TMI (Too Much Information)
2006-02-14 by David Frascone
2006-02-14 by wh1temouse
--- In Homebrew_PCBs@yahoogroups.com, David Frascone <dave@...> wrote:
> Ok, -- I want to try to make some PCB's, but I'm getting a little lost
> with all the information. Here's what I have:
> HP Laserjet 4MP (with after market (non HP) toner)
> Generic Glossy Photo paper for Inkjet printers . .
> Should I even start with these? What's the cheapest way to get
> started? Go to staples and buy their (Staples Brand) paper and do the
> paper soak away?
> Please let me know!
> -Dave
2006-02-14 by soffee83
>do a "switch to board", and it will give you a board outline with allBut with no logical locations. ;)
>of the components connected with rubber-band lines.
> It's hard to really see the unrouted wire paths when they're close
> together. I wish they allowed for multiple colors on those.
> -George
> PS- Another feature I managed to to not find all this time, was that
> while using the actual rotate tool, you can drag away from the
> object's center and "free rotate" to weird angles.
2006-02-15 by kilocycles
> paper soak away?
> Please let me know!
> -Dave
2006-02-15 by David Frascone
> Dave,
> I got my start in PCBs before I found this group. What worked for me
> was a commercial "plastic paper", Press-n-Peel Blue. It costs about
> $10 for a package of five 8 1/2 x 11 inch sheets, plus shipping. One
> of the suppliers is Electronix Express.
> I would print out my board (reverse image) with my inkjet onto regular
> paper, and take it and the P-n-P Blue to the library for photocopying.
> The plastic "ink" from the photocopier fused onto the dull side of
> the P n P Blue. Then, I ironed it onto the prepared PCB.
> I achieved generally good and consistent results. $2-plus a sheet,
> however is kind of expensive, and I bought a laser printer to avoid
> the trips to the library. I have yet to make an equivalent quality
> board using my Brother 2040 and the P-n-P, so I'm trying alternatives,
> and learning a lot in the process. The manufacture, Techniks, told me
> that "the new laser printers have higher toner temperatures" and that
> I needed a hotter iron. Apparently, I need one fired with MAPP gas, then!
> So, bottom line, the P-n-P Blue and photocopier is a reasonable way to
> start, with minimum frustration. What you learn doing it that way at
> first will certainly apply to the more creative ways later on.
> Regards,
> Ted
>> paper soak away?
>> Please let me know!
>> -Dave
2006-02-15 by Leon Heller
Sent: Wednesday, February 15, 2006 2:48 PM
Subject: Re: [Homebrew_PCBs] Re: TMI (Too Much Information)
> Can the P-n-P blue be used in a laser printer instead of a photo copier?
Of course! That is how it is normally used.
Leon
Leon Heller, G1HSM
leon.heller@...
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
> -Dave
> kilocycles wrote:
> > Dave,
gas, then!
> > Regards,
> > Ted
lost
do the
> >> paper soak away?
> >> Please let me know!
> >> -Dave
and Photos:
> > Yahoo! Groups Links
