Homebrew_PCBs
Making the PCB
Making the PCB
2006-04-04 by LogicResearch
Ok,
Now I have my chemicals and PCB etc, it's time to experiment with making the
boards.
I'm using photo resist and developer etc - should I just experiment with
times or does somebody have a good suggestion.
cheers,
Daryl.
Re: [Homebrew_PCBs] Making the PCB
2006-04-04 by Leon Heller
Sent: Tuesday, April 04, 2006 8:22 AM
Subject: [Homebrew_PCBs] Making the PCB
> Ok,
> the
> boards.
The development is easy, just make sure you have the right concentration and
you can see when the resist has been removed - it turns purple in the
solution. It only takes about 30 seconds or so for me with NaOH.
For the UV exposure you need to experiment. Best way is to use a technique
like the test strip used in photography and make a test pattern. Put the
pattern and PCB in the UV exposure unit and move a cardboard mask across
every minute and see what exposure gives the best results. I use 13 minutes
but I've only got two tubes and they are quite far from the glass.
Leon
Leon Heller, G1HSM
leon.heller@...
Cheers,
My resist is green and I have found that 9 minutes is getting close.
Some areas are really good with well defined tracks, some areas are still
lost in the green haze.
More practice I guess.
Daryl.
Sent: Tuesday, April 04, 2006 8:20 PM
Subject: Re: [Homebrew_PCBs] Making the PCB
> From: "LogicResearch" <logicresearch@...>
>> Ok,
>> the
>> boards.
> and
> minutes
> Leon
> Leon Heller, G1HSM
> leon.heller@...
> Photos:
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.385 / Virus Database: 268.3.4/299 - Release Date: 03/31/06
Sent: Tuesday, April 04, 2006 9:33 AM
> Cheers,
Make sure that the PCB material is fresh - the resist can deteriorate if it
is old stock, and it won't work properly. I find it starts to go off if I
keep it longer than six months or so.
Leon
Leon Heller, G1HSM
leon.heller@...
Thanks for that, this should be fresh as I just brought it but who knows how
long it's been sitting on RS's shelf.
Another thing I thought of is that it had not dried properly.
I have another set of practice boards curing overnight that I will play with
tomorrow.
Is there a better etchant than Ferric Chloride?
Will I ever get some sleep?
Thanks for the help.
Daryl.
Sent: Tuesday, April 04, 2006 9:00 PM
>> Cheers,
> it
> Leon
> Leon Heller, G1HSM
> leon.heller@...
> Photos:
Sent: Tuesday, April 04, 2006 1:39 PM
> how
> with
> tomorrow.
Are you using pre-coated boards or coating them yourself?
The uneven etching due to resist remaining after development is a sign that
it might be old stock, if the boards are pre-coated. Is RS Radio Shack or RS
in the UK? The latter will be OK.
You don't need to dry the boards after development, just rinse them well
and put them straight in the etchant. I use ferric chloride because it can
be re-used many times,unlike ammonium or sodium perchlorate.
Leon
Leon Heller, G1HSM
leon.heller@...
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
I'm in New Zealand so it RS probably Australian stock and its the spray on
stuff from a can although I might try the pre coated boards.
> that
> RS
> Leon
> Leon Heller, G1HSM
> leon.heller@...
> Photos:
Sent: Tuesday, April 04, 2006 7:09 PM
I've never been able to get that spray-on resist to work! It was OK until
they changed the formula a few years ago. The pre-coated boards will work
much better.
Leon
Leon Heller, G1HSM
leon.heller@...
2006-04-05 by LogicResearch
Hi again.
Well so much for that - I was going to continue trying to get a good
development but I might as well try something else as I need to get some
PCBs made soon.
I have just finished an email to a knowledgeable fellow, to whom I admitted
that the new photoresist from RS may as well have been a can of whipped
cream for all the good it does.
The reason I am back here again is that I have found (whilst looking for
Riston PCB's) Press 'n' Peel film.
Simply (as they say) copy or print the artwork onto this film with a laser
printer, Iron onto the blank PCB, peel off the film, and etch - simple.
Has anyone used this before and is it as good as they say?
Also I see another chemical, Ammonium Persulphate, that I have never used -
anyone use this and does it have any advantages over Ferric Chloride?
cheers,
Daryl.
Sent: Wednesday, April 05, 2006 8:33 AM
>> on
> much better.
> Leon
> Leon Heller, G1HSM
> leon.heller@...
> Photos:
2006-04-05 by Leon Heller
Sent: Wednesday, April 05, 2006 7:00 AM
> Hi again.
> PCBs made soon.
> admitted
Some people get good results, with a lot of messing about with heated
laminators. I've never been able to get it to work properly, using an
ordinary clothes iron.
> used -
It's a lot cleaner as the solution is colourless, and the board is visible
during etching. It won't keep when made up, fresh solution has to be used
each time.
Leon
Leon Heller, G1HSM
leon.heller@...
2006-04-05 by Stefan Trethan
On Wed, 05 Apr 2006 08:00:32 +0200, LogicResearch
> laser
I don't use press and peel, i use inkjet paper which has a special coating
that easily releases the toner.
Many use this method here with great results, it's called toner transfer.
I find it much less work and much faster than when i had to mess around
with film printing, exposure, developing, and photoresist. I wanted to use
old board stock back then, which i know now just doesn't work well, and it
is totally against my nature to throw something away only because it is
old and buy new stuff, so i never liked it. Coating boards myself with
spray-on resist or film didn't seem practical either.
Toner transfer is a lot cheaper overall and the results are just as good
(well, a lot better actually if you compare to the desasterous
photoprocess i used...).
Look in the links section and in the archives if you want to learn more.
It seems to me most people who use it long term with good results don't
use press and peel but instead various other papers. I'm not sure if it is
just because it is cheaper or maybe press and peel might not be that good
after all, i dunno.
> used -
I think it doesn't stain so badly.
You might want to look at CuCl etchant if you want something new. Also
see-through in thin enough tanks and you can regenerate it time and time
again which is probably most often why it is used...
ST
2006-04-05 by Kamal Shankar
I knew about TonerTransfer method using laser printer
(just bought some glossy paper and printed the traces,
iron and done)
But does this work for Inkjet too ?
Since you have done it, can you please tell me what
brand of special paper you use ?
Also, how consistent are the results and what's the
minimum track width & clearance you can manage using
the inkjet ?
Do You Yahoo!?
http://mail.yahoo.com
Sent: Wednesday, April 05, 2006 9:02 AM
> iron and done)
> the inkjet ?
Inkjets don't work for TT. I use one for making transparencies for the
conventional PCB technique and don't have any problems with 8/8 mil design
rules.
Leon
Leon Heller, G1HSM
leon.heller@...
On Wed, 05 Apr 2006 10:02:53 +0200, Kamal Shankar
> iron and done)
> the inkjet ?
No it doesn't work with inkjet printers. The inkjet paper is used only
because it has a special coating, in a laser printer.
The results are very consistent once you know how to do it. (consistent
enough so that i can be confident every board will be a success.)
The minimum width i can reliably make is 6.66mil. Below that traces will
break up due to underetching, transfer itself will work lower (e.g for
text as component legend). Gap width can be 6.66mil too, but the closer
the traces are together the more attention you must put into removing the
paper - it will easily remain in those small gaps unless you rub there
with a sponge or your finger. I usually use 10 mil clearance which does
not need special attention. For most boards i will also use 10mil minimum
trace width because there is plenty of space.
ST
