What takes off that 'residue' left behind from the toner using inkjet paper?
2006-02-11 by braincambre500
Hello all,
My toner method is coming along real fine, and want to thank all the
ones who have taken time to help me through the process.
I now got it down pat!
The only thing of concern is that filmy coating left behind on my PCB,
after I scrubb off the inkjet paper from the board. I tried
alcohol/WD-40/household oil/and even an eraser...now the eraser works
pretty fair...but I sometimes scrub off bits of the toner also. I am
wondering what substance is this 'filmy' stuff made of? That way, I
can buy a certain chemical that will attack it.
Any has knowledge in this area?
Thank you again for all the help!
Patrick
Re: [Homebrew_PCBs] What takes off that 'residue' left behind from the toner using inkjet paper?
2006-02-11 by Mycroft2152
Hi Brian,
Try soaking the board in water and automatic
dishwashing detergent. Then use a green pad scrubber.
The alkalinity in the automatic dishwashing detergent
dissolves the binder/coating left from the paper.
TANSTAAFL!
Myc
--- braincambre500 <braincambre500@...> wrote:
> Hello all,
> to thank all the
> process.
> behind on my PCB,
> I tried
> the eraser works
> toner also. I am
> of? That way, I
> Patrick
Do You Yahoo!?
http://mail.yahoo.com
2006-02-11 by Patrick Cambre
Hello Sir Myc,
Thank you very much for your advice. I will do as you
say.
I just bought my laserjet and am using inkjet paper,
and everything is coming out fine. It's just a little
tough getting that 'film' off. But I will definately
give that a try. Thank you again!
a friend,
Patrick
--- Mycroft2152 <mycroft2152@...> wrote:
> Hi Brian,
> scrubber.
> detergent
> TANSTAAFL!
> Myc
> > Hello all,
> want
> > to thank all the
> > process.
> left
> > behind on my PCB,
> board.
> > I tried
> eraser...now
> > the eraser works
> the
> > toner also. I am
> made
> > of? That way, I
> > Patrick
> Do You Yahoo!?
> protection around
Do You Yahoo!?
2006-02-11 by Stefan Trethan
On Sat, 11 Feb 2006 14:03:21 +0100, Patrick Cambre
> Hello Sir Myc,
> say.
> a friend,
> Patrick
This film is only there with glossy papers, and is harder or easier to
remove depending on the paper.
If you try matte paper there won't be this film, but the surface is
slightly rougher.
ST
