Epson R220 Printer - compatible with the MIS Inks?
2006-05-16 by lcdpublishing
2006-05-16 by Chris Horne
> I was just about to purchase the R220 printer from Epson, but noticed
> that it doesn't use the durabrite inks (or doesn't say so
> specifically). Somewhere buried in all this talk about ink jet
> printers and such, I recall talk about using a printer that uses
> durabrite inks.
> Am I on right or wrong on this? I already have the MIS inks on hand,
> so that is the path I am walking down right now :-)
> Chris
>the
> Not an answer, but an expansion to chris's question..
> Will the Mispro ink under discussion work succesfully in any of the
> non-durabrite epson printers.. ?
> specifically any of the CD printing versions.
> Has anyone been brave enough to try it?
> given the right conditions
> We know that the ink will print on copper
> We know that the ink will resist etchant
> What we don't have is a cheap straight path printer that will take
> ink.contribute
> I think a definitive answer is in order and I am willing to
> toward someone who can provide the answer if it wrecks theirprinter.
>noticed
> There are so many variables (nozzle design, excess ink removal,
> software etc..) that it is impossible to even guess at the answer..
> Chris (a different Chris)
> > that it doesn't use the durabrite inks (or doesn't say sohand,
> > durabrite inks.
> > Chris
2006-05-16 by Alan King
>Not an answer, but an expansion to chris's question..Impossible is a big word.. :) Easy enough to take an ok guess from a
2006-05-16 by Mycroft2152
> I was just about to purchase the R220 printer from__________________________________________________
> Epson, but noticed
> say so
> about ink jet
> printer that uses
> durabrite inks.
> MIS inks on hand,
> Chris
> Hi Chris (other Chris)
> If I don't get any confirmation one way or the other by the end of
> the day, I am probably going to buy the printer anyway. I can use
> it for it's original intended purpose.
> Without modification, I am hoping I can print on some small PCBs and
> do some testing with the Epson Ink, followed by the MIS inks.
> So, I will be doing some testing and experiments on this printer one
> way or another.
> By chance, does anyone know how to suck the standard ink out and
> replace it with the MIS inks?
> Chris (the other chris)
> --- In Homebrew_PCBs@yahoogroups.com, "Chris Horne" <chris@>
> the
> > ink.
> contribute
> printer.
> noticed
> > > durabrite inks.
> hand,
> > > Chris
2006-05-16 by fenrir_co
>I believe the ink being discussed is not even a pigment based ink, so
> way or another.
>This week the R220 is on sale at Circuit City for $99Forgot to mention, the R320 is on close out at Radio Shack and
>with a $20 Circuit City card.
>TANSTAAFL!
>Myc
2006-05-16 by Cristian
>Not an answer, but an expansion to chris's question..See my posting to MIS' Forum.
>Why not buy empty spongeless cartridges from MIS?
2006-05-16 by Stefan Trethan
> I was just about to purchase the R220 printer from Epson, but noticedIt does have 90 nozzles for each color, just like the one Volkan is using.
> durabrite inks.
> Chris
2006-05-17 by Trevor Matthews
2006-05-17 by Cristian
>But how you'll cheat it to print on a square PCB?
2006-05-17 by Stefan Trethan
> Hello all,I tried, but it is no good. The reason is it gets runny like water when
> I just want to confirm my understanding of using plumbers solder paste.
> I beleive people are using it to tin their board before populating,
> and use several thin layers of paste to completely tin a PCB. Does
> anyone use this paste for SMD soldering?? What about down to 0.5mm
> pitch??
> I am just about to try my first SMD board, with parts down to 0.5mmThe dry crust seems normal, i wipe it off with a paper towel.
> and given that electronic soler paste has a very limited shelf life and
> the infrequent use I will have for it if I have to use regular paste for
> SMD work I may as well use it for tinining as well.
> BTW, I've run a test reflow following an 'average' profile to 225C
> using a skillet style (see sparkfun.com) of setup, unetched board and
> regular paste which was best before end 2003. The paste formed a crusty
> grey coating over nicely tinned copper. It almost looks like a nasty
> dry joint. If you scrape the crust off the solder there is a nice shiny
> tinned copper surface, I've tried several different types of solvent but
> nothing seems to dissolve it. Any ideas of what this is and how to get
> rid of it???? and before you flame me over the use of the very out of
> date paste, I knew it was out of date & I just wanted to see if the
> reflow profile worked on a scrap piece of PCB.
> Thanks heaps
> Trevor
2006-05-17 by Steve
>That is the whole -point- to third party pigmented inks such as MIS's.
> durabrite inks.
2006-05-17 by Steve
> What we don't have is a cheap straight path printer that will take the
> ink.
> I think a definitive answer is in order and I am willing to contribute
> toward someone who can provide the answer if it wrecks their printer.
2006-05-17 by Steve
>... As you mentioned may require keeping the landing area clean etcNot really. It gets sucked down into the waste pad the same as dye
> since the pigment ink may have a little more residue...
> ... Seems most everything even remotely modernThe general rule: if Epson gives the ink a fancy name (Durabrite,
> that uses durabright has a badge for it on the front..
2006-05-17 by lcdpublishing
