Re: Success using Press-n-Peel and H202 HCL etch
2006-02-28 by Richard
Thanks for the good report.
As others mentioned, you might try thermal-relief pad styles.
And get a higher-power iron with internal temp feedback.
It is a common fallacy, which you see all the time, that
you can damage parts by using "too big an iron", or "too
hot an iron".  That's generally baloney.
You damage a part by getting it too hot....and you get it
too hot by the integral of temp and TIME.  And when you
use too small an iron for the job, you have to leave it on
there near -forever-, to get the joint up to temp.
By the time the joint's up to temp, the whole damn -part-
is up to 500+ degrees.  Not good.  The -right- way is to
use a powerful enough iron that you get the -joint- up
to temp -instantly-, and get the heck -off- it; before the
heat has even had a chance to flow up the leads into
the part.
The Pace stations I've used for years now have 70+ watt
irons.  No bigger physically than the usual "25w"; but ever
so much quicker at soldering.  The design of the tips is
also slick...with a very thick section inside the barrel; so
that the thermal-path is very low resistance to the tip; and
so that there is great thermal-mass storing heat behind
that path.
Even with a typical .062" tip, it will properly flow a joint
on a ground plane almost instantly...1-2 seconds at most.
I do quite a bit of RF work myself; along with a lot of
power-electronics; so I face the ground-plane thing a lot.
I should add that these irons are also temp-controlled.  Not
with just a "dimmer" type of variable power-input; but with an
actual temp-sense right up in the barrel; and a feedback
servo control in the power-supply.
You set the temp at 650-700 with the knob, and it will stay
right there, whether you're soldering joint after joint with it;
or letting it sit on the stand.  Very very nice units.
I've seen them go on ePay for a hundred bucks....which
is an -excellent- bargain if they're in good working order.
(they cost $700-1000 new).  By the way, I'm not talking
about just an iron here....I'm talking about the DEsoldering
station with the vacuum handpiece too.  One of these is
a DREAM to have on your bench.  I couldn't live without it.
Once you're skilled with it, you can suck a 40p DIP out of
a 4-layer board in literally only 90 seconds....and it comes
out cleanly; without destroying the PTH's.
About the only thing that goes wrong with these units is that
the little vane-pumps for the vacuum do wear out.  But Pace
sells a rebuild-kit for not too dear....about 30 bucks if I
recall.
I've had my current one (an MBT model Sensa-Temp unit
bought new) for about 10 yrs now; and have yet to even notice
degradation in the vacuum.  It still works like new.
(I do not use it 'production', i.e. 8 hrs a day....if you do,
you'll
of course have to rebuild the pump every few years).
ps;  these Pace stations are also setup to blow hot-air for
reflowing, to mount desoldering-tips for IC's (i.e. melt all
leads at once), and also to use the vacuum to pick up parts
for SMT assy.
Anyway, if you see one of these in working-order for 100
bucks, snap that puppy up...
Richard
Please do NOT add or "subscribe" my name to ANY lists/databases.
2006-02-28 by sbdwag
--- In Homebrew_PCBs@yahoogroups.com, Richard <metal@...> wrote:
Richard
Thank you very much for the Invaluable information. I will definatly
keep my eyes out on ebay for a unit such as you describe.
Regards
Wag
