Does anyone use the chat room?
2006-02-08 by braincambre500
Hello all,
Does anyone use the chat room at a certain time? Or does everyone
just post on the messageboard?
a newcomer, Patrick
Holes for screws
2006-02-08 by Jose Fuentes
I am designing a board that will have two holes for
screws.  How can I place those holes in the PCB
without using pads?
Regards
Jose
___________________________________________________________
1GB gratis, Antivirus y Antispam
Correo Yahoo!, el mejor correo web del mundo
http://correo.yahoo.com.ar
Re: [Homebrew_PCBs] Holes for screws
2006-02-08 by Stefan Trethan
On Wed, 08 Feb 2006 17:42:18 +0100, Jose Fuentes
> without using pads?
> Regards
> Jose
I fear that depends on your software.
Mine has a feature for placing holes, but it is basically only a pad
(usually) without electrical signal.
You can set copper diameter and drill diameter individually, if drill
diameter is the same or larger there will be no copper ring around the
hole.
It should be possible to use a normal pad if your software doesn't allow
for special holes.
As for producing the PCB, i will usually print with option "centering
holes only" which reduces the size of all holes to what is useful in
centering the drill. Then i'll drill there with some small drill i use for
other pads, and at the end enlarge the hole with the right size drill. I
want a hand puch for punching them holes for ages, but they don't seem to
find their way over the atlantic.
ST
Stefan,
what I was using were pads without copper, but maybe
this is not the best way if I'm going to send this
design to a PCB manufacturer.  Also, I found out that
clearance holes must be at least a 5% larger than the
screw diameter.  A rule of thumb is to use clearance
holes 10% larger than screw diameter.
Regards
Jose
 --- Stefan Trethan <stefan_trethan@...> escribi\ufffd:
> for
> > without using pads?
> > Regards
> > Jose
> hole.
> for special holes.
> option "centering
> what is useful in
> right size drill. I
> ST
> Be sure to visit the group home and check for new
> Links, Files, and Photos:
> If Files or Photos are running short of space, post
> them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
>     Homebrew_PCBs-unsubscribe@yahoogroups.com
Re: Holes for screws
2006-02-08 by Chris Horne
Stefan,
I have a Roper Whitney hand punch that i bought here in the UK if
that's what you mean...  I wouldn't use it for pcbs though, a drill is
much easier. Where the punch scores is in thin sheet metalwork where
the drills tend to pull when they break through.
What I have found is that when drilling other than component holes in
pcbs, the best drills to use are the 'Bullet' type, they are easier to
centre on the hole, they do not bind and they break through more
cleanly...
I also tend to drill these holes with an old peice of MDF at the back.
I do have one board where the hole is 60 mm and for that I used to use
a hole saw. The two problems with the hole saw were a) hlding the
board as the saw grabs a good grip on the board.  and b) having to
stop to get the scrap out from the centre of the saw every few holes.
I sorted a) by using another hole on the board dropping over a cut off
nail in the back board... and b) I now use the CNC mill to cut the
holes out with a slot mill.
Chris  (-=Spiyda=-)
> > without using pads?
> > Regards
> > Jose
> hole.
allow
> for special holes.
use for
drill. I
seem to
> ST
2006-02-08 by Leon Heller
Sent: Wednesday, February 08, 2006 4:42 PM
Subject: [Homebrew_PCBs] Holes for screws
> without using pads?
The Pulsonix software I use has a mounting hole part. You could use free
pads with the drill hole the same size as the pad.
Leon
On Wed, 08 Feb 2006 18:34:19 +0100, Jose Fuentes
> Stefan,
> Regards
> Jose
The PCB house will usually be fine with that.
In the gerber files my mounting hole is the same as your pad, a large hole
in the drill file and no copper in the copper layers.
I admit i'm not entirely certain what happens with plating if you have
PTH, they will drill the hole first, then plate into it, but when applying
the resist there will be none tenting the hole, so it should be etched
clear again.
ST
I saw some boards that are attached to chassis by an
L-shape piece of sheetmetal.  Do you know where can I
buy them?
Regards
Jose
 --- Leon Heller <leon.heller@...>
escribi\ufffd:
> From: "Jose Fuentes"
> > without using pads?
> Leon
> them here:
Sent: Wednesday, February 08, 2006 6:20 PM
Subject: Re: [Homebrew_PCBs] Holes for screws
> buy them?
They used to be readily available many years ago. I've made something
similar by drilling angle aluminium and chopping it into small lengths.
Leon
Re: [Homebrew_PCBs] Re: Holes for screws
On Wed, 08 Feb 2006 18:46:02 +0100, Chris Horne <chris@...> wrote:
> Stefan,
Yes such a hand punch is what i mean. Aren't sold anywhere here, not even
mail order, and shipping from the US and taxes is a bit much. Are they
common in the UK? Since you (sort of ;-)) joined the EU there shouldn't be
any customs fees, but i'd have to buy where they take paypal, bank
transfers are too expensive 'cause you don't have the euro and all that...
> cleanly...
bullet type?? You mean a glass/tiles drill?
ST
