Board cleaning trials
2006-02-22 by Wayne Topa
I have followed the suggestions of those more experienced then me in precleaning the pcb, and found that I 'must have' been doing something wrong. My first 2 boards were cleaned using the scotch brite pad and dish detergent and failed when I ran the board through the laminator. By failed, I mean the toner did not adhere to the board. I had to repeat the cleaning/transfer 3-4 times before I got good adhesion. Wasted a lot of TTS paper that way. I recently ordered some pcb's from abcfab, and on on the EBay page describing the boards, Bill mentioned that there were a number of cleaning solutions that would clean the copper, and that the scotch brite scrub wasn't necessary. One of the cleaners mentioned was Tarn-X. I went out and bought a new bottle (the bottle we had must have been 5-6 years old) and tried it on 4 boards last night. I pre-washed the boards with soap and water using a cotton ball, dried with a paper towel then using a cotton ball soaked with Tarn-X , simply applied it to the the boards. I then washed off the boards with water only and dried them, laminated them and after 5-6 passes through the laminator I dropped the boards into cold tap water and, in 2-3 minutes, the paper floated off and there was no toner on the carrier at all (I use Pulsar TTS) and the boards were perfect. I had a hard time believing it could be that easy. The boards from abcfab were not tarnished in any way so this may be why this worked so well. Even so I did see a change in the color of the copper as I applied the Tarn-X. I am so pleased with the results, I though I better pass it on. This Pulsar TTS paper, though somewhat expensive, is a dream to work with. The paper floats off and does not require any work at all. I have tried other medium but it is just too much work getting the paper layers off the toner. As I am only making boards for my own use, I find the Pulsar TTS is the way to go. Using the Pulsar, 1 minute etch method, I can go from printer to finished board in about 15-20 minutes. Good Transferring! Wayne
