old reflow solder paste
> devices if I could.
I just repeated your experiment. Not having a suitable skillet I just used
the hotplate on the electric stove (don't know the temp, I just guessed the
setting), and it worked perfectly! I just put a couple of blobs of solder on
a small scrap of polished SRBP PCB material (easier to cut than FR4) and put
it on the hotplate. In a couple of minutes or so the blobs liquified and
spread out, then the flux burnt off leaving little puddles of nice shiny
solder, surrounded by flux residue. Your paste must be knackered, you need
to buy some new good quality new stuff. I used Warton Metals Microprint
P2004, in a syringe.
Suitable electric skillets are difficult to get hold of here in the UK, so I
might try using the stove hotplate for a real board. I do have a toaster
oven, but haven't tried it yet.
Leon
Leon Heller, G1HSM
leon.heller@...
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Re: Qu about old reflow solder paste
2006-05-27 by mycroft2152
Leon,
You are comparing apples and bananas. He said in his original
message he was using Radio shack solder paste. This is identical to
the plumbers paste for use on copper pipes, I have both, It is not
the refined version for smt pcb's and has none of the
characateristics.
The plumber's paste is designed to be reflowed with a propane torch.
The only apparent advantage for the plumber pastes is that it is
very cheap.
Myc
--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller"
<leon.heller@...> wrote:
> From: "Trevor Matthews" <trev.matthews@...>
melted
nice
right thing.
change to
the lid
surfaced
surrounding it.
solder
activate, no
that the
soldering
and the
Would it
oven??
connectors using
> > devices if I could.
just used
guessed the
solder on
FR4) and put
liquified and
shiny
you need
Microprint
the UK, so I
toaster
> Leon
> Leon Heller, G1HSM
> leon.heller@...
responsibility
are
Re: [Homebrew_PCBs] Re: Qu about old reflow solder paste
Sent: Saturday, May 27, 2006 11:45 AM
Subject: [Homebrew_PCBs] Re: Qu about old reflow solder paste
Leon,
characateristics.
very cheap.
I wouldn't even have bothered trying the stuff, it's obvious it would be a
waste of time!
Leon
On Sat, 27 May 2006 12:52:08 +0200, Leon Heller
<leon.heller@bulldoghome.com> wrote:
> Leon,
> characateristics.
> very cheap.
> a
> waste of time!
> Leon
What? Radio shack sells plumbing paste? I thought this was an electronics
place?
Of course then it will not work like it should! The plumbing paste seems
to need much higher temperature to fully reflow, compared to the SMD
paste. I suggest the OP gets some real SMD paste from a reputable supplier
(that excludes Radio Shack) and it will work.
ST
2006-05-27 by Mycroft2152
Radio shack seels "Solder Paste" It is the samll as
plumbers paste in a smaller, more expensive package.
Myc
> > Leon,
> his original
> both, It is not
> the
> > characateristics.
> is that it is
> > very cheap.
> > a
> > waste of time!
> > Leon
> place?
> compared to the SMD
> ST
> Everything you need is one\ufffdclick away.\ufffd Make Yahoo!
> your home page\ufffdnow.
http://us.click.yahoo.com/AHchtC/4FxNAA/yQLSAA/bGYolB/TM
> Be sure to visit the group home and check for new
> Links, Files, and Photos:
> If Files or Photos are running short of space, post
> them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
>     Homebrew_PCBs-unsubscribe@yahoogroups.com
Do You Yahoo!?
http://mail.yahoo.com
2006-05-28 by Trevor Matthews
Leon,
  I'm not sure that we're talking about the same company.
  I got this (what I thought was) electronics solder paste from
www.rsaustralia.com.au.  I thought they (RS components) were different
from Radio Shack.  I understood that radio shack in the US was tandy
here is aus.
  RS Components certainly advertised this as SMD solder paste.
  Could someone please clarify
Trev
>From: "mycroft2152" <mycroft2152@...>
>Leon,
>characateristics.
>very cheap.
>waste of time!
>Leon
>If Files or Photos are running short of space, post them here:
>Yahoo! Groups Links
2006-05-28 by Leon Heller
Sent: Sunday, May 28, 2006 11:56 AM
Subject: Re: [Homebrew_PCBs] Re: Qu about old reflow solder paste
Leon,
here is aus.
That *should* be OK, I buy a lot of stuff from RS Components here in the UK.
What is the actual RS part number? Perhaps your problems are due to it being
old stock.
Everyone seems to have assumed it was Radio Shack/Tandy.
Leon
2006-05-29 by Andrew
> solder paste from www.rsaustralia.com.au.
> shack in the US was tandy here is aus.
Yes - RS Components is in full "Radio Spares"
RS Components is common to those of us in OZ
or UK. (like Leon and Trevor)
For the Americans and others out there - RS
Components is kinda like an over priced
Digikey with less stock.  (Though I must
admit in the last 5 year RS has picked up
the game a lot and are much better prices
now)
RS to the Americans is Radio Shack.
Tandy in Australia WAS Radio Shack until just
about 2 years ago.  They did sell a lot of
Radio Shack branded goods.  I think they only
managed to survive on sales of telephone
answering machines and butane torches that
could be adapted to become bulbulators.
Today Tandy in OZ is owned by Dick-Smith-
Electronics/Woolworths/Adelaide-Steamships.
They seem to be consolitating and are
selling less and less Radio Shack gear.
We can only hope they don't stop selling
the bulbulators.
2006-05-29 by Trevor Matthews
Stock number 184-9985
    (It is quite old best before wk 50, 2003 it's remained in the fridge
apart from a few mins each use.  It is a multicore solder, "No clean RMA
dispensing solder cream"
  Trev
>Leon,
>here is aus.
>old stock.
>Leon
>Yahoo! Groups Links
2006-05-29 by leon.heller@bulldoghome.com
I'd have thought that would work without any problems. I'd buy some more
and see how that behaves.
Leon
2006-05-29 by Mycroft2152
Ok, I;ll bite.
What is a "bulbulator"?
Myc
> now)
> the bulbulators.
Do You Yahoo!?
2006-05-29 by lists
In article <e5dfrp+kn6i@...>,
Well, used to be. In those days they specialised in electronic parts for
the TV and radio repair trade.
See:
http://www.rs-components.co.uk/
Judging by the last Digikey catalogue I saw, RS beats them hand over fist
at least for the UK market. Prices of everything are much lower in the
states whoever sells them.
Not that I use RS veru much, I prefer Farnell or CPC.
Bulbulator question - was - Re: Qu about old reflow solder paste
> > the bulbulators.
> myc wrote:
> Ok, I;ll bite.
bulbulator n. Any device used for removing
the contents of a whipped cream bulb for
other more interesting uses than whipping
cream.
Some people even use those whipped cream
bulbs for hotting up their little 20cc
2 stroke push scooters these days :D
I am not sure that Nitrous Oxide has any
use in the home made PCBs though.
