Success using Press-n-Peel and H202 HCL etch solution (First Attempt)
2006-02-24 by sbdwag
Enclosed below a photo of my first attemp at etching. http://www.wagsterstuff.com/photos/pnpsuccess.jpg Some observations Used a 3m 320grit scouring pad to clean the surface of the copper. Copper was slightly abrased from this technigue. Cut just the pressnpeel I needed and taped it to the paper to create my resist. Used a Industrial Permanent Ink Sharpie to touch up the resist before etching. Used 2/3 cup of H202 and 1/3 cup of HCL at room temperature gently swishing took about 5 minutes to complete the etch. Remove the Ink and resist using Acetone wearing rubber gloves. One comment its difficult to solder directly onto the ground plane with a 40watt iron because the heat is transfered away so quickly. Any good solutions to soldering onto a ground plane. Regards and thanks again for this great group. Dennis Waggoner
